Rolling a ZJ with Bolt-in Cage - JeepForum.com
post #1 of 7 Old 03-07-2013, 10:07 PM Thread Starter
AAA
Has anyone had any experience or seen a demo of a bolt-in roll cage after a rollover? With all the controversy over the clamps vs welds, etc. you would think that one of the companies who makes a bolt in roll cage would make a video of their cage in action. I'm sure they can find a cheap ZJ that barely runs for a couple of hundred dollars, install their cage, and send it rolling off a cliff to see how it holds up.
Are there any videos or pictures? If so, post up.
AAA is offline
post #2 of 7 Old 03-10-2013, 09:31 AM
biggoofy
kits suck go have a shop build a correct cage if you plan to wheel hard not only will it save you but your jeep will live longer with a properly tied in cage
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #3 of 7 Old 03-12-2013, 01:29 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
It'll hold up just like a one time use cage. For evidence, look up stock tj rollovers.
ratmonkey is offline
post #4 of 7 Old 05-21-2013, 11:34 PM Thread Starter
AAA
As the original request stated, I was looking for pictures or videos of one of the bolt-in kits after a rollover. Stock TJ's obviously don't have the bolt-in kit I was referring to. But thanks for playing.
AAA is offline
post #5 of 7 Old 05-21-2013, 11:55 PM
Timo_90xj
Timo_90xj's Avatar
You're thinking about building a cage using clamps? IMO those aren't true roll cages, they are showtruck stuff that won't hold in a true roll-over. Might survive a slow flop but that's about it. Don't expect for one to survive a multiple roll- over when crawling, let alone a high- speed roll- over.
As was mentioned, a custom cage with welded connections is the ONLY way to build a proper cage. There's nothing wrong with attaching the cage using bottom plates + bolts to the unibody though.
***Under construction***
Timo_90xj is offline
post #6 of 7 Old 05-24-2013, 09:54 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
The tj cage is actually built better than the bolt together station wagon kits.
They're intended to help some survivability of the driver and passengers, but the jeep will be totaled all the same.
post #7 of 7 Old 06-01-2013, 11:04 AM Thread Starter
AAA
I was just looking for pictures or videos to see how they held up after a rollover. That's it - nothing more. I guess there are none.
AAA is offline
