roof rack and winch plate on a budget - JeepForum.com
post #1 of 8 Old 02-19-2014, 06:42 PM Thread Starter
Jameswj4
Im 19 and in College at Wallawalla University for Industrial Design. im in Shielded Metal Arc welding as a requirement for my major. my teacher is pretty cool and lets me do any project i want and better yet i can use materials he has laying around in the shop.
so i first decided i wanted to make a roof rack. so i started with a metal twin bed frame and used the legs for a top hoop. i welded in a thicker bar in the middle to hold a tire. and another up front to mount lights. i got it all done i just need to weld on a bracket in the rear to mount my cb antenna since my other one broke.
then i got some garage sale shackle tabs from fawkes fab and welded it onto angle iron. i made them longer in the rear and drilled holes to bolt up where the gas tank skid mounts. and i was going to bolt them into the frame rails up front.
today i walked into the shop and decided i was going to build a winch plate. so i found more angle iron and welded two 4in wide plates together each 1/4 in thick. they are cut to 31.5 in which i measured is around the length between the two frame rail openings. i then welded the angles to each end and added the 1.5x1.5 to strengthen between the angles. and im going to bolt the front shackle tabs to the angle
so thats where im at as of right now. im thinkin of welding in some plates just inside the frame rails as support. then run bolts from the angle iron to plates under the rails and sandwich it all. everythings not completely finished and ill work on it when i get time.
any thoughts or ideas would be cool. like i said im a college student just testing my skills and working with what i got.
IMG_20140120_1321591_zps5cce1a4c.jpg   20140121_1329001_zpsed16c44a.jpg   20140217_123118_zps5s8rlabg.jpg   20140217_1231331_zps8b4ec8bb.jpg   IMG_20140129_1355081_zps92a15ac1.jpg
20140211_2225231_zps8a76df3a.jpg   20140213_0901391_zps93dbd265.jpg   20140219_154009_zpstb3atpil.jpg   IMG_20140219_1443011_zps96e4aad8.jpg   IMG_20140510_162644_zpsujw6xry8.jpg
'04 WJ "Sherry" 4.0L RCX 4in lift on 265/75/16 BFG ATs DD/Trail rig- uniden 505xl 4ft firestik- custom roof Rack- custom rear and front shackle tabs-
Jameswj4 is offline
post #2 of 8 Old 02-19-2014, 07:40 PM
Timbo24
You should make real mounts for that rack or make a new one all together. That tire could fly off and kill somebody and take the rack with it. Search on here there have been some pretty cool custom racks made.
Timbo24 is offline
post #3 of 8 Old 02-19-2014, 07:53 PM Thread Starter
Jameswj4
i haven't made mounts for the rack yet.. and im not going to make another since i made this one for free and that was the point so i dont have to spend money. the tire is held on by the same threaded hook that was in the wheel well. ive driven around and its stayed put.
Jameswj4 is offline
post #4 of 8 Old 02-19-2014, 08:04 PM
Timbo24
Ok I thought you were mounting it with those ratchet straps. I was meaning if you stop really fast or get in an accident that thing will go flying.
Timbo24 is offline
post #5 of 8 Old 02-19-2014, 08:10 PM Thread Starter
Jameswj4
nope im deciding if i want to use like u bolts to attach the roof or weld tabs and bolt it to the actual roof.. hm any other idea to mount the tire? i didnt want to weld a plate with studs incase i need to throw stuff up there
Jameswj4 is offline
post #6 of 8 Old 06-22-2014, 01:25 PM
JayIV
JayIV's Avatar
I would like more information about those rear tow hooks. How have they lasted? Typical use? How are they mounted? Did you drill additional holes for the bolts along the hitch?
2004 Overland
JayIV is offline
post #7 of 8 Old 06-23-2014, 08:56 AM Thread Starter
Jameswj4
Well I got the shackle tabs (blocks) from a garage sale on the fawkesfab website. Igot 4 for $25 the. I took 11/2" x11/2 " angle iron and I think they are 21 in length but I'm not sure I'd have to check. And I stick welded them all the way around . Holes wise I measured how far I wanted it to stick out then drilled 1/2" holes so it would line up where the gas tank skid and hitch would mount then I cut holes in the bumper. . With the right measurement u can cut a smaller hole but I just guessed and kept getting wrong but I'm okay with it. And durability. It works great I've gotten tugged pretty hard from the back when I got stuck in snow . Just make sure u have at least 2 bolts.. 3 is better
Jameswj4 is offline
post #8 of 8 Old 06-23-2014, 11:44 AM
dlbarr
Hey James, I live over in Kennewick. I may be interested in having a project done - are you interested in talking about that? You could PM me if you are...
dlbarr is offline
