ratmonkey's build. In progress: 3/4 ton and 37's - Page 30 - JeepForum.com
post #436 of 731 Old 09-26-2011, 11:11 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Sometimes you just got to get them titties bouncing.
ratmonkey is offline
post #437 of 731 Old 09-26-2011, 11:31 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Time for coilovers and air bump stops.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #438 of 731 Old 09-26-2011, 11:42 PM
SnowLeopard
What shocks did you kill? So far my Bilsteins seem pretty stout. I get a bit rougher than I should with a mildly lifted Jeep, too. It must be Jeep syndrome. You're insane for blowing all 4 shocks at once though!
SnowLeopard is offline
post #439 of 731 Old 09-27-2011, 03:40 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
They were re monotubes.
I doubt they went all at once. I was hammering on it for a while.
May look into some fox shocks.
post #440 of 731 Old 09-27-2011, 10:11 AM
SnowLeopard
Could you give that money tree of yours a shake for me? I could really use some 'leaves.'
post #441 of 731 Old 09-27-2011, 11:29 AM
squashman702
1994 ZJ
Words to live by.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #442 of 731 Old 09-27-2011, 01:16 PM
BLACKzj52
Words to live by.
Damn right.
Rat, I always enjoy reading through your build. Keep up the good work.
Ps. Do you have any pics of the the sway bar setup you had in the rear?
BLACKzj52 is offline
post #443 of 731 Old 09-27-2011, 03:43 PM
LordHobbit
Do I detect a future signature?
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #444 of 731 Old 09-28-2011, 02:36 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Anyone may use it as they like.
I'll see if I can snag a few pictures in the morning.
post #445 of 731 Old 09-30-2011, 12:26 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Did the gear set up again on the rear finally, sort of. Got a great pattern with the set up bearings, pressed the new stuff in and ended up too deep on the pinion again. Bl was headed towards the toe pretty far so I should be able to get away with just pulling a couple thou from the pinion. Wanted it set up race tight, but I'm also tired of messing with bearing pullers.
Apparently my pinion set up race is a few thou thinner than the final install piece. I'll pull and verify so I dont take too much out of the stack.
post #446 of 731 Old 09-30-2011, 07:37 PM
mike_breaker_5
just use my dads method of repairs...
if it doesn't work the way you want it, you didn't hit it hard enough the first time.
translation: get a bigger hammer.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #447 of 731 Old 10-02-2011, 05:22 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
guess i'll put up some photos again.
here's the rear sway bar i was asked about. with the 8.8 it has to be a bit off center. doesn't seem to effect performance in any way. i did have to remove the down leg from the claytons truss though. kinda unhappy 'bout that but not too big a deal.
headlights and foggy lights
under hood and exhaust
post #448 of 731 Old 10-02-2011, 05:31 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
crawler ready motor mounts
center console.
the junk still in my drive way.
rear gear pattern.
what i was hoping to end up with, i.e. the last pattern from the set up bearings.
that got all screwed up by the real races and bearings. it was about the same centering for backlash but was .005" deeper giving me about the same pattern greg convinced me to re-do. very defined half circle instead of feathered edges rounded on the ends. needless to say, i was an unhappy monkey.
now the final pattern. good feathered edges, not too sharp on the root, small strip on the top. i'd prefer it slightly more towards toe, but centered will do.
post #449 of 731 Old 10-02-2011, 06:58 PM
MaintMech
Old and in the way
MaintMech's Avatar
Holy Buckets!!
What size cables do you have on that battery, and where did you get them?
Welding cable??
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #450 of 731 Old 10-03-2011, 01:28 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Welding leads 2/0. unfortunately, aftermarket audio spec battery terminals don't go that large.
Post pics of your wrangler in use during the upcoming storm 1/31/11 Krochus Wrangler General Discussion 64 02-05-2011 01:32 PM
keep the 37's or go bigger?? highrolrcustoms Wrangler General Discussion 19 08-21-2010 01:00 PM
37's on the 'dub..... CaribouLouWJ Grand Cherokee General Discussion 108 03-31-2010 07:47 PM
Upcoming Mods!! njrealtor55 ZJ Grand Cherokee Forum 9 08-31-2005 09:14 PM
Need tires in the upcoming months, Size recomendations? spankey ZJ Grand Cherokee Forum 17 08-20-2004 09:00 AM
