Roughknight69's 95 zj build - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Roughknight69's 95 zj build
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineCHASSIS SAVERô Labor Day 2 for 1 Sale!!!JKS Flex Connect in Actions!
Unread 09-30-2013, 04:22 PM   #241
Lincolnwelding
Hey man if you and your jeep ever get around the binghamton area and want to do some wheelin let me know!
"Piper, theres a big difference between wingin it, and seeing what happens"
Want to change my forum name to jeep wheelikers
WJC #292
Lincolnwelding is offline   Reply With Quote Quick reply to this message
Unread 09-30-2013, 04:29 PM   #242
roughknight69
Alright! Thanks for the invite!
Build thread [url]http://www.jeepforum.com/forum/f197/roughknight69s-95-zj-build-1319907/[/url]
roughknight69 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2013, 06:23 PM   #243
roughknight69
It's been a while, nothing to much to report besides Dunn tire not tightening a drag link sleeve bolt. It was almost all the way off!! Also bought some hella 550ff amber fog lights today, for those white out winter storms.
Unread 12-18-2013, 05:00 PM   #244
roughknight69
We'll after waiting over 2 weeks summit keeps pushing the back order delivery date of my hella 550, I changed the order to a pair of warn w650f amber fog lights for another $30
Unread 12-18-2013, 06:41 PM   #245
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Why amber lights
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 12-18-2013, 06:52 PM   #246
roughknight69
Originally Posted by DNFJ
Why amber lights
For white out conditions to see easier in the snow, less reflection on snow.
Unread 12-19-2013, 04:20 PM   #247
roughknight69
Fog lights came!
Unread 12-21-2013, 06:43 PM   #248
roughknight69
Installed!
Unread 12-22-2013, 05:28 PM   #249
roughknight69
Finally some light pictures. The fog lights were adjusted a bit higher after these pics, but my iPhone wouldn't pick it up well on the rd. also my low and high beam shots. I can turn off the headlights and drive with my fogs just fine. Which is what I wanted for the white out snow conditions since the dichroic coating on the lenses, provides a low-glare yellow light.. Also I can upgrade these from 55w to 100w, which I'll probably do in the next few weeks.
Unread 12-23-2013, 05:29 AM   #250
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
They actually throw a really nice pattern.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 12-27-2013, 09:58 AM   #251
roughknight69
Thanks!
Unread 12-27-2013, 09:59 AM   #252
roughknight69
Talked to carolina driveshaft today about a new front shaft. He recommended not going with the adapter and switching out the yolk itself. Which I would be all for, but I'm going to replace the lp 30 with an hp 30 whenever I find a good one. Also believe this lp 30 is slightly bent since my camber on my drivers side is off by 1*. So I think it would be a wast of extra money to have a yolk installed for now, unless the vibrations are so bad I can barley drive it.
The top one in this picture I'm going for.
Unread 01-07-2014, 06:18 PM   #253
roughknight69
Shaft will be here tomorow. I also ordered a omix-Ada water pump and cougar Efan to install.
Unread 01-10-2014, 02:30 PM   #254
roughknight69
Brown Santa came!!
Unread 01-12-2014, 03:23 PM   #255
roughknight69
Installed my e-fan today, was a pita but I got it! Along with the thermostat. Would have done the water pump but ran out of sun light. My silver on/off/on switch mounted. The e-fan was within an inch of the water pump, but it worked.
