Snobrdrkid's WJ Build Thread - Page 10 - JeepForum.com
post #136 of 6785 Old 01-18-2011, 02:14 PM Thread Starter
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by lloyd877 View Post
Thanks.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #137 of 6785 Old 01-18-2011, 02:21 PM Thread Starter
snobrdrkid07
WJ for Life
Should I look into getting new injectors? Read that could cause rough idle .
-Michael-
post #138 of 6785 Old 01-18-2011, 03:21 PM
AgitatedPancake
Damn man, one thing at a time. You have to rule things out before you find the cause. Why would you look into replacing the injectors before you'll even attempt to pull 1 or 2 screws out to look at a sensor? Hell I think you could replace it for under $50.
I don't understand what's going through you're head to refuse to diagnose, just throw money at it
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #139 of 6785 Old 01-18-2011, 03:24 PM
AgitatedPancake
and when was the last time it got new plugs or you regapped the plugs?
Build Thread:
post #140 of 6785 Old 01-18-2011, 04:22 PM Thread Starter
snobrdrkid07
WJ for Life
I got new spark plugs put in last weekend along with a throttle body cleaning.
I am going to pull the IAC and inspect/clean it, this weekend when I have time.
I was just asking if the injectors could cause the idle issue, I am not messing with that until I deal with the IAC as you suggested. Because I really don't have money to throw.
As always I appreciate the information.
-Michael-
post #141 of 6785 Old 01-18-2011, 07:09 PM
AgitatedPancake
Ahh nice man, good plan! Sorry it kinda felt like you were ignoring the easy things :P. It's nice to check them, just to rule them out in your mind!
Build Thread:
post #142 of 6785 Old 01-18-2011, 07:14 PM Thread Starter
snobrdrkid07
WJ for Life
Reading this about how to Clean the IAC
I am hoping that cleaning it all off should help the idle.
I am still working on my lose a** steering.
-Michael-
post #143 of 6785 Old 01-18-2011, 10:23 PM
Akrobatiks
I finally got that Jet Accu-speed chip installed...!!!! SOoo Stoked!!!! It works perfectly. My speedo is accurate again and because it adjusts the shift points my ride is sooo much smoother on the highway again. Its also looking like my fuel economy is back. Have to do some more driving to be sure but its looking like Il be back up over 200 miles per tank and with my flashpaq set to economy mode I may even get 250+!!!!(Gone about 100 miles w/ about 2/3 of a tank left) Im super pumped about that because gas has been killing me since I got everything done!!!(was getting about 175 miles per tank @ $55 per fill)
As for your Idle issue,
Did you try running some fuel injector cleaner through your gas?
It may sound dumb but have you tried different gas? You could have a bad batch...?
Akrobatiks is offline
post #144 of 6785 Old 01-18-2011, 11:24 PM
SplitNail
Which chip did you get??
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #145 of 6785 Old 01-18-2011, 11:45 PM
CostcoPizza
Fresh Baked
CostcoPizza's Avatar
Originally Posted by SplitNail View Post
I can't read
CostcoPizza is offline
post #146 of 6785 Old 01-18-2011, 11:49 PM
SplitNail
sorry, its late. I just got back from playing tennis. My B.
post #147 of 6785 Old 01-18-2011, 11:56 PM
Akrobatiks
I also have a Superchips Flashpaq with the Fuel Economy Tune programmed in ATM...
post #148 of 6785 Old 01-19-2011, 05:45 AM Thread Starter
snobrdrkid07
WJ for Life
Oh that those two chips must be awesome! I would only need the flashpack seeing how everything is still stock. I usually get 240 (13.0) mpg was my average) out of a tank with heavy city only @ 60-65 a tank.
I am going to look into the IAC first, whenever I get the time. I am going to hopefully soon, be able to pull it, and clean it. And if that helps... Great. And then I may or may not to go to the injector cleaner.
-Michael-
post #149 of 6785 Old 01-19-2011, 08:53 AM
Akrobatiks
Originally Posted by snobrdrkid07 View Post
I usually get 240 (13.0) mpg was my average) out of a tank with heavy city only @ 60-65 a tank hahaha
When I was driving my mom's 4.0, I was getting between 275-300 miles per fill-up FYI on the highway...
post #150 of 6785 Old 01-19-2011, 09:59 AM Thread Starter
snobrdrkid07
WJ for Life
We have gotten 380 to almost 400 on just highway... we could get 22 mpg on cruise on highway
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
