Scibbyz's 1999 WJ Build - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Scibbyz's 1999 WJ Build
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 06-05-2013, 11:04 PM   #121
Scibbyz99WJ
whats wrong with your idle?
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 11:32 PM   #122
snobrdrkid07
snobrdrkid07's Avatar
Nothing per say. Just a little rough at times, so I was wondering if better injectors would atomize the fuel better and idle better and by better I mean smoother. I've done the throttle body cleaning and replaced IAC and all that stuff. Short of a top end rebuild and injectors I've done everything else. Its more of a nit pick thing though. With the I6 being what it is and hooked up to a non electronic transmission it can only be so good I guess.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 06-12-2013, 01:22 AM   #123
Scibbyz99WJ
Mine needs lifters, BAD. but I'm holding off until I can put this in. a whole new valvetrain.
http://www.ebay.com/itm/Performance-...29a057&vxp=mtr
If you want to replace your injectors these are the ones I used
http://fuelinjectorconnection.com/sh...?productid=280
Unread 06-14-2013, 01:37 PM   #124
snobrdrkid07
That looks likes pretty sweet. Wish I could tear into my engine like that!
-Michael-
Unread 02-10-2014, 05:45 PM   #125
Scibbyz99WJ
Been neglecting this for awhile. (since October '13)
This is what you get letting your sister use a vehicle that isn't hers.
"hey the jeep is smoking and making funny noises"
"shut it off! Where are you?"
"on the highway headed home, can you come get me?"
Bottom line crank is out over .050"s shredded rods bearings 3, 4, and 5. Oil was low and smelled horribly burned up. How or why I don't know.
Barely turned 30,000 on my recent rebuild time to do it over :
Instead of buying a kit like last time I am sourcing parts myself to get exactly what I want.
Ill add pictures once I get home. some are scary!
