RedZJ Super Slow Build Thread - Page 2 - JeepForum.com
post #16 of 598 Old 01-16-2011, 03:49 PM
sadass
why? Are you guys speaking in code. Having a hard time following that last couple of posts. anyhow, Do you need sway bar links because your lift did not come with them. I have some JKS quicker discos for the ZJ that I am looking to sell might be a better option for you.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #17 of 598 Old 01-16-2011, 10:48 PM Thread Starter
RedZJ
Id rather have the JKS Quicker, but money is tight and jeep has to be ready to roll by Feb 10th. I go on vacation. So I am going cheap on a few things right now.
RedZJ is offline
post #18 of 598 Old 01-17-2011, 01:56 PM
Flat_Black_ZJ
Hey man have you been able to get any measurements on the snorkel set-up yet for me?
Flat_Black_ZJ is offline
post #19 of 598 Old 01-17-2011, 01:57 PM
Flat_Black_ZJ
How much are you asking for the disco's?
post #20 of 598 Old 01-17-2011, 02:48 PM
sadass
PM sent
sadass is offline
post #21 of 598 Old 01-18-2011, 12:16 AM Thread Starter
RedZJ
Sorry I was super busy today. Ill try tomorrow.
RedZJ is offline
post #22 of 598 Old 01-18-2011, 09:25 PM
Flat_Black_ZJ
Ok thanks man
post #23 of 598 Old 01-21-2011, 12:09 AM Thread Starter
RedZJ
Flat black, I didn't forget about you. I've been super busy with work. Today was the first time I got to even look at the jeep and that ended up being a mess.
Put my 3.5 inch lift on it.
Just when we were putting the control arms on thefront... It hit me. I forgot to order the trac bar. Lol.
Had to take the lift off and put all the stock **** back on.
RedZJ is offline
post #24 of 598 Old 01-21-2011, 01:37 PM
Flat_Black_ZJ
Ok just whenever man
post #25 of 598 Old 01-21-2011, 07:23 PM Thread Starter
RedZJ
Do u have any info on what you used to build the snorkel?
ok.. I guess I am working from the top down
All pipe pieces will be INCHES.
90 Degree
2inch
90degree
2inch
45Degree
32inch
45Degree
26inch
45 Degree
7inch
90 Degree
into a 3inch hole.
Coming from the hole to the air box..
3 1/3 inch
45 Degree
2 1/2 inch
45degree
Red Rubber piece I got from pep boys.
Towards the middle of the box youll see I attached the one hose.. I used an air hose fitting, Silicone.
http://www.factorydirecthose.com/sit...duct/6PUR-4RMP
Air Box is out of a ford win star. If you do it, use one out of a Ford F150. Bigger box.
I know, I am bad at write ups. If you need me to clear anything up for you just ask.
RedZJ is offline
post #26 of 598 Old 01-22-2011, 08:30 AM
Flat_Black_ZJ
Thanks man thats a big help now when it warms up i am ging to try to do this to mine. Is it sealed pretty good
post #27 of 598 Old 01-23-2011, 03:42 AM Thread Starter
RedZJ
It stalls the jeep when I cover the snorkel.
if you need help I'll be living in nc, I can swing by and knock it out in a few hours.
RedZJ is offline
post #28 of 598 Old 01-24-2011, 12:31 AM Thread Starter
RedZJ
Just picked this up. Putting it in once my IRO adjustable s come in.
high pinion Dana 30 out of a 1990 Jeep cherokee. It has a clayton high clearance axle bracket kit installed by A to Z fabrication, ruff stuff diff cover, new wheel bearings, new brake pads, 3.55 gears, open, knuckles drilled to 3/4" to run heim joints or tie rod flip kits.
RedZJ is offline
post #29 of 598 Old 01-24-2011, 07:33 AM
Flat_Black_ZJ
Hey man can you tell me whats the advantage of runnin the hp30 set-up?
post #30 of 598 Old 01-24-2011, 08:32 AM Thread Starter
RedZJ
Here are some threads I read. Can prob. explain a few things better then me.
http://www.jeepforum.com/forum/f9/hp...a-30-a-602784/
RedZJ is offline
NarnWV's super slow build thread narnwv Grand Cherokee General Discussion 762 01-23-2016 10:01 PM
lateralus3's slow build thread lateralus3 Grand Cherokee General Discussion 746 01-30-2014 05:13 AM
My slow zj build Erbo1Kanerbo Grand Cherokee General Discussion 564 05-10-2013 08:46 AM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
99wjlaredo's Slow 99' WJ Build 99wjlaredo Grand Cherokee General Discussion 18 08-03-2010 10:18 AM
