SLOW Stroker Build - JeepForum.com
post #1 of 19 Old 11-23-2012, 10:34 PM Thread Starter
PhantomWJ
2003 WJ
SLOW Stroker Build
I picked up an AMC 258 a few days back. It was running before it got pulled and had relatively low miles. No leaks. No funky noises. The PO decided to install a 4.0 to replace 4.2L; his trash, my treasure.
Once I gather the appropriate bolts, it will come off the engine hoist and onto the engine stand where I will begin tear down.
I will pull the crank and rods, and slowly decide how the build will go; 4.5 or 4.6L. Nonetheless, as my 4.0 nears 200K without issues, I need a reason to dump/waste more money on it.
Any useful input is welcomed.
PhantomWJ is offline
post #2 of 19 Old 11-24-2012, 08:52 PM Thread Starter
PhantomWJ
2003 WJ
Opinions needed:
So i picked up a cheap 4.2L long block...unfortunately it came with the #3235477 crankshaft.........4 counterweights, 46lb, 64mm nose.
Im not completely sure what difference this makes over the 12 counterweight crankshaft, should I wait some more for the 12 counter weight or proceed?
Someone enlighten me.
Below are some picks of the tear down of the AMC 258
4.2L Long Block.jpg   4.2L Old Parts.jpg   4.2L Old Plugs.jpg   4.2L Cylinder Head.jpg   4.2L Oil Pan Off.jpg
post #3 of 19 Old 12-02-2012, 02:19 PM Thread Starter
PhantomWJ
2003 WJ
Zero input from anyone so I continued to disassemble the 258...
More progress...
ForumRunner_20121202_131841.jpg   ForumRunner_20121202_131857.jpg   ForumRunner_20121202_131911.jpg
post #4 of 19 Old 12-12-2012, 10:07 AM
Rocklobster
I don't have any input but if like to know how you make out.:-) good luck.
Rocklobster is offline
post #5 of 19 Old 12-12-2012, 09:41 PM Thread Starter
PhantomWJ
2003 WJ
I hope not to eff it up... to date I can not find a spare block to rebuild...and I dont want to take mine out yet since it is still running...and I need a running toy...
I found the Sealed Power H802CP .020" overbore piston for like $210 shipped for the set of 6 or ...about $115 for only 5 pistons...
post #6 of 19 Old 12-14-2012, 11:08 PM Thread Starter
PhantomWJ
2003 WJ
This is what I think I am going for:
4.6L "poor man's" stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.2L 5.875" rods
Sealed Power 677CP +0.020" bore pistons
9.25:1 CR
Stock 4.0 camshaft
Ported HO 1.91"/1.50" cylinder head
Mopar/Victor 0.043" head gasket
0.088" quench height
Ford 24lb/hr injectors for '87-'95 engines, Accel 24lb/hr injectors for '96-'04 engines, '98 Chevy LS1 25.2lb/hr injectors for '05-'06 engines
248hp @ 4900rpm, 306lbft @ 3250rpm ('87-'95 camshaft)
245hp @ 4800rpm, 315lbft @ 3000rpm ('96-'04 camshaft)
http://jeep4.0performance.4mg.com/stroker.html
post #7 of 19 Old 12-14-2012, 11:25 PM Thread Starter
PhantomWJ
2003 WJ
I found these Sealed Power H825CP20 Pistons Hypereutectic Dish 3.895" Bore AMC L6 Set of 6 (http://www.ebay.com/itm/Sealed-Power...sories&vxp=mtr
or I can get these
Speed-Pro Hypereutectic Pistons ZWH825CP20
http://www.summitracing.com/parts/slp-wh825cp20
or
Sealed Power Cast Pistons Z677CP20
http://www.summitracing.com/parts/slp-677cp20
My question is, what difference would one make form the there?
post #8 of 19 Old 12-14-2012, 11:35 PM
Bama_WJ
Bama_WJ's Avatar
I'll be watching this build. I've been looking into a stroker motor or selling my Jeep and buying a V8. I can't help but think the stroker is the cheaper of the two options though. I've been looking at the 4.7 range (using .060 over bore pistons instead of .030 I assume) and a hotter cam.
