Side Mirror Replacement - 2011 Jeep GC - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Side Mirror Replacement - 2011 Jeep GC
Offset Tie Rod Kit From RuffStuff!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-14-2014, 12:55 PM   #1
BillK
2011 XJ Cherokee
Before I create more work for myself than necessary, or remove more than I need to, can someone tell me how to remove the passenger side mirror assembly on my 2011 Jeep Grand Cherokee?
BillK is offline   Reply With Quote
Unread 03-15-2014, 12:55 PM   #2
ColdCase
ColdCase's Avatar
2011 WK
You may get a quicker response by posting in the WK2 section, but its similar to other chrysler vehicles.
1.Partially remove the door trim panel as necessary to gain access to the mirror.
2.Disconnect the wire harness connectors from the mirror.
3.Remove the three nuts that secure the mirror to the door and carefully remove the mirror
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote
