Roughknight69's 95 zj build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Roughknight69's 95 zj build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 03-14-2012, 06:45 AM   #16
HeavyArms
Yes sonicelectronixs is where i bough my kicker wiring. Crutchfield is a rip off. Sure the site's handy but god there price's are ridiculous.
I wish I could be a kewl wangster lol
tip's: wd-40 every bolt you'l be taking out a few time's a day for a few days. It make's things go much nicer.
Wiggle wiggle wiggle
HeavyArms is offline   Reply With Quote Quick reply to this message
Unread 03-14-2012, 07:06 AM   #17
roughknight69
Id pb-blastered every bolt for the past 3 days!
Any tips for going through the process of installing the lift? never put trac bars on before.
roughknight69 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2012, 07:18 AM   #18
HeavyArms
IRO's instructions are actually pretty helpful lol. Start at the back, it's much much much easier and less intimidating.
Unread 03-14-2012, 07:32 AM   #19
roughknight69
sounds good i'm glad I have until sat to get it all done and Its going to be in the 70s and sunny! wont have to wear a full jump suit this time.
Unread 03-16-2012, 07:31 PM   #20
roughknight69
ZJ is now officially lifted 3.5 in
Will take pics tomorow after work, Will have to drive to work (only 3mi.) with the steering wheel upside down and not being able to turn all the way right (all taken care of by an alignment right?) which is tues morn.
Unread 03-17-2012, 07:51 PM   #21
roughknight69
Got some pics of the lift I really need to touch up my wheels that were damaged wheeling. Maybe this week
430115_3342525798223_1121056481_33383989_1897560015_n.jpg   427696_3342531798373_1121056481_33383999_1657155683_n.jpg   431570_3342526918251_1121056481_33383992_849495603_n.jpg   429112_3342528478290_1121056481_33383995_584028747_n.jpg   430481_3342533358412_1121056481_33384000_1018280478_n.jpg
Unread 03-19-2012, 01:16 PM   #22
roughknight69
Recieved my rear 3.5 iro springs today finally
Unread 03-25-2012, 05:18 PM   #23
roughknight69
Adjusted my steering box today deff. firmer feeling and not as much sway on the highway. Before it was pretty scary, feeling the axle sway underneath you. Now not much play, though I do think some of it is due to the 7/16 pin bolts I used at the sway bar connection to the axle (per $5 dissconnect thread). You can here them clinking a bit when I hit bumps goin through town.
Besides that moving to a new appt so the new rear springs are waitng till I have time for them.
Unread 03-26-2012, 07:25 PM   #24
HeavyArms
So the pins are a bit small? I was planning on removing my swaybar link bolts and just taking the bolts in with me.
Unread 03-26-2012, 10:22 PM   #25
roughknight69
There just a bit small so it makes a little noise, but what i think i'm going to do is take the origion sawy bar bolt and just drill a hole for a coter pin. Seems like a good idea in theory, well see thou
You could also do 1/2in pins instead of 7/16ths and drill out the sway bar mount just enough for a snug fit to.
But for a temporary disco the 7/16th do there job
Unread 03-28-2012, 02:59 PM   #26
roughknight69
Having fun in the creek bed waiting for my mach. to get his computer fixed for my inspection apt.
546562_3406670881810_1121056481_33414422_1913039875_n.jpg   551471_3406675281920_1121056481_33414427_559220398_n.jpg   531925_3406680722056_1121056481_33414434_1529953408_n.jpg   544691_3406679442024_1121056481_33414433_971923678_n.jpg   557854_3406677401973_1121056481_33414429_1313198340_n.jpg
Unread 04-04-2012, 03:20 PM   #27
roughknight69
Replaced my front drivers side wheel bearing today. Was so simple and easy compared to alot of other people, who have trouble with it. The axle nut came loose an the first try, then used the bolt trick to pop the bearing itself off.
Unread 04-04-2012, 03:22 PM   #28
roughknight69
Gonna try and make myself install my iro skid plate tomorow since it will be nice. Though, the thought of going hiking is temping to.
Unread 04-10-2012, 11:19 AM   #29
roughknight69
Replaced front pass caliper. deff can tell it was seized
Also installed crown braided steel/kevlar extended lines meant for a tj with 3-4 in of lift.
I have about 2-3 in extra then I needed on the lines but now I can always go bigger and not have to worry about them
Probably thurs I'll be bumpstopping the zj finally via hockey pucks
Could I instead use and extra puck instead of the old orange bumpstops in the front?
I took them out when doing the lift and forgot to put them back int
Unread 04-25-2012, 12:18 PM   #30
roughknight69
Whipped out the angle grinder today and chopped up my front bumper.
I will get those wheels repainted soon I swear!
