ratmonkey's build. In progress: 3/4 ton and 37's - Page 6 - JeepForum.com
post #76 of 731 Old 08-19-2009, 08:07 PM
jeep360limited
post a video of you driving around...that thing is so sweet
Charlie
2003 Ford Ranger Edge
1986 Jeep CJ7
1998 Jeep Grand Cherokee 5.9 Limited-----SOLD
jeep360limited is offline
post #77 of 731 Old 08-26-2009, 08:33 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
local shop, once again that comes highly recommended, wanted 275 to whack an inch off of my front driveshaft.
i felt that was totally unreasonable so i made a jig to keep the tube straight and cut and welded it myself. gonna test drive it in a few to see if there's any vibes, i think there's gonna be though due to the angle the tcase is sitting at. i need to raise it about an inch to an inch and a half. oddly there's no rear driveline vibes with the angle altered like that.
since i can raise it that much more i'll be nearly able to do a flat belly pan. score!
ratmonkey is offline
post #78 of 731 Old 08-27-2009, 05:15 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
closer...
post #79 of 731 Old 08-27-2009, 08:50 AM
spife7980
wow! i havent been back in here since the first post however long ago. i cant believe ive been missing all his! amazing wok so far, i wish i was confident enough to undertake something like this. mad props man.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #80 of 731 Old 08-28-2009, 04:43 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
finally got around to inspecting my rear axle well. it's toasted. i guess hitting a curb, blowing a u-joint at 75mph, and catching air on a few jumps did it in. lol.
bad pinion bearings(from the ujoint going out at high speed), bad carrier bearings(common), and bent tubes(curb and ramping). so picked up an 8.8, getting tnt to do me a truss and mounts, and it'll go in soon. so motor is on hold again. lol.
i have a nearly brand new pass side axle shaft, pass side and driver's side axle shafts that'll be good for trail spares or possible replacements. moderate amounts of wear on the bearing surfaces and they don't appear to be bent. will check run out if there's interest in buying them. and a used aussie with less than 15k on it.
75/ axle shaft and 200 for the aussie if you want 'em. the aussie shows little to no signs of wear and was installed to the tight side of in spec. doesn't pop and engages correctly every time.
post #81 of 731 Old 09-02-2009, 07:06 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
got the mounts cleaned off and the rust sanded down on the 8.8. i wanted to get one with an open carrier so i could throw an aussie in there, there was no tag on the diff and the yard assured me it was 3.73 open, well it's 3.73 lsd...i guess i'll check the clutch pack out and wheel that if it's still in good shape. i'll check out the svt rebuild kit for it, if that's a good price i'll just go that route if needed. otherwise i'm gonna start looking into selectable lockers for next year.
i've decided to also build a clayton's style rear long arm for it since i've got to put new tabs on the axle anyways. now, hopefully i can keep up with the overtime at work so i can afford to finish this quickly.
post #82 of 731 Old 09-08-2009, 01:57 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Tore everything but the pinion out if the 8.8...the carrier bearings are galled beyond belief. One outer race appears to have spun. The wheel bearings and seals are shot. Shaft bearing surfaces show visible wear, but only mics out to .0045". The lsd...well it broke two clutch plate tabs off at some point at least 5k before they parked it. Spider gears are marked up, but not chunked so that's good. The ring and pinion are in excellent shape with a very light and correct wear pattern. Backlash was still on the tight side before I pulled the carrier out.
Suspension. After pricing out materials and factoring in my labor time. I'm just buying claytons with the high clearance axle bracket kit. Their fab time and profit comes out to less than I'd make in the time it would take me to fab the same system. Given that we pay the same for steel.
When it comes time for the front of my jeep claytons may not be the prime choice due to my atypical drivetrain. There are better price points out there for the front, claytons are hard to beat on the back side though.
post #83 of 731 Old 09-10-2009, 06:23 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
ordered back half of my claytons today.
post #84 of 731 Old 10-19-2009, 12:18 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Project took a break so I could purchase a newer second vehicle 2003 eclipse spyder gts.
Gotta do a clutch in that soon and it'll be a done deal. 'till the modding bug bites on that of course. The power is adequate and the mileage us good, but it sure isn't a v8.
Finally got my welder set up and ready to squirt some wire. Clayton's long arms will start going on this week as weather and time allows. I still haven't decided what I'm going to do for a traction aid in the rear. Ox and arb lockers are tempting. But a rebuilt lsd is cheaper.
With the nice daily driver i'm leaning towards making the grand a little less on road friendly now.
post #85 of 731 Old 10-19-2009, 03:47 AM
sadass
PM sent! 12345
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #86 of 731 Old 10-19-2009, 06:37 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
welded up everything but the lower control arm mounts this afternoon on the axle.
never mind the work area, i have very limited space at my house.
post #87 of 731 Old 10-20-2009, 04:33 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
ran out of wire tonight. got the lower control arm mounts on and tacked the coil buckets in place.
post #88 of 731 Old 10-20-2009, 08:46 PM
charles81076
where do you find the time?
charles81076 is offline
post #89 of 731 Old 10-21-2009, 11:56 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
A few hours here and there really adds up.
The time has come to decide upon a locker to put in the 8.8. Anyone care to offer some opinions? Selections on 4wd and qt are actually really slim for such a popular jeep swap.
post #90 of 731 Old 10-22-2009, 02:27 AM
j.love
j.love's Avatar
1994 ZJ
You are a mad man!
I never come over here to the general discussion side.. look what I missed!
Now I feel lazy for not having my motor in yet.
Slow down so I don't feel so bad about myself will ya!
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
Post pics of your wrangler in use during the upcoming storm 1/31/11 Krochus Wrangler General Discussion 64 02-05-2011 01:32 PM
keep the 37's or go bigger?? highrolrcustoms Wrangler General Discussion 19 08-21-2010 01:00 PM
37's on the 'dub..... CaribouLouWJ Grand Cherokee General Discussion 108 03-31-2010 07:47 PM
Upcoming Mods!! njrealtor55 ZJ Grand Cherokee Forum 9 08-31-2005 09:14 PM
Need tires in the upcoming months, Size recomendations? spankey ZJ Grand Cherokee Forum 17 08-20-2004 09:00 AM
