The Second Coming: Eric's New ZJ Build - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > The Second Coming: Eric's New ZJ Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 09-11-2013, 06:02 AM   #46
Technohead
Old School
Technohead's Avatar
Got my sliders done!
Technohead is offline   Reply With Quote Quick reply to this message
Unread 09-12-2013, 09:12 PM   #47
squashman702
1994 ZJ
Looks good man! Nice meeting you at fall crawl. What trails did you end up wheeling?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 10:22 AM   #48
Technohead
Old School
Technohead's Avatar
JonFund's private property.
We met at Fall Crawl? Refresh my memory. Too many one more, one mores . . .
Unread 09-13-2013, 11:31 AM   #49
squashman702
1994 ZJ
Briefly- I was wandering around with the infamous billy Watkins on Friday night. You were with the guy with the camo ZJ.
Think Twice Garage
Unread 09-13-2013, 11:53 AM   #50
Technohead
Old School
Technohead's Avatar
I remember now.
Unread 01-16-2014, 07:34 AM   #51
riot1987
Nice work man, I dig it. Good job on the build
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline   Reply With Quote Quick reply to this message
Unread 04-23-2014, 06:39 PM   #52
speedbucket
and dennnnnnnnn?
got a link for that prop valve you used? my MC took a dump and id like to ditch the abs crap at the same time if i can...
http://www.jeepforum.com/forum/f22/speedbuckets-zj-build-1361322/
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline   Reply With Quote Quick reply to this message
Unread 04-23-2014, 09:03 PM   #53
Technohead
Old School
Technohead's Avatar
I believe this is it:
http://www.summitracing.com/parts/sum-g3910/overview/
Unread 11-02-2014, 08:09 AM   #54
riot1987
What kind of brakes are you running? How come you changed your proportioning valve?
Build thread^^
Unread 11-02-2014, 08:24 PM   #55
Technohead
Old School
Technohead's Avatar
Stock brakes with Hawk pads. ABS system is deleted. Adjustable proportioning valve allows the bias to be adjusted for lifted configuration.
Unread 11-03-2014, 08:54 AM   #56
speedbucket
i ended up using the stock prop valve with the abs delete, it would be worth it to buy a prop valve like he has, they make it a PITA to delete the abs where every connection is a different size and thread, with an aftermarket prop valve you can just bend/flare a few lines and probably finish with bleeding it in an hour, with parts store trips mine took a few days to sort the connections out and an hour standing at the fitting rack at the back of napa
