ratmonkey's build. In progress: 3/4 ton and 37's - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ratmonkey's build. In progress: 3/4 ton and 37's
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-12-2010, 02:58 PM   #196
ratmonkey
R.I.P.
ratmonkey's Avatar
i'm gonna go with a set of boggers in a 35" flavor for wheeling. keep my 32" bfg at's for when i need to do much street running that isn't winter. i have a summer toy car i drive that gets much better mileage than the heep. even though the 5spd helped out a LOT with fuel consumption.
i'm probably just going to polish an hp30 front to hold up to the 35's and v8. rcv's, truss, wj brakes, elocker.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 05:19 PM   #197
solomon8718
Yeah, I'm kinda in that boat deciding on tires too. I'm thinking 32's with my UC+bb setup, but I'm not sure on tire make yet. I'm not big on km2's, all I see in the threads reguarding them is mediocrity.
Did you have a certain kind in mind?
solomon8718 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 11:56 PM   #198
squashman702
1994 ZJ
Boggers? I thought there were a lot of rocks in PA? I haven't heard many positive things about boggers in the rocks, but I also haven't wheeled with anyone that was running them in that situation.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2010, 05:10 PM   #199
CTeunuch
They're terrible in the rocks, they have basically zero lateral traction. I've seen tons of rigs lose a line, and a few almost rolls, because of boggers. But if you're just mudding they're tits.
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
Unread 07-14-2010, 10:44 PM   #200
PaLftr
For PA kind of wheeling MTR w/ Kevlar are perfect.
So RM...You live in Erie? Do you know any shop or person where I could get the welding done on my Jeep? There's honestly nowhere where i live...it ****in sucks.
ZJ DD, WW. 4.go litre modded. 3", 31's. Needs armor.
PaLftr is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 08:28 AM   #201
ratmonkey
R.I.P.
ratmonkey's Avatar
i seem to be missing something. while something else has appeared from nowhere.
palftr, i've done all my own welding and one of my friends does a lot and purchased a 1400$ lincoln mig set up last year(i'm using his older 220 lincoln wire feed).
he does a lot of side work, what all do you need done and where are you? (pm if you want)
Unread 07-30-2010, 02:00 PM   #202
ratmonkey
R.I.P.
ratmonkey's Avatar
Finally got it out for a spin round the block(first time in a long long time). I'm definitely going to need a rear sway bar. Wow does the claytons kit roll around corners.
i'll be mounting a tj sway bar to the rear axle like some others have.
Had a stuttering and stalling issue when i'd attempt to move forward before taking her out. Figured since reverse was ok that it may be a wire issue. Checked grounds and the coil harness, then discovered that the harness for the ckp got wedged between the trans and the body. Every time the motor would torque over going forward it squeezed the connector and caused it to lose contact. Next time i drop the crossmember i'll pay better attention to it.
Unread 07-30-2010, 03:34 PM   #203
squashman702
1994 ZJ
What about an Explorer rear bar? They're 7/8th's and mount to the axle instead of the body.
Think Twice Garage
Unread 07-30-2010, 09:52 PM   #204
Spike300
NIce covers theres a set of them in the junkyard i go to hopefully ill finally get them since we have a few days off of work
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2010, 12:21 PM   #205
ratmonkey
R.I.P.
ratmonkey's Avatar
exploder bar mounts behind and the shock mounts are in the way there. i bought a full traction tj bar out of the classifieds here.
Unread 08-04-2010, 07:37 PM   #206
ratmonkey
R.I.P.
ratmonkey's Avatar
Got my engine compartment all but done now. New wires, valve covers, ac delete, wrapped fuel rails, got header wrap and heat sleeves for the coolant hoses on the way.
Unread 08-04-2010, 10:00 PM   #207
CTeunuch
I'd recommend against header wraps if you're going to wheel, they'll trap all the moisture and rot them out.
Think Twice Garage
Unread 08-04-2010, 10:26 PM   #208
ratmonkey
R.I.P.
ratmonkey's Avatar
Thats what the dei header wrap sealant is for.
Unread 08-05-2010, 08:49 AM   #209
rugermack
I like the valve covers.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
rugermack is offline   Reply With Quote Quick reply to this message
Unread 08-05-2010, 09:49 AM   #210
solomon8718
Originally Posted by rugermack View Post
i like the valve covers.
+1
