Roughknight69's 95 zj build - Page 11 - JeepForum.com
post #151 of 276 Old 01-16-2013, 07:59 AM
DNFJ
Go to a jy and rip apart their header panel to get the bolts, then tap yours out and replace.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #152 of 276 Old 01-16-2013, 09:10 AM Thread Starter
roughknight69
You mean grabbing the plastic adjusting gears out of the jy header panel? My adjustment is pretty decent right now, but I wanna do what one person did on here was drill holes behind the header panel and use regular bolts to connect and adjust the headlights.
Build thread
roughknight69 is offline
post #153 of 276 Old 02-20-2013, 07:39 PM
nickpequignot
So I'm looking into bed lining my zj I did a trial on my spare door with some under coating and some desert tan spray paint. Didn't turn out vary good. The paint peels off the under coating easy. I was looking at monstaliner. And the 2 gallon tintable kit and desert tan tint is 256$ before shipping. With out the tint in it is the liner black? Or would I have to get black liner. Is it worth te 250$+?
This is the scheme I'm going with
nickpequignot is offline
post #154 of 276 Old 02-20-2013, 10:57 PM
bananaslug
The non-tintable is just black. Somewhere on their thread it says the price is going up so try to buy it before then if you can.
Look through the Monstaliner pictures in the Jeep Photos forum, when done right the quality and look are hard to beat for that price.
As a side not, the black on top and tan on the bottom seems like a bad choice but to each his own.
bananaslug is offline
post #155 of 276 Old 04-16-2013, 01:22 PM Thread Starter
roughknight69
Update: in the past few months the zj has taken a seat on the back burner while as I had lost interest in modding it. Due to recent advents and have just been enjoying life.
Though I have finally got off my lazy but and replaced the front d shaft u joints. First time ever doing u joints myself and it wasn't to bad. The reasoning for doing this was because my u joints clicked very loudly and were completely shot. Did I mention loud and annoying? :
But all is well now no chirps and I'm happy
Build thread
post #156 of 276 Old 05-26-2013, 10:14 AM Thread Starter
roughknight69
Yesterday I had to tear the drive shaft apart and grease up everything well. It started to make the angry sparrow noise again. :brikwall:
But thankfully nothing was broken and its all better now!
Build thread
post #157 of 276 Old 05-26-2013, 10:19 AM Thread Starter
roughknight69
Also in the next few months ill be doing this list of items to it when overtime picks up. Along with some long term goals.
- iro short arms
- Tom woods drive shaft
- 4.5 in springs
- notch fender flares
- re painting it in Monstaliner jungle love/black
-undercoating it again in chassis saver
-Rear quarter panel armor
-33s
-d44a swap (for now)
-ac condenser
Build thread
post #158 of 276 Old 05-26-2013, 04:23 PM
GCjunkie93
Looks like a pretty good list
Why repainting it? Problem with the first paint job or color preference?
1993 ZJ 5.2 V8-Some Stuff/Beater
1984 CJ7 258/Auto/Dana 300/Daily Driver
GCjunkie93 is offline
post #159 of 276 Old 05-26-2013, 04:29 PM Thread Starter
roughknight69
My first paint job could of been better I didn't realized it had to be recoated in 8 hrs, so I ended up doing it at midnight with a work light. but really just more color preference. The desert sand color is great but I live in New York where everything is woodsy/green not much desert here so I don't think it fits in as well as I would like it to with the environment. So I'm planning on going with the dark green called jungle love. As seen in this picture.
Build thread
post #160 of 276 Old 05-26-2013, 06:00 PM Thread Starter
roughknight69
Seen this today at tractor supply! I want a zj one
Build thread
post #161 of 276 Old 06-06-2013, 03:23 PM Thread Starter
roughknight69
My new ac condenser was delivered today! Can't wait to have cold ac for summer will be installing this weekend. Also my ipf headlight bulbs will be here Monday. Relay got water inside of it causing the drivers side low beam to blow and eventually the passenger. Replace the relay an bulbs and should be good to go.
Build thread
post #162 of 276 Old 06-08-2013, 01:57 PM Thread Starter
roughknight69
Replaced air condenser today every thing went well except for one of the a/c lines that didn't want to come off. : but after a few whacks with a bfh it came off refilled the r134a and now for the first time ever I have Ice cold a/c in the zj also every car that u ever had besides my exploder when I was 16.
Build thread
post #163 of 276 Old 06-10-2013, 12:54 PM Thread Starter
roughknight69
Brown Santa came today while I was working
D-ring
Tool bag
And ipf Arb h4s
Build thread
post #164 of 276 Old 06-16-2013, 06:31 AM Thread Starter
roughknight69
Replaced the pads and rotors today. Didn't realized how bad the rears were, so worn down they barely worked. While changing the brakes I discovered them at the passenger rear axle seal was leaking causing a ton of build up around the rim. :Brickwall:
After the brake change and driving the zj around the same side became hot and started to smoke due to the differential fluid leak. After a few hours of driving most of the fluid build up burned off and the rim cooled down to normal. Will eventually get the seal replaced.
Up next is either new adj. control arms or the kolak exhaust!
Build thread
post #165 of 276 Old 06-18-2013, 03:50 PM Thread Starter
roughknight69
Decided on getting 33x12.50 Goodyear mtrs with kevlar an 15x8 Mickey Thompson classic wheels after the iro adj. arms.
Build thread
UK WG build offroading.net Grand Cherokee General Discussion 98 12-05-2015 11:33 AM
Bumper Build Project For my 95 ZJ: Build Time- 1 Month TMNT2210 ZJ Grand Cherokee Forum 43 09-10-2015 12:57 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
Fbi (offroad build inspeter) build 93zjFBI ZJ Grand Cherokee Forum 8 12-18-2010 11:43 PM
where to buy 4.7 re-build kit??? kik_start ZJ Grand Cherokee Forum 5 04-29-2008 08:16 AM
