Ricochet's build thread project "WOODY!!" - Page 53 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Ricochet's build thread project "WOODY!!"
Unread 01-08-2012, 10:25 PM   #781
Heepish
It really has come a long way! Just finished skimming through all 52 pages, really like the look of it. I'm hoping to start building my ZJ soon, but first I need to come up with the money and gain some experience in wrenching
1998 Grand Cherokee 5.9 Limited - Completely bone stock for now
1996 Grand Cherokee 4.0 2WD Laredo - Suprise for the grandfolks
1994 Chevy Silverado 1500 4X4 - Plow Truck
1993 Honda Del Sol Si - Parked good weather DD
Heepish is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 09:17 AM   #782
Ricochet88
OK so some of you know my fuel pump finally died. while I have the tank out I wanna cut a trap door in the floor so when it happens again it will be a simple swap without dropping the tank again. Does anyone have suggestions on how to make a trap door that will be water proof yet in screw fairly simple? My only problem is the floor is not flat it's corrugated or whatever you wanna call it
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread PROJECT WOODY
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 10:33 AM   #783
85IrocZ-28
Just cut it, then find some sheet metal. I would cut some tabs out of the sheet metal that rest in a few spots around the perimiter of the cut you made, and silicone them in place making sure that they stick out into the hole. Then rest the cut peice of metal onto those tabs, and pull out a tube of silicone or gasket maker and seal the thing up. Silicone will make it water tight, and it is easy to cut with a knife if you ever need to remove it. I would just use silcone in a tube (from a hardware store) as it is cheaper than gasket maker.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 12:49 PM   #784
Ricochet88
Thanks that's what i was thinking has anyone done this or have pictures of what they did?
Rick "woody"
Unread 03-27-2012, 09:16 AM   #785
Ricochet88
Soooo I didn't end up cutting the hole in my floor lol
Rick "woody"
Unread 03-27-2012, 09:44 AM   #786
Heepish
I was starting to wonder what had happened to the Woddy...glad to hear you got your fuel pump replaced It was starting to look like all the West Coast builds I follow went on hiatus or something
Unread 03-27-2012, 10:41 AM   #787
Ricochet88
Hahaha ya I haven't updated it lately I lifted it more I have like 5in in front and 6 out back hopefully it settles more. I got the iro 4.5in springs my other iro springs settled but it took awhile
Rick "woody"
Unread 03-27-2012, 10:59 AM   #788
squashman702
1994 ZJ
No sense in cutting up the floor. It's fairly straightforward to drop the tank, especially since I doubt you have to deal with much in terms of rust.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 03-27-2012, 01:17 PM   #789
Ricochet88
Exactly I don't have any rust whatsoever knock on my jeep
Rick "woody"
Unread 03-28-2012, 12:11 AM   #790
biebs53
I giggled
[CENTER][FONT="Franklin Gothic Medium"]1998 Jeep Grand Cherokee 5.9 Limited
Build thread: [url]http://www.jeepforum.com/forum/f197/project-raven-biebs53-build-thread-1215245/[/FONT][/url][/CENTER]
biebs53 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 08:34 PM   #791
Ricochet88
Long overdue for an update I have moved out so I've been busy I installed a set of iro 4.5in springs and they are really like 5-6 in springs lol. I finally did my disk brake swap they made a huge difference and I didn't put in my new master cylinder yet. The only thing I couldn't hook up is my ABS sensors I don't have the bracket that holds them the drum set doesn't fit. O ya and I got those fancy set of bilstien billet resi clamps
Rick "woody"
Unread 04-08-2012, 09:17 PM   #792
Ricochet88
More pics
Rick "woody"
Unread 04-08-2012, 09:47 PM   #793
GraKee99
Rapist Wit
GraKee99's Avatar
Send me your 7100s.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 09:51 PM   #794
311LJ
311Popo
311LJ's Avatar
Originally Posted by GraKee99
Send me your 7100s.
If he owes anyone shocks, may I remind u of GSW 2011 ha ha JK
John
04 TJ Unlimited, GenRight Armor, 37's Unlimited Build Thread
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY* WJ Build Thread
*UTAH JEEPCREW #01*
I ♡ John
311LJ is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 10:52 PM   #795
GraKee99
Rapist Wit
GraKee99's Avatar
I sent him bilstein 5100s.
Brian
WJ, WK, CJ5
