Project Yeti, Abominable WJ - Page 49 - JeepForum.com
post #721 of 796 Old 06-24-2013, 01:58 PM Thread Starter
85IrocZ-28
Well....it wasn't a cracked CV cage like I hoped. But at least I was able to make it home from Moab:
New Yukon R&P along with master install kit is on its way.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #722 of 796 Old 06-24-2013, 02:59 PM
dillonjm
2013 WK
I assume thats in your front 30, probably had a little housing flex goin on. Glad you're getting it sorted out!
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #723 of 796 Old 06-24-2013, 04:16 PM Thread Starter
85IrocZ-28
Yeah, I think I have pushed the axles to their limits For all the trips we have made to Moab though, I feel fortunate to have this as the first major break.
post #724 of 796 Old 06-28-2013, 11:54 AM Thread Starter
85IrocZ-28
Parts arrived on Wednesday, so I took Thursday off to get the Jeep back on the road:
I thought all my gears were Yukons (I know the rears are, but Six States may have just used whatever D30 stuff they had on the shelf). The pinions look different, the left one is the Yukon and it has a larger contact tooth:
The passenger side of the carrier has an attachment (may have something to do with the varilock) on it that didn't allow me to use the bearing puller the way I wanted to without destroying it...so we cut the bearings off with a grinder, then sliced into the inner race, and used an air hammer around the lip of the inner race to get it off of the carrier. Long process, but it worked:
We put it together to see the pattern and left all shims as they were before. BTW, the pinion was a beast to tighten. I had a pipe wrench on the yoke and against the LCA while tightening it with a 24 inch breaker bar. We got really lucky, the pattern looks great. I am no gear pro, and was lucky to have the help of my bro. He is my go to mechanic when something is beyond my skills.
It feels better on the highway than it did before. I also replaced the diff side u-joint in the front driveline, and rotated the tires. My highway test last night and this morning were both great, now to get some miles on this and see how it starts wearing. I'll check the pattern again in 500 miles when I change the fluid again.
post #725 of 796 Old 06-28-2013, 06:57 PM
clgielin
2003 WJ
Glad to see it back on the road. I am still trying to get myself and the Jeep at a Secretary of State at the same time during business hours. It's in my in-laws barn 1.5 hours away.
Chris
2003 WJ 4.7L
Build Thread Here:
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline
post #726 of 796 Old 06-28-2013, 07:11 PM
dillonjm
2013 WK
Your pinion is a little deep judging by the pattern. Looks like good backlash.
Probably not a huge deal, just what it looks like to me. Glad its all back together.
dillonjm is offline
post #727 of 796 Old 06-29-2013, 12:00 AM
Timo_90xj
Timo_90xj's Avatar
I've seen quite a few people set up their pinions fairly deep, heard it's good for gear longevity when playing on the rocks.. keeps the gear contact OK even under slight housing flex/ R&P deflection. Dunno for sure though, that's just an internet rumor
Truss and a heavy duty diff cover are a damn good idea on any D30 (and D44a) that gets used off road on bigger meat.
***Under construction***
Timo_90xj is offline
post #728 of 796 Old 06-29-2013, 01:16 PM
780406jeeper
Thats the coast side of the gear. What does the pattern look like on the drive side?
Kevin
'78 Cherokee Chief: 360/TH400/NOS QT, '04 Grand Cherokee: 4.7/545RFE/242HD w/SYE, JK Rubi front axle, 4.56 gears, Protofab rear bumper/tire carrier
780406jeeper is offline
post #729 of 796 Old 07-01-2013, 04:08 PM Thread Starter
85IrocZ-28
Thanks for the input...on my next set of axles, I plan on having more time to work on things. I would love to have the axle on the bench and really have time to learn how to do this properly. For now, it is close enough and feels good on the highway.
Kevin
The opposite side of the gear looks about the same. However, this is actually the drive side if I understand correctly (Dana 30 Low Pinion). Hence the reason that D30 HP are stronger as it actually drives on the drive side. I don't know why the LP was ever used, they should have used a HP in all vehicles for better strength.
post #730 of 796 Old 07-01-2013, 04:13 PM Thread Starter
85IrocZ-28
I have a truss for the rear, just haven't welded it on. Maybe I should think about a truss for the 30 as well, they aren't that much $.
post #731 of 796 Old 07-01-2013, 04:18 PM
780406jeeper
Man talk about having my head up my you know what,
When I looked at that pict, I just thought it was the rear 44A. You are absolutely correct for the front, and I agree, no idea why jeep ever used the lp 30, even in the xj I was always told that the tj needed to be lp for clearance issues, and that the hp 30s ran out before the xjs were done. For the wj, doesn't seem like a clearance issue but who knows.
Your jeep looks sick btw and was the inspiration for mine. I am the guy that 801DubJay ran into out here in AZ. I guess he knows you...
Kevin
post #732 of 796 Old 07-01-2013, 04:26 PM Thread Starter
85IrocZ-28
Thanks. Yeah, Matt thought it was fun to run into another Dubber down in AZ. He is way cool to wheel with, you'll have to join us on one of our Moab trips if you can. I have also heard there are some areas of AZ that we need to check out though too (near Sedona). My wife's aunt and uncle just build a home in Gilbert. We were planning a trip around the four corners, NM, AZ but our plans changed and we had to cancel. I am glad it didn't work out though, the trip would have been for last week and this week. The heat has been crazy.
post #733 of 796 Old 07-01-2013, 05:19 PM
780406jeeper
Where abouts in Gilbert? Great town to live in. The wheeling out here is awesome. Rocks and more Rocks. I would love to wheel with you guys some day.
Kevin
post #734 of 796 Old 07-01-2013, 05:55 PM Thread Starter
85IrocZ-28
Kevin
I am not sure, can't find their address right now and I haven't visited there yet. If you ever plan on coming to Moab, make sure to post in the UT section. I will do the same if we can get our SW exploration tour back on track
post #735 of 796 Old 07-21-2013, 12:56 AM Thread Starter
85IrocZ-28
Last week I finally ordered new window scraper seals for the Jeep. They were getting really bad, and it was time. Here are some pics of the worst one, it was rusting from the inside out and bulging away from the body.
This view shows how much it was starting to push away from the door because of the internal rust and swelling:
There was an incredible amount of rust that was falling out during the removal of the old ones. All 4 took about 10 minutes to remove and install.
The new seals look so much better.
Project rdtj Wrangler General Discussion 23 11-04-2009 08:40 PM
My new Project!! BHand89 ZJ Grand Cherokee Forum 3 06-26-2009 11:59 PM
zj project mudder_317 ZJ Grand Cherokee Forum 30 03-25-2008 06:23 PM
New project nashmd454 ZJ Grand Cherokee Forum 13 01-12-2008 12:42 PM
next big project grandman17 ZJ Grand Cherokee Forum 5 01-06-2006 08:11 PM
