Racing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Racing
Steering and more from Ruffstuff!Ruffstuff 3 Link Kit!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 10-07-2014, 12:40 PM   #1
tricky1ok
Racing
Well I'm getting close to driving my jeep after I put new lifters in it.
Fired it up today and the motor isn't idling at all (maybe for a few seconds), as a matter of fact its racing.
I checked all the vacuum lines.
All connectors.
Any ideas guys?
tricky1ok is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 12:56 PM   #2
ChrisHager
ChrisHager's Avatar
Have you messed with the Camshaft Position Sensor a.k.a. OPDA a.k.a. "distributor"?
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 10-07-2014, 01:12 PM   #3
Jeeples
Did you reuse the intake/exhaust manifold gasket? If so, get a new one, if not did you follow the bolt tightening sequence for the intake and exhaust manifolds?
His: '00 WJ 4.7 Limited- stock
Hers: '03 WJ 4.7 V8- IRO 3", 245/75/16 Duratracs
Jeeples is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 01:49 PM   #4
tricky1ok
Not at all Chris..
Unread 10-07-2014, 01:50 PM   #5
ChrisHager
ChrisHager's Avatar
I ask because if a lifter is bad, there's a chance the camshaft is bad. To replace the camshaft, the CPS has to be removed. If it is altered, it needs reset and can cause you to have high idle.
There is method to my madness.
Hers: 2000 TJ
WJ Torque Specs
Unread 10-07-2014, 01:51 PM   #6
tricky1ok
I did put a new one in...and followed the bolt tightening sequence.
Unread 10-16-2014, 07:18 AM   #7
airplanes518
good luck hope it gets fixed
airplanes518 is offline   Reply With Quote Quick reply to this message
