ratmonkey's build. In progress: 3/4 ton and 37's - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ratmonkey's build. In progress: 3/4 ton and 37's
ROCKRIDGE 4WD Newsletter about to hit your Inbox! Just in FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 08-26-2010, 08:17 PM   #241
PaLftr
Also interested in old headlights...Could pick up in Erie. lol
ZJ DD, WW. 4.go litre modded. 3", 31's. Needs armor.
PaLftr is offline   Reply With Quote Quick reply to this message
Unread 08-26-2010, 10:07 PM   #242
squashman702
1994 ZJ
Sent you a PM back about the headlights, just need to know where to send the cash.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2010, 07:58 AM   #243
rugermack
Everybody wants the old headlights.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
rugermack is offline   Reply With Quote Quick reply to this message
Unread 08-27-2010, 10:30 PM   #244
ratmonkey
R.I.P.
ratmonkey's Avatar
I know right?
Headlights are spoken for. Got to get rid of the corners and turn signals.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 08-28-2010, 07:36 AM   #245
rugermack
I'd be interested in the corners, What's the cost shipped to 85641 ?
Unread 08-28-2010, 08:30 AM   #246
squashman702
1994 ZJ
Paypal sent for the lights.
Think Twice Garage
Unread 08-28-2010, 08:41 AM   #247
rugermack
Did you buy all the lights ?
Unread 08-28-2010, 10:10 AM   #248
jeepguy98
Now if they only made MKIII Range Rover style tail lights I'd get the whole set
97 JGC Limited 5.2L, Black/Black, NP242 swap, D44a with LSD, 3.73 Gears, 2" IRO lift, Zone Nitro shocks, BFG KO's, Doug Thorley Headers, Magnaflow High Flow Cat, Flowmaster Super 44, Custom Tail Pipe, 5.9 E-Fan Conversion, SCT Tune by Sean, K&N FIPK, Amsoil filter/Pre-filter, MSD 6AL Ignition Box, Blaster SS Coil, Alpine Type-S speakers, Alpine 500W Amp, 10" Kicker CVR, Receiver Shackle, Custom Dash Bezel
jeepguy98 is offline   Reply With Quote Quick reply to this message
Unread 08-28-2010, 11:09 AM   #249
ratmonkey
R.I.P.
ratmonkey's Avatar
anyone need a rear addco sway bar?
how about some rubicon express short arms?
jks rear track bar?
need to fund the tnt front brackets and truss and sniper fab rear brackets for my 3/4 ton swap.
Unread 08-28-2010, 11:15 AM   #250
Spike300
Pm sent for sway bar
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 08-28-2010, 11:19 AM   #251
ratmonkey
R.I.P.
ratmonkey's Avatar
lets not go too far in turning this into a sale thread. just pm me, no need to post about it.
back on topic a little. i wrapped my exhaust today. trying to figure out the best way to get bolts in every hole on the stinkin things. a couple of the holes are nearly impossible to get a bolt into and then harder than heck to get a tool on the fastener when you do manage to put one in. REALLY bad design on hedman's part. can't wait to get around to sectioning the frame and firewall to put real long tubes on the beast. eventually i'm gonna end up making a tube sub frame for the front. the ideas never end.
Unread 08-28-2010, 09:19 PM   #252
BLACKzj52
rat, those look pretty good actually. can you post any pics of the beam pattern?
My Build Thead
Facebook
BLACKzj52 is offline   Reply With Quote Quick reply to this message
Unread 08-28-2010, 10:23 PM   #253
ratmonkey
R.I.P.
ratmonkey's Avatar
it'll have to wait till after i get a new header panel. the adjusters stripped out on me and it was solid enough to support the stock lights, but too cracked for these ones.
Unread 08-29-2010, 05:39 PM   #254
BLACKzj52
alright sounds good man. thanks
My Build Thead
Facebook
Unread 08-30-2010, 07:18 AM   #255
LordHobbit
Good build up. Subscribe.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline   Reply With Quote Quick reply to this message
