It's name is 'Black Jeep' - Page 43 - JeepForum.com
post #631 of 643 Old 12-10-2012, 08:47 AM
1stblack97ZJ
looks good man!!
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #632 of 643 Old 12-10-2012, 04:28 PM
RedZJ
I likely..
How does it perform?
RedZJ is offline
post #633 of 643 Old 12-10-2012, 05:38 PM Thread Starter
PeriwinkleZJ
It performs superb sir! I will NEVER go back to stock steering! I bent waayyy too many stock tie rods, draglinks, and stock ends. Those WJ end shanks are a tad shy of one tons so they're beef. I can get better pics and more details by request.
Sent from your moms house, using JeepForum
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:
PeriwinkleZJ is offline
post #634 of 643 Old 12-11-2012, 02:20 PM Thread Starter
PeriwinkleZJ
A small write up on by home discos:
Took my bottom sway bar bolt to the local hardware store (ie: home depot, lowes, ace, whatever you got). I purchased two 7/16 or 1/2 clevis pins, matching pins, and 2 corresponding washers per disco. I then installed them in the bottom sway bar bolt hole with the pin going inboard. When I disconnect, I just. Use a handy dandy bungee chord to hold the sway bar up and out of the way. There you have it, home made disconnects for $10~.
BUILD THREAD:
post #635 of 643 Old 12-11-2012, 05:18 PM
tyler_t
So you don't have any road noise or anything like that coming from them? I've read before that those clevis pins sh*t out and make a lot of noise.
tyler_t is offline
post #636 of 643 Old 12-11-2012, 05:33 PM Thread Starter
PeriwinkleZJ
They have a little play in them, and occasionally rattle around when I go up and down my driveway as the suspension loads and unloads. Aftermarket discos will do the same though. My brother just pulls his bottom bolts out every time. Much quieter operation, just takes 2 minutes longer. No big deal IMO.
BUILD THREAD:
post #637 of 643 Old 12-11-2012, 05:41 PM
tyler_t
I mean I carry the tool in my jeep to take mine out at anytime but I'd really like some discos.
Built Not Bought #682
tyler_t is offline
post #638 of 643 Old 12-11-2012, 06:37 PM Thread Starter
PeriwinkleZJ
Discos are nice, but can be noisy and troublesome. If you do the home made version, you can always switch back to the stock bolt.
BUILD THREAD:
post #639 of 643 Old 12-11-2012, 06:41 PM
tyler_t
That's a good way to look at it.
tyler_t is offline
post #640 of 643 Old 12-12-2012, 01:13 PM Thread Starter
PeriwinkleZJ
I also pulled my VIC out and built a little switch panel to replace it. Those switches are $8 damn dollars at the parts house so I only grabbed one for now. The label says 'OBA'.
BUILD THREAD:
post #641 of 643 Old 12-12-2012, 01:37 PM
tyler_t
Rock auto!
tyler_t is offline
post #642 of 643 Old 12-12-2012, 01:42 PM Thread Starter
PeriwinkleZJ
I grabbed a few more from the parts house, I get a hefty discount. Just no installing them until I need to.
BUILD THREAD:
post #643 of 643 Old 03-24-2013, 10:26 PM Thread Starter
PeriwinkleZJ
Rock lights in action.
598738_10151252472416444_767313234_n.jpg   483137_10151252472221444_1881040009_n.jpg   540076_10151252472121444_662416028_n.jpg   22216_10151252472081444_687617549_n.jpg   379323_10151252472046444_1565778639_n.jpg
543903_10151252471406444_693892668_n.jpg   67424_10151252470961444_1266921422_n.jpg   75796_10151252471981444_220303186_n.jpg   602872_10151252470916444_146638621_n.jpg   217540_10151252471066444_1475035861_n.jpg
BUILD THREAD:
Flat Black Jeep..... hargenraderj Wrangler General Discussion 50 05-21-2012 11:38 AM
RED Jeep grand cherokee with black wheels AustinJohnson Grand Cherokee General Discussion 26 11-16-2011 01:50 PM
Black jeep, Khaki Top? ian0341fo Wrangler General Discussion 18 02-28-2011 10:40 PM
Black Ice = Jeep RIP Mud-Hunter Wrangler General Discussion 44 01-31-2010 04:42 PM
took the yj out with my bud and his jeep on black gulch trail basestealer12 Wrangler General Discussion 2 10-07-2009 12:04 AM
