SLR 4.0 Performance Chip? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > SLR 4.0 Performance Chip?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!Genright at JeepHut
Unread 01-03-2009, 02:14 AM   #1
jakemandinga
1994 ZJ
Has anyone heard of this or used it? It is a Performance chip from SLR Motorsports it says it will give 50 more horses and 50 more in torque plus 3-6 MPG.
Here is the link http://slrmotorsports.com/shop/index...t_detail&p=398
And for $70 it's not so bad. What do you guys think?
jakemandinga is offline   Reply With Quote
Unread 01-03-2009, 08:49 AM   #2
Slummin
That is a seriously deceptive advertisement. There is NO WAY a simple chip upgrade on a 4.0 is going to produce and extra 50 hp, 50 lb/ft of torque and boost milage 3-6 mpg.
Email them and ask for a dyno sheet. Then you might ask how they determined the 3-6mpg increase. I suspect you will not get a straight answer.
What they will tell you is SOME engines can see 50 hp, most likely turbocharged or supercharged engines that have chip controlled boost. SOME engines will see a milage increase.
If they can produce a dyno sheet for their chip on a 4.0, which I seriously doubt, I bet it shows no more than a 10 hp increase and will require premium fuel to get it.
Slummin is offline   Reply With Quote
Unread 01-03-2009, 08:51 AM   #3
gatorayde
( Vehicles with Larger engines produce more HP)
gatorayde is offline   Reply With Quote
Unread 01-03-2009, 09:34 AM   #4
mendelmax
Wow, it improves every single engine parameter. I'm wondering why jeep engineers didn't do it? They probably didn't know how to write proper ECU program, or didn't have a dyno to do it
When I read advertisement like that I'm 100% sure the product sucks
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline   Reply With Quote
Unread 01-03-2009, 10:29 AM   #5
the88thpianoman
the88thpianoman's Avatar
2003 WJ
That thing is the same ebay scam we see over and over again. It plugs into your IAT sensor, giving it a constant reading of like 30 degrees, instead of your IAT sensor being able to do its job and actually determine what the air intake temp is. It's crap, it will give a barely noticeable increase in power by screwing with the timing and not allowing the Jeep to make fine adjustments like it is supposed to be able to, and it should make gas mileage plummet.
the88thpianoman is offline   Reply With Quote
Unread 01-03-2009, 11:17 AM   #6
jakemandinga
1994 ZJ
I figured it was most likely bull. But just thought I'd ask. Thanks for the info.
Unread 01-03-2009, 11:47 AM   #7
the88thpianoman
2003 WJ
Just remember, if it sounds too good to be true, it is. Exhaust headers that will give the 4.0 maybe 10 or 15 ft lbs of torque are a good bang for the buck at around $600. Stroking the engine, which will give similar power increases to those advertised for the chip, can cost anywhere from $1500 to $2000 for a carefully assembled budget build, to $5000+ for an all out high quality build. Excellent bang for the buck increase. If that chip performed as advertised, every single person on this forum would have one. Probably every Jeep anywhere would, because they would have been there from the factory
Unread 12-13-2009, 10:01 PM   #8
RMC_xj
2007 WK
After doing a Google search for SLR, I came up with this. Anyone install an SLR Motorsports Performane Chip?
Pretty sly stuff.
2007 WK CRD | QDII | GDE ECO
1998 XJ | FbG | Moabs & Duratracs - Sold
1996 XJ - Sold
RMC_xj is online now   Reply With Quote
Unread 12-13-2009, 10:10 PM   #9
Mondo727
I got one for my Lamborghini...now it will finally do a burn out...
[U][FONT="Arial Black"][SIZE="4"]Ryan[/SIZE][/FONT][/U]
[SIZE="3"][COLOR="Red"]<04-WJ><4.0><FM Super 40<242><32s>[/COLOR]
[COLOR="White"]<4in IRO><Bilstein 5100's><K&N Intake>[/COLOR]
[COLOR="Blue"]<Alpine Deck><Kicker Components and Amps>[/COLOR][/SIZE]
Mondo727 is offline   Reply With Quote
Unread 12-14-2009, 08:43 AM   #10
oviedojeeper
shoulda got a V8
1998 5.9- 6" lift, HPD30, 8.8 rear 4.10's LS, 33" KM2's
Collecting parts to put the niner on rockwells, which will be coming late 2011.
oviedojeeper is offline   Reply With Quote
Unread 12-14-2009, 08:43 AM   #11
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
These guys must be in bed with RRO.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 12-14-2009, 08:50 AM   #12
Greeeeenberg
ZOMBIE
10 char
97 ZJ Orvis 5.2 108K.
Michigan Tech Jeepers Member #1
Greeeeenberg is offline   Reply With Quote
Unread 12-14-2009, 09:12 AM   #13
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Less AND fewer oil changes...
Wow that site is a winner there!
ArloGuthroJeep is offline   Reply With Quote
Unread 09-24-2010, 01:07 PM   #14
bloggerrich
SLR Chip
I know this is an older thread, but I went to the SLR site because I saw them advertising a 50hp and 50 ft/lbs of torque increase for my 2004 Jeep Wrangler Unlimited. I assumed it was BS, but I did a little research.
It turns out that is pretty much what they say on all vehicles. I looked at probably 25 different makes and models and all said the same thing. Additionally, when I went to the numerous testimonials, I realized that all follow the same sentence format and structure, which pretty much means one person wrote them all.
Also, if a company tells you they can give you 50hp and 50 ft/lbs of torque increases for only $69.95, in 10 minutes and with only a chip, they are completely deceiving you. I had a 1997 Golf GTI VR6 and shopped around for a chip from only well known tuners and the best chip for my car, which had the cat back Borla system and a K&N intake, safely gave me about 15hp and 18ft/lbs torque. When you start getting into 20hp+ increases through a chip, on a stock naturally aspirated engine, you are getting to the point that 93 octane fuel is not enough because the timing is bumped to high. That kind of increase may be OK if you are going to run 97 octane or higher racing fuel exclusively, but I don't know anybody that does that. In fact, at that time, I would occasionally put a few gallons of 103 octane and I believe I was paying about $5 per gallon in 1998. Don't know what it is now.
I am likely going with the Super Chips tuner as they are well known and respected in the industry.
Stay away from any company that gives the numbers mentioned above unless they are well known like Super Chips. And even with the well known companies, you will not see anything approaching these gains unless your talking turbo or super charged engines. Even then, its a stretch.
My Rig: 2004 Jeep Wrangler Unlimited
Upgrades: K&N Air Intake, Banks Stainless Steel Header, Borla Stainless Exhaust, Energy Suspension Poly Bushings, Trail Master SSV Shocks, Rancho Steering Stabilizer, 31x10.50 Firestone Destination AT's
Planned Upgrades: 2" Old Man Emu Suspension Lift, 32x11.50 Firestone Destination AT's, Electric Fan, Super Chips Tuner and a killer stereo system
bloggerrich is offline   Reply With Quote
Unread 09-24-2010, 03:57 PM   #15
ratmonkey
Living dead mod
ratmonkey's Avatar
zombie! kill it with fire!
seriously, if people can't figure out the bs they deserve to learn a 70$ lesson.
ratmonkey is offline   Reply With Quote
