ratmonkey's build. In progress: 3/4 ton and 37's - Page 16 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ratmonkey's build. In progress: 3/4 ton and 37's
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-20-2010, 05:36 PM   #226
ratmonkey
R.I.P.
ratmonkey's Avatar
got my "new" ecu today. still no communication to the bcm. got ahold of a ram fsm and i know why now. the send and receive pins for the ccd bus are reversed in a ram vs a jeep apparently.
sci send and sci transmit pin 27 and 29 on the gray jeep connector and flipped on the same ram connector. all other pins are exactly the same.
i did not expect this as others have stated it is a direct swap with no wiring needed.
scratch that, still no signal to the gauge cluster. time to find someone who's done ecu rewiring before i guess. i can't find ANY differences in the pinouts other than this.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 06:54 AM   #227
ratmonkey
R.I.P.
ratmonkey's Avatar
truckviva.com projector housing install.
this install is very easy and went off without a hitch really.
the product as it came
well packaged in bubble wrap and bagged expanding foam. lens is also covered with cling wrap to prevent scratching.
build quality appears excellent.
the victim, ebay clear housings and converted over to early zj 8 slot grille.
pull your old housings. there's four screws for the markers one top and one between the lenses for the side marker/reflector. two on the outer edge of the lower marker/signal. simple job so i didn't take any pictures. the headlight just pulls straight out with a bit of grunt.
upper side marker, the halo lights plug into this guy.
turn signal, blackjoe states his 98 had a two prong turn signal. my 97 has the 3 prong style.
back of the housing.
plug in your halo lights here.
everybody in their sockets.
line up the tabs and push the housing on firmly. it'll take a bit but it will snap right into place. you MAY need to extend the adjusters out so that you can more easily line things up and push on it.
and you're done. unwrap to finish took me about 15mins even with taking pictures and i wasn't in any kind of hurry.
here's the halo's on.
i noticed my vertical adjuster is stripped so i'll need to replace that before i can get proper pattern shots at night.
they seem to be solidly locked into the headlight hardware, though i would like some lower support or something. it is a lot of weight to hang off those three posts.
Unread 08-25-2010, 07:22 AM   #228
rugermack
Looks good, can't get the picture to enlarge on my work computer.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
rugermack is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 07:36 AM   #229
ratmonkey
R.I.P.
ratmonkey's Avatar
i posted the thumbnails for faster loading of the thread.
photobucket is probably on the banned list for your websense/censor program.
Unread 08-25-2010, 07:39 AM   #230
squashman702
1994 ZJ
Is there anything wrong with your old clear housings? If not, can you PM me a price?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 07:54 AM   #231
rugermack
Dam goverment computers.
Unread 08-25-2010, 09:13 AM   #232
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Originally Posted by ratmonkey View Post
can you grab and post a similar shot to this with your new headlights?
We have the same bumpers, so I'll get an excellent visual aid...
Also, it seems that the gaps lined up pretty good on your installation... I am glad.
I will be ordering as soon as I get home from this trip.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
SpeedyCat3 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 09:57 AM   #233
ratmonkey
R.I.P.
ratmonkey's Avatar
adjusters on both sides are stripped now it was also a slightly cracked salvage yard freebie header panel that now can't support these housings as well as needed(got a perfect shape header panel at a friend's house from a part out)
they stick out the same/less than the crystal ebay housings.
Unread 08-25-2010, 02:10 PM   #234
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I like them.
Seems like the fit is pretty good considering that they are all in one piece and it needs to pivot some for aiming.
I will probably be using a compressible foam insert to bridge the gap and that is it if needed.
They give a "LandRoveresque" look to the fron now, lol.
Thanks for the pics and installation instructions.
Our set ups will be very similar, though I am installing IRO long arms, and my axles will be an HPD44 from a Super Cab (F250 tubes in diameter and wall but 5 on 5.5 bolt pattern) with Ford Thunderbird brakes; and a rear 9 inch with Lincoln Versailles disc brake conversion; all on 4.56 gears. I will use a set of 35x16.50.15 swamper boggers for offroad and will probably get TA/KO's on 35 flavor for the street .
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
Unread 08-25-2010, 03:55 PM   #235
redfoxbody
Are you going to put hid lights in the new housings?
That would really be a thread killer for all hid arguments
4.0 [B][COLOR="Red"]2x4>4x4 conversion[/COLOR][/B] 3.73, rubicon rims, 245/75R16 mtr [B][COLOR="red"]42RE > AX-15[/COLOR][/B] Conversion in progress. [COLOR="Black"][/COLOR]
[CENTER]Build thread[/CENTER]
[CENTER][url]http://www.jeepforum.com/forum/f197/redfoxbody-jeep-build-979752/[/url][/CENTER]
[SIZE="5"][COLOR="White"][CENTER]Depressed about your car dent? dentszone.com[/CENTER] [/COLOR][/SIZE]
[QUOTE=]Nice the legs in that last picture, almost makes you not think about the jeep.[/QUOTE]
[QUOTE=]My 16 year old little sister, you creep.[/QUOTE]
redfoxbody is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 08:56 PM   #236
country_boy454
They look better than I thought they would! Nice to know. Now I have another part to save up for!
1996 XJ 6.5" Rusty's, 34" LTB's, 220 amp alt, #1 wire upgrade, 4.0, AW4, NP231 NON SYE, CB 1996 ZJ Plum Broke Limited 5.2, SCT Tuned, Dual exhaust, CAI, Audivox Prestige APS997a alarm, Performance Distributors Ignition Upgrade, KOR BB + Up Country Springs, 52mm TB, 24lb/hr Ford Racing Injectors Plum Broke Build thread
country_boy454 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2010, 09:56 PM   #237
ratmonkey
R.I.P.
ratmonkey's Avatar
I won't be using hid's in my housings. Halogen projectors don't have the best beam pattern for it. I would consider it in the high beams only, you're not supposed to use them with traffic around anyway.
Unread 08-26-2010, 02:39 PM   #238
truckviva
thank you ratmonkey for the pictures, can you also take some pictures for the night view with the halo ring on?
Phone: 1-800-382-8869
[url][URL="http://truckviva.com/1993-1998-Jeep-Grand-Cherokee.html"]http://truckviva.com/[/URL][/url]
[URL="http://truckviva.com/1993-1998-Jeep-Grand-Cherokee.html"]http://truckviva.com/1993-1998-Jeep-Grand-Cherokee-Projector-Headlights.html[/URL]
[SIGPIC][/SIGPIC]
truckviva is offline   Reply With Quote Quick reply to this message
Unread 08-26-2010, 07:33 PM   #239
YERFDOG
Curious to what your gonna do with your old Clear headlights and corners
PM me if your interested in selling.
Eric
*1998 Jeep Grand Cherokee 5.9 Limited*
http://www.jeepforum.com/forum/f197/yerfdog-s-white-5-9-build-picture-thread-1087847/
YERFDOG is offline   Reply With Quote Quick reply to this message
Unread 08-26-2010, 09:03 PM   #240
19onebadzj96
interested in the old headlights please
19onebadzj96 is offline   Reply With Quote Quick reply to this message
