-   Grand Cherokee General Discussion (http://www.jeepforum.com/forum/f197/)
-   -   scparrish build thread (http://www.jeepforum.com/forum/f197/scparrish-build-thread-1530728/)
scparrish 05-31-2013 06:55 PM
So this past monday I talked to kolak and got some stuff heading my way. I got iro 4 lift with the adjustable front long arms, pro comp 9000 shocks, crown coil spring isolators, and moog steering stabilizer. I will be using jk sahara takes offs. This will be the start of the build should be getting parts over the next week or so and I will add some pictures. :cheers2:
Also if you are buying parts for your wj kolak is a great guy to talk to and has the best prices any where. Kolak is good people in my book.
Current Mods:
IRO 4'" lift with adjustable track bar
IRO Critical path front adjustable high clearance long arms
Pro Comp 9000 shocks
Crown coil spring isolators
Moog steering stabilizer
Black dye on plastics
Addco rear sway bar
Akebono caliper swap
Stillen pads and rotors
Retrofitted quad mini h1 projectors
Future mods:
Double din radio upgrade
Rear bumper with swing out tire carrier
Front winch mount bumper
D44a rear axle swap
4.10 gears
5.3 LS with 4L60E swap
bpolly_2004 05-31-2013 07:44 PM
how much did the set up cost you? I either want a 3 or 4 inch lift.
narnwv 05-31-2013 08:49 PM
Moved to Grand General Discussion
scparrish 06-01-2013 11:36 AM
thanks for getting this thread where it needs to go
scparrish 06-30-2013 06:10 PM
Just about have everything buttoned up. I got the parts friday and got everything done between yesterday evening and today. Drives like it did before the lift but slightly smoother. I am getting an alignment tomorrow. I got it to about 65mph nothing unusual smooth no vibes but it does seem like it is a little squirrelly at higher speeds I am hoping the alignment fixs that. I will get pictures up tomorrow after I finish dying the pasitcs, just have the front bumper left.
scparrish 07-01-2013 05:01 PM
http://i578.photobucket.com/albums/s...ps4f9675de.jpg
http://i578.photobucket.com/albums/s...psf5991174.jpg
scparrish 07-01-2013 06:33 PM
I just ordered an addco rear sway bar after seeing the wanna be sway bar during lift install
scparrish 07-02-2013 02:35 PM
so I have been putting off getting an alignment due to the fact that this thing rides and drives awesome no death wobble, not even a hint at any speed over the bumpiest roads. It doesn't pull at all and it just glides down the road with absolutely no vibrations what so ever. So I am debating even getting an alignment done.
scparrish 07-07-2013 08:47 PM
the addco rear sway bar made a huge difference. I am thinking I need gears or I need to start working on my harness for the ls swap it seems very under powered going down the highway, more than it did stock.
scparrish 07-17-2013 11:47 AM
jeep is awesome to drive. My next step to make night driving better is to install 4 mini h1 projectors. I almost have the parts needed I just have to buff the oem headlights and see if they are worth saving.
scparrish 10-11-2013 05:30 PM
bought some new headlights the oem ones were expired. Just need bulbs and ballasts for the retrofit. So far I have to say this is one of the best vehicle builds for the money, so far only about 5k into the whole thing including purchase and it's fun to drive.
scparrish 01-08-2014 07:26 PM
No pictures right now but I removed the ashtray and put in the cubby hole with the heated seat switches so I can finally hook up the heated leather seats. Second gear is starting to slip and new tires are coming up quickly. Working on fiberglass spare tire enclosure at the moment.
The time now is 08:40 PM.
