The Second Coming: Eric's New ZJ Build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > The Second Coming: Eric's New ZJ Build
TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-01-2012, 03:09 AM   #16
Technohead
Old School
Technohead's Avatar
Originally Posted by jtackerman28 View Post
is that a Rubicon express bracket?
Yes. I'm less than impressed with the construction. Adding a couple short beads to the inside would have made the bracket alot more durable.
Technohead is offline   Reply With Quote Quick reply to this message
Unread 07-01-2012, 08:14 AM   #17
jtackerman28
Thanks now ill know to keep an eye on mine!
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2012, 08:59 PM   #18
Technohead
Old School
Technohead's Avatar
Progress. Rear suspension is IN. Somehow I seem to have ended up with a couple extra inches of lift which renders my shocks, bump stops, and limit straps useless. I figured rotating the spring perches would have made a little difference but not that much. Hmmm.
Unread 07-08-2012, 07:15 AM   #19
squashman702
1994 ZJ
Monster truck status in the rear. Looks like 7" of lift now?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 02:43 PM   #20
bananaslug
Shorter springs would be easiest it seems like. Looks more like 9" in the rear. Measure the hub to fender, i bet its crazy. I am seriously jealous of those axles tho
bananaslug is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 11:49 AM   #21
Technohead
Old School
Technohead's Avatar
Front axle is in:
I've broken a couple OEM engine mounts over the past 3 seasons and both times the fan blade shattered the shroud which in turn sheared the fan blade clean off. Hopefully these poly engine mounts from Ironman 4x4 will solve the problem.
Swapped in my built NP231:
Steering box, pitman arm, and linkage is all bolted up:
Brakes are mostly done. Proportioning valve and lines to the rear and drivers front are in. Still need to run the line to the passenger front (which is a NIGHTMARE):
Exhaust is in. Still need to add a hanger in front of the rear axle. The factory setup does not have one but its absolutely necessary for off-road use:
Even got myself a fancy exhaust tip:
Credibilty:
Ocean State Jeepsters next camp-n-wheel is now less than two weeks away and its looking like I will be trail ready in time. Still to do includes:
  1. Finish plumbing the brakes and bleed the system
  2. Bolt in driveshafts & steering stabilizer
  3. Add fluid to the diffs
  4. Install cold air intake
  5. Replace battery terminals and wire up the winch
  6. Install rear shocks and limit straps
The above are the must-do items. If time permits I will also:
  1. Finish cut-out rocker skids
  2. Fab a new belly skid
  3. Install CB
  4. Install new sound system
  5. Build storage solution for the cargo area
Unread 07-23-2012, 03:46 PM   #22
BenHoleton
2008 KK Liberty
I definitely want to see a storage solution done! I am going to do something with mine. Have a few ideas. Just haven't built it yet
BenHoleton is online now   Reply With Quote Quick reply to this message
Unread 07-23-2012, 07:15 PM   #23
squashman702
1994 ZJ
Any issues with the Ironman mounts? CTeunuch's are becoming a nightmare.
Think Twice Garage
Unread 07-23-2012, 07:32 PM   #24
Technohead
Old School
Technohead's Avatar
Have not even started the engine yet. Tell me more. Vibration?
Unread 07-23-2012, 07:58 PM   #25
biggoofy
The v8 mounts have never had issues only the I6 due to variation in the uniframe from assembly plant to assembly Plant
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
[URL="http://www.mallcrawlin.com/forum/showthread.php?22776-Biggoofy-s-96-ZJ-build!-**Building-axles**"]My Build[/URL]
Need quality parts call Andy at Ironman4x4fab!!!!!
[url]http://ironman4x4fab.com/index.html[/url]
[/CENTER]
biggoofy is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 08:20 PM   #26
CTeunuch
I don't think you have anything to worry about. The 4.0's apparently suffered from OEM production differences in the unibody, which caused line up issues for the mounts on the body side. There's a thread on Mallcrawlin about it in the vendor's section.
Jeeps looks good. Where are you guys wheeling?
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 05:20 AM   #27
Technohead
Old School
Technohead's Avatar
A private property in Southern NH that used to be a campground. I call it Disneyland for Wheelers.
Unread 07-31-2012, 07:52 AM   #28
Technohead
Old School
Technohead's Avatar
Back in the saddle!!!
At first I was getting the click-click-click when I tried to start it. Tried jumping without success. Charged the battery overnight and still nothing. Hooked the battery directly to my winch. Nothing. Its a one year old Diehard Gold. Sears tested the battery and came clean with a replacement. Started the engine up and after about a minute it starts smoking and screeching. Forgot to fill the steering system. Ooops. Hope its OK.
Finished bleeding the brakes, installed the rear limit straps:
Toe is way off so in about 10 miles I peeled a bunch of rubber off the front tires. Otherwise, so far so good. No leaks from the brakes, diffs, or t-case.
There is a rather annoying rattle coming from the front. Sounds like the fan shroud or something in the grille or header panel. Might be somehow related to the poly motor mounts. Speaking of which, they do not transfer nearly as much vibration as I expected. I like.
Still some details left to work out before the camp-n-wheel this weekend. Adjust the toe, rehab then bolt in the front driveshaft, replace liftgate supports, add one more hanger to the exhaust, install new head unit and cb, make the belly skid (if the steel ever shows up), wash, wax, and Armor All.
Unread 07-31-2012, 04:46 PM   #29
CTeunuch
Man that would look good on some AEV's
Sounds like you don't have too much to do before the weekend. Good luck and get some good pictures!
Think Twice Garage
Unread 07-31-2012, 05:14 PM   #30
Technohead
Old School
Technohead's Avatar
Yes it would.
Just bought a new mountain bike and my daughters tuition is coming due. Still interested though . . .
