ratmonkey's build. In progress: 3/4 ton and 37's - Page 40 - JeepForum.com
post #586 of 731 Old 03-05-2013, 11:19 PM
sdmayhew
Can you talk more about e drop Pittman arm? I am noodling on going to 6 or 7 inch springs and 35's in a couple months and would need to drop my Pittman arm
I already have over 12 of Travel at the shock
1993 ZJ Clayton long arms with Johnny joints, custom front axle W yota center, D44 chevy outers, fabtech dirtlogic 2.25, front bilsten rear shocks, tacoma rear axle, 4.88, arb rear, 5 speed, poly motor mount inserts, NP241OR 4-1 ,receiver front for xcr 8k winch
sdmayhew is offline
post #587 of 731 Old 03-06-2013, 07:11 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
It's actually about 3" lesss than stock. My arm is almost flat now.
ratmonkey is offline
post #588 of 731 Old 03-06-2013, 09:58 AM
bananaslug
I would like to do the ABS delete to open up space under the hood. Is this a good thread in your opinion?
http://mallcrawlin.com/forum/showthr...-System-Delete
bananaslug is offline
post #589 of 731 Old 03-06-2013, 02:01 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
yep, that write up works
post #590 of 731 Old 03-06-2013, 02:03 PM
mike_breaker_5
i read that thread and laughed harder than when i watched this. . .
gravel guard apparently cools your brake lines. that guys mouth and this hippo's butt have something in common.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #591 of 731 Old 03-06-2013, 02:25 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
http://www.youtube.com/watch?v=XTUFSVYFUTE
it's like this guy was giving advice on brakes.
https://www.youtube.com/watch?v=WkCxXErb2Ag
post #592 of 731 Old 03-06-2013, 11:25 PM
sdmayhew
Cool. Looking at your picture again I realized your on high steer arms. Which I could also do real easy with my d44 knuckles by swapping the one out.
Mine has abs removed when po went to different axles. Not that much of a difference not having abs.
sdmayhew is offline
post #593 of 731 Old 03-08-2013, 04:53 PM
daddyjeep87
1987 YJ Wrangler
I didnt read the thread that you mentioned, but I laughed like hell at the video.
You live in Emporium? you need to come over and help me build my Jeep. I am in Smethport.
daddyjeep87 is offline
post #594 of 731 Old 03-23-2013, 12:30 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
well, after wrecking my car i've decided to buy a truck.
picking up a 1997 f250 hd. regular cab, 7.3 powerstroke, 5 speed manual trans, 8800# axles. it's a little beat on, but i think i can make it a decent hauler and driver.
post #595 of 731 Old 03-23-2013, 12:30 PM
MStaffin
Not bad. I hate mine. Its a turd. Pulls anything but just no power. How many miles on yours?
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline
post #596 of 731 Old 03-23-2013, 01:53 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Yeah, my step father had a 96 power stroke auto, it was a dog but you could load that sucker up like no ones business.
The manual seems a bit snappier.
Definitely needs some tlc. 25x,xxx on it.
Needs an exhaust manifold
Needs a major cleaning of the engine bay. Theres a slight leak in the valley from something.
Tank switch or sending unit in the rear tank went and the guy never fixed it.
Needs an interior update, fogged headlights replaced, front fenders, etc.
The usual junk on a work truck.
It'll probably get some h2 wheels and 10ply a/t tires in a 33-35" flavor
I'll likely do the exhaust, intake, and fmic, possibly a different turbo.
Got it at half low blue book private value.
post #597 of 731 Old 03-23-2013, 03:07 PM
nickpequignot
My boss has a 2000 power stroke. And It was a dog stock. He threw some injectors and a upgraded turbo wheel and custom tunes on it and it will put you back in the seat now.
nickpequignot is offline
post #598 of 731 Old 03-28-2013, 08:27 AM
MStaffin
Im now buying a 99 cummins 5spd. Thing is a monster. Hope guy takes my offer. Has 125xxx all stock minus the 4" exhaust.
MStaffin is offline
post #599 of 731 Old 03-28-2013, 09:43 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
I'll be getting the leaky manifold done Friday I'd the weather isn't too terrible. New manifold and I'll prep it for an egt probe and ceramic coat it for some rust prevention.
The manifold on it now is literally rusted through.
Hope it doesn't need up pipes just yet.
Got a rebuild kit for all the fuel related items under the hood on the way.
I'll pull the high pressure oil pump and throw some gaskets and o rings at it to make sure its in good order. They're kind of expensive to get remanufactured.
I'll be inspecting the turbo wheel too. The upgraded wheel most commonly used in the 99+ Garrett turbo is the wheel from the 94.5-98 Garrett turbo.
I've got a 6637 intake kit on the way
Needs new batteries
Going to swap to super duty 40/20/40 heated leather seats
Going to throw in real carpet
Power window/lock doors from an xlt/lariat
New headlights
New front fenders
Fix rear fuel tank/tank switch .
Get a CD player in it.
Probably do an injector rebuild or upgrade with a good tune. I'll do the turbo back exhaust if it's too rusted, otherwise I'll leave it alone for now.
post #600 of 731 Old 03-29-2013, 06:50 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
i hate rust. all 8 manifold bolts are broken off in the head after trying to pull the exhaust manifold. at least four of them have studs long enough to grip. only one promises to be a total pain. it's the reason it was leaking in the first place. the bolt actually completely rusted through and is rusted into the head.
Post pics of your wrangler in use during the upcoming storm 1/31/11 Krochus Wrangler General Discussion 64 02-05-2011 01:32 PM
keep the 37's or go bigger?? highrolrcustoms Wrangler General Discussion 19 08-21-2010 01:00 PM
37's on the 'dub..... CaribouLouWJ Grand Cherokee General Discussion 108 03-31-2010 07:47 PM
Upcoming Mods!! njrealtor55 ZJ Grand Cherokee Forum 9 08-31-2005 09:14 PM
Need tires in the upcoming months, Size recomendations? spankey ZJ Grand Cherokee Forum 17 08-20-2004 09:00 AM
