Snobrdrkid's WJ Build Thread - Page 108 - JeepForum.com
post #1606 of 6785 Old 08-30-2011, 09:54 AM Thread Starter
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by 1stblack97ZJ View Post
yessiree!
That'd be a cool swap, I've seen a thread on it. AgitatedPancake did the swap!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #1607 of 6785 Old 08-30-2011, 12:00 PM
SnowLeopard
What I want to know is why they stopped using the Aisin Warner transmission.
http://en.wikipedia.org/wiki/AMC_and...s#Aisin-Warner
That thing is a lot stouter than the 42RE, no? I'm sure we could swap, but what would the issues be with CELs? I think some people have done it before. I'd likely do that if I ended up needing a tranny swap.
SnowLeopard is offline
post #1608 of 6785 Old 08-30-2011, 12:08 PM Thread Starter
snobrdrkid07
So the AW4 mirrors the 42re pretty closely and is supposedly a better trans AND fits with the 4.0. But I wonder what codes etc it would through with the WJ
-Michael-
post #1609 of 6785 Old 08-30-2011, 01:29 PM
SnowLeopard
I know that it'll fit and has been done before in ZJ's. I don't know about it working in a WJ. The issues arise from the 42RE being electronically controlled and so forth. The AW4 is mechanical.
post #1610 of 6785 Old 08-30-2011, 02:32 PM Thread Starter
snobrdrkid07
Oh there are electronics in the 42re... but just not as much as there 45re
-Michael-
post #1611 of 6785 Old 08-30-2011, 02:37 PM
Thomahawk
545RFE Rearwhell Full Electronic
Same as 45RFE just another program in the TCM transmision control modul That adds the 5th gear.
45RFE was delivered from factory in 99 and 00 models, sometime in 01 they started with the 545RFE, but all 99 and 00 models can easily be flashed by dealership so it becomes a 545RFE.
Buildthread
Thomahawk is offline
post #1612 of 6785 Old 08-30-2011, 02:54 PM Thread Starter
snobrdrkid07
I was looking at the 545re and was wondering if the could flash it to be a six speed... So it would utilize both 2nd gears.
-Michael-
post #1613 of 6785 Old 08-30-2011, 03:09 PM
Thomahawk
In fact the 45 have 5 gears, the 545 have 6 gears, both have 2 2th gears one for down shift and one for up shift. The difference is the 5th (6th) overdrive gear.
Btw its RFE not RE as in the 42re.
Buildthread
post #1614 of 6785 Old 08-30-2011, 03:36 PM Thread Starter
snobrdrkid07
Right, Now can the 545rfe be programmed to use all 6 gears consecutively?
-Michael-
post #1615 of 6785 Old 08-30-2011, 04:08 PM
joze
No, when you drive "normally" it just shifts normal.
The gears in (5)45RFE are like 1st, 2nd, 2ndLong, 3rd, 4th, 5th. So when i take off it just shifts 1st, 2nd, 3rd... but when i romp the pedal to the floor it upshifts to 2ndLong and then 3rd, 4th... i hope i explained it well enough. If not, i'll make a video.
If you can get it to fit, 545rfe is a great tranny. Or just get a V8
Originally Posted by Ljohn221 View Post
You can't start a new civilization without jeeps
Originally Posted by dukie564 View Post
Epic boobs saving threads since 1978
joze is offline
post #1616 of 6785 Old 08-30-2011, 04:10 PM
1stblack97ZJ
the AW4 isn't a simple swap..
http://www.jeepforum.com/forum/f13/a...dii-zj-382739/
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #1617 of 6785 Old 08-30-2011, 04:11 PM Thread Starter
snobrdrkid07
Yes that does make sense. But what I was wondering is if they can program it to on a normal basis to go: 1,2,2,3,4,5 so it would be turning it into a six speed. Get me? lol. Is there a lock up torque converter with the (5)45rfe?
-Michael-
post #1618 of 6785 Old 08-30-2011, 04:13 PM
Thomahawk
Its like 1-2-2-3-4-5
The first 2 gear is for up shift the second for down shift.
I have read someplace here at JF That the 545RFE actualy can have up to 8 gears physicly, 2 backwards and 6 forwards but Chrysler never Made Any program for That as far as i know.
I would be like R1-R2-1-2-3-4-5-6
Buildthread
post #1619 of 6785 Old 08-30-2011, 04:15 PM Thread Starter
snobrdrkid07
OH WOW I guess it can be done. I think it would be easier for my to buy my overland and swap my audio and mods over to the new Jeep!
-Michael-
post #1620 of 6785 Old 08-30-2011, 04:16 PM
1stblack97ZJ
yep, pretty much haha.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
ome hd , OME lift kit , snobrdrkid , wj
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