Any plans to beef the transmission up?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #9 of 19 Old 12-14-2012, 11:58 PM Thread Starter
PhantomWJ
2003 WJ
Originally Posted by Bama_WJ View Post
I'll be watching this build. I've been looking into a stroker motor or selling my Jeep and buying a V8. I can't help but think the stroker is the cheaper of the two options though. I've been looking into the 4.7 range (using .060 over bore pistons instead of .030 I assume) and a hotter cam.
Plans, not yet. I will wait until it poops out...I had it revuilt a few years ago with HD clutches...it should only have about 40K on rebuilt, if that...id have to check receipt to track mileage....
I though about the V8 option a few years back before I went to 6"...I had found a V8 with a bad motor for like $1000 and some after market lift part i coulda parted to recoup some cash...
I woulda spend more money getting a rebuilt 4.7L and swapping evrything over than what i think I will spend here....plus, i didnt wanna swap lifts, at the time....
I think the 4.6L stroker HP/TQ numbers will be the same if not better than the stock 4.7L...drawback is the tranny....
oh well...this is what I have, I gotta work with it...
post #10 of 19 Old 12-15-2012, 12:13 AM
Bama_WJ
Bama_WJ's Avatar
Yea, that's basically my thinking now. It would probably take me forever to sell off my WJ to someone (normal non-Jeep people would think it's beat to hell) in order to buy a V8 WJ. On the other hand, I could build a stroker motor for under $4k.
Look forward to your build.
Daniel
Bama_WJ is offline
post #11 of 19 Old 12-15-2012, 08:58 AM Thread Starter
PhantomWJ
2003 WJ
You can buy one way under 4K....
You can build one way way way under 4k...i buddy of mine just rebuilt his 4.0 wiht only a .030" overbore had he been patient he coulda added the AMC 258 crank and rods and woulda made out with a 4.7...of course at point, if he did have the crank and rods I woulda encouraged him to only go .020" overbore....
nonetheles, less that 1K was spent on parts and laber....he saved money by reassembling the long block himself, installing and unistalling....etc..
You can do it.
post #12 of 19 Old 12-30-2012, 10:42 AM
WJ2000
Yes your numbers are correct on the cost, of corse I took out my motor my self with help from an buddy
an handed my Mech my motor . And I got out of the shop for 1425, total cost, all including machining, 258 12 counter weight
crank, 258 rods, Sealed Power H825CP20 Pistons Hypereutectic pistons 20 over, new stock cam , oil pump, cam timing set,
I ported my head my self an saved big buck's on that . So really'' you can rebuild your 4.0 pretty darn cheap .
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #13 of 19 Old 12-30-2012, 10:57 PM
WJ2000
Hey I posted this yesterday . But I found it in the Grand Cherokee General Discussion thread site .
WJ2000 is offline
post #14 of 19 Old 03-23-2013, 01:08 PM Thread Starter
PhantomWJ
2003 WJ
So im picking this up today for two bills.
Head is new, less than six months old.
The WJ was the owners wife and when he heard a little pistons slap he decided to get it pulled out and replaced immediately; better safe than sorry he said. The oil pan was off and there was no sign of any piston skirt breakage nor did the bore look worn/chewed or damage. Plus, if there was some sarring the overbore would more than likely take care of it
If so, this will be my donor long block to begin the stroker build. Good thing is, if i have a block to work with, i will have double of everything...and of cOurse i wont have to pull my blo k and lose the wj for weeks....
post #15 of 19 Old 03-24-2013, 01:57 PM Thread Starter
PhantomWJ
2003 WJ
Does any one know the diferrence, aside form what is listed, between the Sealed Power and the Speed Pro pistons?
I can t find the Sealed Power but Summit has the Speed Pro, both in .020 over bore.
