Seafoam in gas tank DONT DO IT! - JeepForum.com
post #1 of 29 Old 08-13-2009, 07:18 PM Thread Starter
jeep95xj
1995 XJ Cherokee
Guys dont do it! Works great in the manifold however a really bad idea in the tank. After i did it i had a huge problem with under 1/2 tank of gas. Turns out the seafoam broke all the slidge loose in the tank and cloged the pickup screen on the pump so bad it could not suck any fuel through it. Had to drop the tank and clean the screen out. After having this happen to me i started looking around on the forum. Seems that in the last week about 3 other people have posted with problems after seafoam and under 1/2 tank of gas. Avoid the problem before it becomes one. Dont use it in your gas tank.
jeep95xj is offline
post #2 of 29 Old 08-13-2009, 07:30 PM
SouthSeaPirate
SeaFoam is a make or break... Blew a head gasket on a 98 Chevy Venture, and I still stand by it. If there are any weak points, itll find em. Good to know about the Jeep issue though. I put some in at about 193,000 and had no issues, but I didnt put very much. How much did you put in? Is there a pissiblity that it could partially clog the screen? - Im thinking I need to check my fuel pressure LOL
SouthSeaPirate is offline
post #3 of 29 Old 08-13-2009, 07:35 PM Thread Starter
jeep95xj
1995 XJ Cherokee
I used 1/2 bottle in the manifold. Worked great. Used the other 1/2 in a full tank of gas. Thats when my problems started. My fuel pressure was fine at idle. Just about 50 lbs. Droped to 30 lbs under load. And what was powerbraking it on a lift. Tires were not even on the ground so yes they did spin. With out a doubt check your pickup. My jeep runs so much better now. Can actually get out of it's own way.
jeep95xj is offline
post #4 of 29 Old 08-13-2009, 07:39 PM
gmp211
I use Amsoil PowerFoam. It has one job and one application. Just the way I like it.
2002 WJ - Forest Green
gmp211 is offline
post #5 of 29 Old 08-13-2009, 07:47 PM Thread Starter
jeep95xj
1995 XJ Cherokee
Nothing is going in my fuel tank ever again other than fuel.
jeep95xj is offline
post #6 of 29 Old 08-13-2009, 08:08 PM
JForest2
Wow I would have never thought that at all.. But I've never heard of sludge in a gas tank.. The only thing that might build up over a LONG time is dirty gas or water.... This is new to me though.. Thanks for the advice..
James
JForest2 is offline
post #7 of 29 Old 08-13-2009, 08:10 PM
Virmagicus
Virmagicus's Avatar
The reason you have sludge in the tank is because you have had gas that sat in the tank for a long time and turned into sludge at the bottom.Warning everybody is fine but only a small percentage of people will experience your problem.
Jeff
Virmagicus is offline
post #8 of 29 Old 08-13-2009, 08:31 PM Thread Starter
jeep95xj
1995 XJ Cherokee
^ virmagicus - very possible however IMO not worth the risk. I bougt my ZJ 2nd hand as most of us did. No way to know weather or not it has sat.
jeep95xj is offline
post #9 of 29 Old 08-13-2009, 09:16 PM
Fischey
Chris, I agree with virm. Seafoam is okay in the fuel tank you may just have had more sludge than most, take it from a guy who uses way too much Seafoam in every car he's ever gotten his hands on including friend's cars.
Fischey is offline
post #10 of 29 Old 08-13-2009, 09:18 PM Thread Starter
jeep95xj
1995 XJ Cherokee
Hey Ryan whats up! How are those tires holding out for you? Hope all is well. Anyway, I duno i have seen a bunch of guys on here with the same problem as mine. You guys can of course do what you wana do. Im just stating the problems i had due to it. Some with agree some wont. Either way ill use it in an intake manifold again but never in a fuel tank.
jeep95xj is offline
post #11 of 29 Old 08-13-2009, 09:44 PM
Bama_WJ
Bama_WJ's Avatar
I guess the Seafoam did its job then. I've used Seafoam in my tank and went through flawlessly.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #12 of 29 Old 08-13-2009, 09:51 PM Thread Starter
jeep95xj
1995 XJ Cherokee
Seafoam did do it's job ill say that. Just sux that i had to drop the tank and clean the pickup filter.
jeep95xj is offline
post #13 of 29 Old 08-13-2009, 11:03 PM
Fischey
All is well with the tires, you got the pictures right? Anyway in my opinion it's probably a good thing you had to drop the tank and clean everything because it's one less thing you know?
Fischey is offline
post #14 of 29 Old 08-13-2009, 11:05 PM Thread Starter
jeep95xj
1995 XJ Cherokee
Yea i got the pix. Where did you go wheeling LIE 71? Yea droping the tank wasnt a bad thing just wasn't what i wanted to do lol. Really not a bad job at all but 1 more thing taking time away from the lift! Should get started on that soon. Know anyone selling a set of 31"s local?
jeep95xj is offline
post #15 of 29 Old 08-13-2009, 11:08 PM
subliminal
1997 XJ Cherokee
I have used Sea Foam countless times with no problems whatsoever. It sounds like your screen was on its way to become clogged anyway and the sea foam just helped it along. You cant whine about a product when it is doing its job.
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
Should I Use Seafoam? ZJJay ZJ Grand Cherokee Forum 6 12-29-2009 10:02 AM
Seafoam!!! MachinistMade Grand Cherokee General Discussion 0 09-04-2009 05:22 PM
Seafoam? Ski01xj ZJ Grand Cherokee Forum 3 09-23-2007 03:48 PM
Seafoam spros95jeep ZJ Grand Cherokee Forum 5 04-01-2006 10:24 PM
Seafoam 01grander ZJ Grand Cherokee Forum 29 04-15-2005 11:24 AM
