ratmonkey's build. In progress: 3/4 ton and 37's - Page 40 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ratmonkey's build. In progress: 3/4 ton and 37's
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 03-06-2013, 12:19 AM   #586
sdmayhew
Can you talk more about e drop Pittman arm? I am noodling on going to 6 or 7 inch springs and 35's in a couple months and would need to drop my Pittman arm
I already have over 12 of Travel at the shock
1993 ZJ Clayton long arms with Johnny joints, custom front axle W yota center, D44 chevy outers, fabtech dirtlogic 2.25, front bilsten rear shocks, tacoma rear axle, 4.88, arb rear, 5 speed, poly motor mount inserts, NP241OR 4-1 ,receiver front for xcr 8k winch
sdmayhew is offline   Reply With Quote Quick reply to this message
Unread 03-06-2013, 08:11 AM   #587
ratmonkey
R.I.P.
ratmonkey's Avatar
It's actually about 3" lesss than stock. My arm is almost flat now.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 03-06-2013, 10:58 AM   #588
bananaslug
I would like to do the ABS delete to open up space under the hood. Is this a good thread in your opinion?
http://mallcrawlin.com/forum/showthr...-System-Delete
bananaslug is offline   Reply With Quote Quick reply to this message
Unread 03-06-2013, 03:01 PM   #589
ratmonkey
R.I.P.
ratmonkey's Avatar
yep, that write up works
Unread 03-06-2013, 03:03 PM   #590
mike_breaker_5
i read that thread and laughed harder than when i watched this. . .
gravel guard apparently cools your brake lines. that guys mouth and this hippo's butt have something in common.
Ratmonkey donation page. all proceeds will go to his family.
[URL="http://www.youcaring.com/memorial-fundraiser/our-friend-tyler-is-at-rest-/65052?utm_source=widget"]http://www.youcaring.com/memorial-fundraiser/our-friend-tyler-is-at-rest-/65052?utm_source=widget[/URL]
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
[URL="http://www.jeepforum.com/forum/f22/military-94-yj-now-more-tons-hummer-junk-990191/"]http://www.jeepforum.com/forum/f22/military-94-yj-now-more-tons-hummer-junk-990191/[/URL]
mike_breaker_5 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2013, 03:25 PM   #591
ratmonkey
R.I.P.
ratmonkey's Avatar
http://www.youtube.com/watch?v=XTUFSVYFUTE
it's like this guy was giving advice on brakes.
http://www.youtube.com/watch?v=WkCxXErb2Ag
Unread 03-07-2013, 12:25 AM   #592
sdmayhew
Cool. Looking at your picture again I realized your on high steer arms. Which I could also do real easy with my d44 knuckles by swapping the one out.
Mine has abs removed when po went to different axles. Not that much of a difference not having abs.
Unread 03-08-2013, 05:53 PM   #593
daddyjeep87
1987 YJ Wrangler
I didnt read the thread that you mentioned, but I laughed like hell at the video.
You live in Emporium? you need to come over and help me build my Jeep. I am in Smethport.
daddyjeep87 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 01:30 AM   #594
ratmonkey
R.I.P.
ratmonkey's Avatar
well, after wrecking my car i've decided to buy a truck.
picking up a 1997 f250 hd. regular cab, 7.3 powerstroke, 5 speed manual trans, 8800# axles. it's a little beat on, but i think i can make it a decent hauler and driver.
Unread 03-23-2013, 01:30 PM   #595
MStaffin
Not bad. I hate mine. Its a turd. Pulls anything but just no power. How many miles on yours?
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 02:53 PM   #596
ratmonkey
R.I.P.
ratmonkey's Avatar
Yeah, my step father had a 96 power stroke auto, it was a dog but you could load that sucker up like no ones business.
The manual seems a bit snappier.
Definitely needs some tlc. 25x,xxx on it.
Needs an exhaust manifold
Needs a major cleaning of the engine bay. Theres a slight leak in the valley from something.
Tank switch or sending unit in the rear tank went and the guy never fixed it.
Needs an interior update, fogged headlights replaced, front fenders, etc.
The usual junk on a work truck.
It'll probably get some h2 wheels and 10ply a/t tires in a 33-35" flavor
I'll likely do the exhaust, intake, and fmic, possibly a different turbo.
Got it at half low blue book private value.
Unread 03-23-2013, 04:07 PM   #597
nickpequignot
My boss has a 2000 power stroke. And It was a dog stock. He threw some injectors and a upgraded turbo wheel and custom tunes on it and it will put you back in the seat now.
nickpequignot is offline   Reply With Quote Quick reply to this message
Unread 03-28-2013, 09:27 AM   #598
MStaffin
Im now buying a 99 cummins 5spd. Thing is a monster. Hope guy takes my offer. Has 125xxx all stock minus the 4" exhaust.
Unread 03-28-2013, 10:43 AM   #599
ratmonkey
R.I.P.
ratmonkey's Avatar
I'll be getting the leaky manifold done Friday I'd the weather isn't too terrible. New manifold and I'll prep it for an egt probe and ceramic coat it for some rust prevention.
The manifold on it now is literally rusted through.
Hope it doesn't need up pipes just yet.
Got a rebuild kit for all the fuel related items under the hood on the way.
I'll pull the high pressure oil pump and throw some gaskets and o rings at it to make sure its in good order. They're kind of expensive to get remanufactured.
I'll be inspecting the turbo wheel too. The upgraded wheel most commonly used in the 99+ Garrett turbo is the wheel from the 94.5-98 Garrett turbo.
I've got a 6637 intake kit on the way
Needs new batteries
Going to swap to super duty 40/20/40 heated leather seats
Going to throw in real carpet
Power window/lock doors from an xlt/lariat
New headlights
New front fenders
Fix rear fuel tank/tank switch .
Get a CD player in it.
Probably do an injector rebuild or upgrade with a good tune. I'll do the turbo back exhaust if it's too rusted, otherwise I'll leave it alone for now.
Unread 03-29-2013, 07:50 PM   #600
ratmonkey
R.I.P.
ratmonkey's Avatar
i hate rust. all 8 manifold bolts are broken off in the head after trying to pull the exhaust manifold. at least four of them have studs long enough to grip. only one promises to be a total pain. it's the reason it was leaking in the first place. the bolt actually completely rusted through and is rusted into the head.
