Smoke - JeepForum.com
post #1 of 6 Old 06-11-2010, 04:55 PM Thread Starter
briankeith1968
Smoke
One issue blueish smoke coming from tailpipe. not always but if I am at a stop and in idle is is more than if I am driving. Seems as though when the A.C. is running strong. Coolant level is unchanged and oil level is steady. ???
Things that make you go Hmmmm.
Brian. in Coral Springs
briankeith1968 is offline
post #2 of 6 Old 06-11-2010, 05:01 PM
CostcoPizza
Fresh Baked
CostcoPizza's Avatar
Hello Brian from Coral Springs,
Keep an eye on your oil level it only take a small amount of oil to cause blue smoke. Try and look for the leak, probably the head gasket.
Amauri in San Diego
CostcoPizza is offline
post #3 of 6 Old 06-11-2010, 05:55 PM Thread Starter
briankeith1968
Give me a source to look and if so how much to repair and any alternatives. The smoke started after a new exhaust was put on maybe just cioincidence, But also the smell of the smoke has a sweet smell.
Brian in Coral Springs Florida
99 Grand Cherokee Limited
91,000 4.7 V-8
post #4 of 6 Old 06-11-2010, 06:10 PM
Walt
2008 WK
91,000 4.7 V-8
Black = running rich (carb/fuel inj.); blue = oil (rings, bad PCV valve, or valve seals); steam/sweet smell = antifreeze (head gasket or cooling system leak).
Do compression test of cylinders and pressure test of cooling system. That should give you a direction to head.
Can't estimate $$$ until you know what is wrong (could be $3 - $300).
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is online now
post #5 of 6 Old 06-12-2010, 06:46 AM Thread Starter
briankeith1968
smoke
Thank you I will get those tests done and let you know the results..Hopefully it will be something minor and was able to catch in time... My jeep is too nice to me to be blowing smoke thru my neighborhood.
Thanks again.
post #6 of 6 Old 06-12-2010, 07:17 AM
Walt
2008 WK
......unless you put in Seafoam. Kills the mosquitos.
Walt is online now
white smoke xowiickedox WJ Grand Cherokee Forum 6 03-25-2010 01:41 AM
POLL: Do you smoke? And... vfrpilot Wrangler General Discussion 11 07-27-2009 03:07 PM
White Smoke BRayf78 ZJ Grand Cherokee Forum 22 04-23-2008 12:14 PM
Smoke under dash... TeeJeep ZJ Grand Cherokee Forum 17 03-24-2008 08:00 PM
HELP, Smoke mr_user ZJ Grand Cherokee Forum 1 09-19-2004 12:00 AM
