rescued 5.9 turned light wheeler/ product showcase - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > rescued 5.9 turned light wheeler/ product showcase
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l50% Off Sale at KrawlOff-Road.comTactical Recovery Equipment Soft Shackles!!!
Unread 02-03-2015, 02:41 PM   #1
FortCollinsZJ
Found a pair of 5.9's in a boneyard and bought both. A black and white. The white one had irreparable side damage, but the slate had only a buckled frame rail from the firewall forward, and a bad hood/fender and fascia.
I combined the frame rail from the white one to the black one, and managed to make it all one piece again. Sold off parts from the stone white and re-cooped all I spent on it. Ended up with a 900$ Niner plus headers, and a few other bolt-ons to pretty it up.
The plan is:
32" JK takeoff tires with Moab wheels: Check
WJ axles for added width. front: Check
Fender flares
Custom mid length arms for smoother ride, added flex, but retained on-road drivability.
WJ steering and brakes for more handling comfort: Check
Swing out tire carrier while retaining stock bumper cover.
I also want to use this for a mock-up vehicle for future parts I want to produce, and as a showcase for a few other parts.
Started with beautifying the engine and getting ready to drop it in after welding the new frame rail in:
Towed the white parts Jeep out of the way with the newly drivable Slate.
[/URL]
Getting the WJ axle all cleaned and welded for install.
[/URL]
Decided I needed a bumper.
[/URL]
[/URL]
Waiting on fender flares before I put these on (will be the anchor point for the rear tire carrier
[/URL]
Built a slick steering box brace with a bearing block for smooth steering.
[/URL]
[/URL]
Ordering parts this week to get started on the mid arm setup, that's when the real tech will start.
Offroad parts for your Jeep ZJ
www.mountainvistafabrication.com
FortCollinsZJ is offline   Reply With Quote Quick reply to this message
Unread 02-03-2015, 06:13 PM   #2
martymars
Awesome... Wish I was a handy guy...lol.. Ill check in for updates.
Need Jeep Parts?
info@gtajeep.com
martymars is offline   Reply With Quote Quick reply to this message
Unread 02-03-2015, 06:20 PM   #3
martymars
BTW, sick bumper. You design that?
Need Jeep Parts?
info@gtajeep.com
Unread 02-03-2015, 06:23 PM   #4
Killallblue
Looking good so far man
http://www.jeepforum.com/forum/f22/02-blue-wj-1808673/
Killallblue is offline   Reply With Quote Quick reply to this message
Unread 02-03-2015, 08:04 PM   #5
SnowLeopard
You're making me want to buy the thing when it's done. Though I suppose it won't be for sale.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 02-04-2015, 10:23 PM   #6
MurdaJs
Yes
Built one piece at a time, and it cost me many dimes
MurdaJs is online now   Reply With Quote Quick reply to this message
Unread 02-06-2015, 02:59 AM   #7
Timo_90xj
Timo_90xj's Avatar
Are you planning on keeping both front & rear as a 4 -link + panhard, or front as a 3-link (I see both upper link posts on the front axle)?
I've been thinking of using JK front & rear links because they are slightly longer than the ZJ/TJ arms, but short enough to be fairly easy to modify for use on the ZJ. Would need to do the 4-link calculations for correct anti-squat/ brake-dive/ pinion angle change etc., but I'm pretty sure it should come out better than OEM setup.
I'll be watching you!
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 03:13 AM   #8
thevanillaninja
Very nice. I've always loved the 5.9 Magnum. So much support and so receptive to mods. Looks like a great start to an awesome ZJ!
02 Overland
89 XJ 4.0/aw4/242
01 WR250 // 02 Suzuki 400 // 10 Pol 400HO
MK2 USCG, Kodiak, AK
thevanillaninja is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 11:47 AM   #9
jorhay
Nice showcase vehicle. Looking forward to those new front fenders.
jorhay is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 07:29 AM   #10
FortCollinsZJ
Working on trying to put my front links in today. Wish me luck. Hope it all goes smoothly.
Unread 02-14-2015, 06:45 PM   #11
martymars
How much for the bumper and the gaurds?
Need Jeep Parts?
info@gtajeep.com
Unread 03-20-2015, 10:02 AM   #12
FortCollinsZJ
Got my four link mid arms in, rides like a Cadillac up front now. Got my bushwhackers mounted too. Still need to swap the rear WJ axle in for the extra width. I'm beginning to LOVE driving this thing now!
Unread 03-21-2015, 04:51 PM   #13
martymars
Going to need some spacers.
Need Jeep Parts?
info@gtajeep.com
Unread 03-23-2015, 09:41 AM   #14
Timo_90xj
Timo_90xj's Avatar
Why?
He's installing a WJ rear axle as well, which will push the rear tires out by about 2" per side. WJ WMS-WMS width is about 4" wider than ZJ WMS-WMS.
Unread 03-24-2015, 03:58 PM   #15
DrGrand
2003 WJ
Those rear corner guards are awesome! I wouldn't mind seeing a set for a WJ!
03 WJ, 7.25", Custom LAs, 35s, Spooled HP44, Locked D60, 5.13s
DrGrand is offline   Reply With Quote Quick reply to this message
