Roughknight69's 95 zj build - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Roughknight69's 95 zj build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-25-2012, 06:25 PM   #31
roughknight69
Went ahead and painted my rims to today
Also made in dash switches for my winch, no more having to leave the window cracked open for the controller and getting covered in mud
roughknight69 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2012, 09:10 AM   #32
roughknight69
Going to take my physical and drug test for cummins tomorrow a very nice pay bump in 1yr-1yr 1/2 I hope to be making double what I do now. Needless to say the jeep will be upgraded very nicely soon!
Unread 04-26-2012, 06:34 PM   #33
roughknight69
Got around to putting my switches where my vic used to be. The fake wood plate there on is temporary, until I grab up some very thin sheet metal.
Unread 04-27-2012, 02:37 PM   #34
roughknight69
Adjusted tv cable, only took a few mins to to. Deffinitely can tell the difference trans isn't searching for gears and doesnt go hard into 2nd like it used to. I also noticed that it doesnt want to downshift as much either.
Unread 05-02-2012, 05:07 PM   #35
roughknight69
Went wheeling today
Only trail damage is my rear pass. bottom shock bolt came off and bent the shock a little :thumbsdown:
Threw on a new bolt/nut and went on wheeling with no problems
Only a few pics for now, nothing to exciting I'll have some videos up hopefully tomorow that are much better!
540254_3566316874828_1180093514_32783335_139572884_n.jpg   558507_3566309594646_1180093514_32783332_1744771160_n.jpg   534871_3566326195061_1180093514_32783338_404300643_n.jpg   dscn3932.jpg
Unread 05-03-2012, 12:33 PM   #36
roughknight69
Re-adjusted my rear track bar today
Build thread [url]http://www.jeepforum.com/forum/f197/roughknight69s-95-zj-build-1319907/[/url]
Unread 05-03-2012, 09:43 PM   #37
roughknight69
Couple vids, nothing to amazing
Only the two of us and we didnt feel like walking back and forth in deep mud for videos of the harder parts
Unread 05-04-2012, 08:23 AM   #38
roughknight69
Unread 05-04-2012, 05:06 PM   #39
roughknight69
Vids of fellow jf member jasonstebbins from the trip
He's stock on 235 hurcule mt's
Unread 05-04-2012, 05:12 PM   #40
roughknight69
Officially starting cummins either next fri or the following, depending on when i put my two weeks in at my old job if they wont sched. me for the last week.
I can already see those long arms,axles/lockers, and mts.
Edit: and many trips to rausch creek
Unread 05-12-2012, 05:25 PM   #41
roughknight69
a few from today also started cummins! pretty good so far.
Unread 05-20-2012, 12:29 PM   #42
roughknight69
Flushed my cooling system today, it was horribly dirty. (po decided to put stop leak in it )
Since letting it sit and warm up it does not seem to be getting as hot as it usually would.
It would crawl up to 230 if i let it and turning the heat on brought it right back down to 210ish. So far hasn't gone above 200 yet.
When having the top radiator hose off flushing out the old coolant/water the t stat kicked in and shut when it was supposed to
and the pump seemed to be pushing the water out fine.
The only thing I can think of if it gets super hot again is that the radiator is shot, seems like the original.
Unread 05-26-2012, 12:02 PM   #43
roughknight69
Finally got around to putting my Iro rear coils in today that gave been laying in my closet for a few months : rofl:
The ride is alot stiffer compared to the front swap. Netted 22in from hub to fender with my usual heavy load of crap in the back.
Ordering rc disconnects today also.
Unread 06-02-2012, 05:47 AM   #44
roughknight69
My new rough country disconnects and rear shock that are going in today. I'm thankful that this little project doesn't require using jack stand and the tires off as its most likely going to be pouring rain out while I'm doing this.
Unread 06-02-2012, 11:27 AM   #45
Roskoe
looks great keep up the good work
"aut viam inveniam aut faciam"
I hate when old people poke me at weddings, point and whisper, "You're next." So I've started doing the same thing to them at funerals
Roskoe is offline   Reply With Quote Quick reply to this message
