Quadra's 94 ZJ Build - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Quadra's 94 ZJ Build
The Cure for your Tie Rod Roll!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-26-2013, 11:54 AM   #31
QuadraBeast
1994 ZJ
A little teaser for one of the mods I hope to accomplish today
My Overland Ready ZJ Build
[URL="http://www.jeepforum.com/forum/f197/quadras-94-zj-build-1557001/"]http://www.jeepforum.com/forum/f197/quadras-94-zj-build-1557001/[/URL]
QuadraBeast is online now   Reply With Quote Quick reply to this message
Unread 08-28-2013, 08:16 AM   #32
dnuccio
sway bar discos!
im thinking of fabbing a set
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline   Reply With Quote Quick reply to this message
Unread 08-28-2013, 07:34 PM   #33
QuadraBeast
1994 ZJ
Originally Posted by dnuccio View Post
sway bar discos!
Do it! Ive got about $15 in the parts. I got 4 Pins, 4 clips, and 8 washers. I got the extra two so I can mount them up higher, so I can swing the swaybar up out of the way and clip it so it doesnt interfere with anything. I didnt get around to the mod yet though, its been pouring the last couple days and ive been very busy with a couple very important interviews and whatnot, but I hope to have it done in the next couple days and ill post a mini write up.
Other than that ive been looking into new tires but I cant find the size I want. Im looking BFG ATs or something comparable in a 33x9.50 or 10.50. The only problem is I need them in a 16" wheel and I cant find anything close. If anyone has any recommendations, that would be great. On the other hand I might just end up selling my Konig wheels and get a set of 15" steelies so they sit out a little farther. Too many choices!
Unread 08-28-2013, 11:58 PM   #34
dnuccio
i think some TJ ravines would look sick on your rig.
i was gonna do the sway bar discos a while ago, i had made pins to bolt to the axle bracket with lynch pins and everything, but for some reason, the sway bar links kept hitting the coils. that and i didnt have a good way to attach them up out of the way. so im thinking of a new design, probably will post a thread in the ZJ section when i get it together
R.I.P. Ratmonkey
Unread 10-03-2013, 08:41 AM   #35
TNScrambler
good looking jeep, I like the look of the painted cladding...
I had seen in another thread you posted about tires and how you would like a 33x10.50 tread and possibly trying to keep your 16s.... you might want to check out 255/85/16s, they are almost a 34x10.50 tire. I recently picked up a used set to go on my F350, I haven't gotten them mounted up yet, but I like that they have the hieght but not the width of my 285s on stock wheels.
Justin
1995 ZJ Laredo 4.0 auto 242, D30 and D44a with 3.73s (swapped in), 4in tj skyjacker front coils, stock v8 front coils in rear, adj upper and lower front arms, adj upper and JK rear uppers acting as my rear lower control arms, RC adj front trac bar, RE adj rear trac bar, 31x10.50 Michelin LTXs on ZJ Canyons, WJ Black Leather seat swap.....more to come....
TNScrambler is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 06:19 PM   #36
martymars
Very nice Jeep
martymars is offline   Reply With Quote Quick reply to this message
