Scibbyz's 1999 WJ Build - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Scibbyz's 1999 WJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 03-15-2011, 09:42 AM   #31
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Originally Posted by compcrasher86
Shouldn't have, to my extent of knowledge there's a check valve in the tank that will not allow drainback. Just thought about it... Even easier, pull the fuel pump relay or fuse and then crank the jeep over... It may start and stall, good, fuel pressure released. If it doesn't start, good, fuel pressure released lol
Haha. Good deal man. Ill try and borrow my mech's lift at his house and get under there.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 12:34 AM   #32
JerzeyBoyWJ
2003 WJ
how much was you stroker build..do you have any 0-60 videos?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 10:14 AM   #33
brianestep
Haha isn't that what I said? Yea I don't think removing the fuse actually relieves any additional pressure. It's just a way to check...
brianestep is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 12:35 PM   #34
Scibbyz99WJ
grriiiiiiinnnddclunkkkkkkkkkkkkk chain broke inside my t-case today. in the middle of an intersection!!!!!!!!!!!!!!!!!!!!!
ill post pics installing the new one
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 01:23 PM   #35
AGDubyaJ
242HD in your future?
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 06:36 PM   #36
88yjproject
Scibbz, let me know how that transfer case works out for you.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 06:50 PM   #37
compcrasher86
Yeah but if you pull the fuse then crank itll cycle the fuel injectors and that'll relieve the pressure
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 10:22 PM   #38
Scibbyz99WJ
naw, i wish, money is a bit tight right now and i cant afford one.
plus i was able to get my hands on a 242 with only 23k miles on it from 88yjproject!
Unread 03-22-2011, 10:23 PM   #39
Scibbyz99WJ
ill let you know when i can get the old one off
that top screw is a PITA!
oh and it looks like the ujoints in my rear driveshaft were fried as well. all the bearings were gone from one and ground into pieces on the other.
Unread 03-23-2011, 06:14 AM   #40
88yjproject
I have had the best luck with Spicer u-joints.
HydroLocked Offroad
Unread 03-30-2011, 09:46 PM   #41
=KZ=
Hey Scibbyz was thinking of doing a square slanted stainless tip as well do you have any other shots besides head on so I can check it out? Also have been having probs finding the right one did you tget yours off ebay?
2000 Lmt. V8 Quadradrive, 2" BDS, Bilsteins, JKS Tr Bar, Addco Rear Sway
=KZ= is offline   Reply With Quote Quick reply to this message
Unread 03-30-2011, 10:05 PM   #42
Scibbyz99WJ
thats the only picture i have of it. i can take another tomorrow in the light. but its not slanted, its just a normal tailpipe only squarish.... um its pretty oxidized too. i think i picked it up at oreillys for like 15 bucks a few years ago
it was supposed to "resonate" my exhaust. hah!
Unread 03-30-2011, 10:12 PM   #43
=KZ=
sure its all good then...I guess no one wants to spend too much time polishing their tailpipe
Unread 03-30-2011, 10:24 PM   #44
Scibbyz99WJ
i tried to! i honestly did. but if i left alone for a few days it got worse and worse despite my frequent attempts to clean it off.
Unread 04-03-2011, 04:16 PM   #45
WJ27
Do your 265/70s rub at all and did you trim anything
2000 WJ 4.7L V8 Limited 2.5" BB 265/70-16
WJ27 is offline   Reply With Quote Quick reply to this message
