Read this! I need your input! :) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Read this! I need your input! :)
Rough Country Jeep Suspension Deals at Rockridge 4WD!JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 02-03-2015, 01:08 PM   #1
mgilbert11
Hi all ---
If you have a couple minutes to spare, could you take this survey I've created about Jeep's brand?
I am doing some marketing research and it would greatly help me understand where Jeep is heading.
Thanks in advance! Feel free to share the link as well.
Link:www.surveymonkey.com/s/MCB7H3Z
mgilbert11 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2015, 06:57 AM   #2
mjb1032
That was easy!
mjb1032 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2015, 11:23 AM   #3
veiri86
veiri86's Avatar
2003 WJ
Done!!
Sent from ME
R.I.P ratmonkey
Build thread: http://www.jeepforum.com/forum/f197/...x-wjs-1872002/
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2015, 04:38 PM   #4
Jeep32
Done yesterday (I think) !!
"so i did a full tune up soup to nutts."
4.7 210k+
Jeep32 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 12:29 PM   #5
Mattyjm
Nailed it!
Whisper to my friend..."I see Jeoples.....I see them ALL the time!"
Mattyjm is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 12:45 PM   #6
mgilbert11
Hell yeah! Thanks guys!
