ratmonkey's build. In progress: 3/4 ton and 37's - Page 41 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ratmonkey's build. In progress: 3/4 ton and 37's
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 03-31-2013, 04:40 PM   #601
MStaffin
Originally Posted by ratmonkey View Post
i hate rust. all 8 manifold bolts are broken off in the head after trying to pull the exhaust manifold. at least four of them have studs long enough to grip. only one promises to be a total pain. it's the reason it was leaking in the first place. the bolt actually completely rusted through and is rusted into the head.
I pulled my motor to do the mani. I was worried about busting bolts. Made life easier
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 08:53 PM   #602
ratmonkey
R.I.P.
ratmonkey's Avatar
welded nuts to the ones that broke flush. made life a lot easier. don't feel like pulling a 1000lb motor for this job. the bolts on the passenger manifold are almost rusted through as well. i'll be doing that when the weather turns i believe.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 09:11 PM   #603
MStaffin
Mine had a bad trans so it wasnt much more work when I did it. Dumped 1000$ into myself rebuilding trans and motor parts
Unread 04-02-2013, 08:08 PM   #604
ratmonkey
R.I.P.
ratmonkey's Avatar
cheap dorman(chinese) manifold cracked when torquing it down. 45ftlbs should not crack cast iron. damn chinese can't make any metals. even the simplest ones the freaking middle age europeans knew how to make.
i still refuse to pay 500$ for the oem manifold though.
Unread 04-02-2013, 08:11 PM   #605
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I split a 3" galvanized nail lengthwise yesterday at work. Id never seen that before. Metal made in China with pride.
Sent from my iPhone 6 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 07:16 PM   #606
BuzzZJ9er
Gas tank clearance.
Steering
Track bar bracket tacked in place(finished welded now)
Pittman arm needs changed to a 7" variety
Then final angle/position for the track bar can be set.
It is very tight with such a low lift, but I built with the intention of having 4" or less up travel.
Almost 9" of down travel in the front before the coils unseat.
Excuse my lack of knowledge but what is that red rubber boot in the middle of your coil?
BuzzZJ9er is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 08:07 PM   #607
ratmonkey
R.I.P.
ratmonkey's Avatar
Prothane makes a custom cut to length coil spring insert that works as Jounce bumpers. Not the most economical solution but very comfortable on road and they keep the tires out of the fenders off road when set right.
Unread 05-22-2013, 08:24 PM   #608
BuzzZJ9er
Is a jounce bumper kinda like a shock/progressive bump stop? Sorry again!
I don't know a lot but love to learn all I can!
Unread 05-22-2013, 10:10 PM   #609
ratmonkey
R.I.P.
ratmonkey's Avatar
Jounce bumper= bump stop
Unread 05-27-2013, 06:59 AM   #610
mike_breaker_5
R.I.P. buddy.
Ratmonkey donation page. all proceeds will go to his family.
[URL="http://www.youcaring.com/memorial-fundraiser/our-friend-tyler-is-at-rest-/65052?utm_source=widget"]http://www.youcaring.com/memorial-fundraiser/our-friend-tyler-is-at-rest-/65052?utm_source=widget[/URL]
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
[URL="http://www.jeepforum.com/forum/f22/military-94-yj-now-more-tons-hummer-junk-990191/"]http://www.jeepforum.com/forum/f22/military-94-yj-now-more-tons-hummer-junk-990191/[/URL]
mike_breaker_5 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 07:27 AM   #611
PurpleZJ
Originally Posted by mike_breaker_5
R.I.P. buddy.
Whatttttt?!
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
PurpleZJ is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 09:24 AM   #612
OverlandZJ
Originally Posted by mike_breaker_5 View Post
R.I.P. buddy.
OverlandZJ is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 01:03 PM   #613
mike_breaker_5
we lost a great forum member, a great source of good jeep knowledge, and above all my best friend in a car accident last night. i plan to start a memorial thread here on JF for him. i am still almost in denial that it's true. sad thing is this is the first place i went, i just wanted to see his pics and read his words.
Unread 05-27-2013, 01:19 PM   #614
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Wow. I don't even have words. I never met ratmonkey in real life but he helped me more than anybody else on JF. What a huge loss.
Unread 05-27-2013, 02:05 PM   #615
PurpleZJ
RIP man, I didn't know you personally but I enjoyed the knowledge you had to offer.
[/CENTER]
