Scibbyz's 1999 WJ Build - Page 5 - JeepForum.com
post #61 of 125 Old 05-18-2011, 04:51 PM
compcrasher86
well you have a stroker, doesnt count lol. I'm really hesitant about throwing 31s on my WJ now, it doesnt need to be fast it just needs to hold OD on the highway
Matt
compcrasher86 is offline
post #62 of 125 Old 05-18-2011, 06:42 PM Thread Starter
Scibbyz99WJ
but that shouldnt change the way the trans shifts should it?
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #63 of 125 Old 05-19-2011, 02:43 PM
88yjproject
More weight with 31's means engine works harder to move them. Trans might shift more to keep the heep moving.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #64 of 125 Old 05-19-2011, 02:47 PM
compcrasher86
Oh I thought you meant getting through first gear was easy... a stroker will haul through first gear better than factory, the shift delays are the same though... If you get a transgo shift kit apparently its like night and day fixing that, shifts are much faster and firmer
Matt
post #65 of 125 Old 05-19-2011, 02:53 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by JerzeyBoyWJ
try driving those gears with 31s
haha 1st to 2nd takes about an hour
Regear time. Haha
I've got 31s. It's not that bad. At least it doesn't really bother me.
Stroked. Doesn't count. Haha
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #66 of 125 Old 05-19-2011, 03:02 PM
JerzeyBoyWJ
2003 WJ
Originally Posted by snobrdrkid07 View Post
Regear time. Haha
ill be re gearing to 4:56s eventually ..and running 35s
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #67 of 125 Old 05-19-2011, 03:32 PM Thread Starter
Scibbyz99WJ
i think im going to stick with a 2" lift and 31s or maybe trim a little for some 31.6s until i can afford a 4" long arm from IRO and matching jk44s with 4.10s. then ill stuff some 33s under it. but thats eons away!
post #68 of 125 Old 05-22-2011, 10:18 AM Thread Starter
Scibbyz99WJ
I finally got a hitch!!!!!!!!
my e-fan had been acting up a lot lately. then connections on the inside of them fan motor are touchy. i got sick of having to pop the hood every few minutes to poke them to get my fan to work.
i went to the junkyard to pull a clutch fan from any old 4.0. the JY had several zjs, and xjs, and a few wjs. while pulling out the shroud on a zj my buddy shouts at me hey check this wj out! it had a clutch fan, so i excitedly ran around to the rear. and OMG a Mopar hitch, bumper and bezel!!!!
oh and im pretty sure that the clutch fan moves more air at idle than my efan did at full blast.
and i didnt notice any loss of power :P (we'll see about mpgs when i start my work week)
post #69 of 125 Old 05-22-2011, 10:46 AM
Akrobatiks
Nice!!
2001 WJ Limited 4.7L Black on Black --- Interior Modifications... Alpine INA-w900 navigation unit, 2 9-inch headrest LCD's, Alpine PDX-F4 125w x 4 Multi-channel Digital amplifier, Alpine Type - X Component Interior Speakers, Alpine PDX-M12 1200w x 1 Digital Mono Sub Amplifier, 2 MTX - 9510's, Custom built subwoofer enclosure, Sirrius Satellite Radio, Backup Camera, Viper 5901 Remote start/alarm, Passport Escort 9500ci Radar Detector/Laser Shifter, Optima Yellow Top Battery, Cobra 29 LTD BT CB Radio --- Exterior Modifications... 6" Clayton Long arms, Bilstein 5100's, Addco Front and Rear Sway bars, IRO extended rear sway bar links, JKS Trackbar, JKS quicker front disconnects, IRO front upper and lower coil retainers, Rough Country Dual Steering Stabilizers, 17" Fuel Hostage Wheels, 285/70 Goodyear Wrangler Duratracs, Westin Safari bar, PIAA 525 dual beam off road lights, CCFL Halo Projector Headlights w/ Super Vision 6000k HID bulb kit, 100w PIAA 4000k halogen high beams, LED 360 Amber LED signal bulbs, LED Tail Lights, Jet Accu-Speed Computer chip, Flashpaq jeep power programmer, AVS rain gaurds, Yakima 4 Snowboard rack, Curt tow strap receiver mount, Hornblasters Shocker 240 Train Horn Kit, Rigid E-Series 40" LED light bar, Mean Green H.O. Alternator, JCR Stage 3 Sliders, Blue Torch d30/d44a diff covers, KOR Steath rear tire carrier/bumper. LSR winch mount front bumper, Warn xd9000, KOR under Belly skid...
Akrobatiks is offline
post #70 of 125 Old 05-22-2011, 11:23 AM
snobrdrkid07
WJ for Life
Nice find! That poor WJ! haha So your WJ only had one fan from the factory? Only the electric fan?
When you mean clutch fan do you mean the mechanical engine fan that is directly connected to the engine?
Cause I have both... the one attached to the engine and the electric fan!
-Michael-
post #71 of 125 Old 05-22-2011, 12:19 PM Thread Starter
Scibbyz99WJ
Lucky!
post #72 of 125 Old 05-22-2011, 01:25 PM
snobrdrkid07
WJ for Life
Lucky!
I think I have both fans cause I have the tow package if I remember correctly
-Michael-
post #73 of 125 Old 05-22-2011, 02:35 PM Thread Starter
Scibbyz99WJ
Yup, that'd be why
post #74 of 125 Old 05-22-2011, 04:09 PM
snobrdrkid07
WJ for Life
Yup, that'd be why
Well lucky me then. Haha. Also thankful for the 3.73 gears.
-Michael-
post #75 of 125 Old 05-22-2011, 04:34 PM Thread Starter
Scibbyz99WJ
Ah peeshaaa! :P
1999 V8, no fuel. ryanfudger WJ Grand Cherokee Forum 9 12-19-2010 02:43 PM
1999 WJ TC 247 to 242 Hend13 WJ Grand Cherokee Forum 6 12-15-2010 07:45 AM
1999 WJ, Squeaky Fan! 5point1 WJ Grand Cherokee Forum 7 12-02-2010 06:02 PM
New to me 1999 WJ nauthead WJ Grand Cherokee Forum 5 09-14-2010 02:53 PM
Opinion on this 1999 GC sxshep WJ Grand Cherokee Forum 13 04-12-2010 12:54 PM
