Project Yeti, Abominable WJ - Page 40 - JeepForum.com
post #586 of 796 Old 10-23-2012, 10:01 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by clgielin View Post
One was used to rotate the pinion to the proper angle and the other to press the truss back in place to be field welded.
Sounds like a good time on the trail!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #587 of 796 Old 10-23-2012, 10:03 PM Thread Starter
85IrocZ-28
Yeah...the bottle jack trail repair. The UJC doesn't leave a fellow jeeper behind
Well, the trip was a blast and we are looking forward to Thanksgiving. Hopefully we can have an even larger Utah JeepCrew turnout. And if adavis can make it out, maybe we will consider him an honorary member
We hope you can make it Corbin, along with your wife. We'll post up more info as it gets closer. You too Matt, you should join us.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #588 of 796 Old 10-23-2012, 10:24 PM
alwaysHI
2003 WJ
Looks like fun!
Man, I need to get my arse out of here and come up there one day. Hawaii has nothing to wheel like that
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #589 of 796 Old 10-24-2012, 04:59 AM
adavis39
Sweeeeet!!! ill start driving now, maybe ill make it by Thanksgiving
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #590 of 796 Old 10-24-2012, 10:46 AM Thread Starter
85IrocZ-28
You do drive a UT WJ, you belong here.
post #591 of 796 Old 10-24-2012, 11:28 AM
adavis39
haha...very true
TNJEEPS.COM
BUILD:
adavis39 is offline
post #592 of 796 Old 10-24-2012, 12:53 PM
Volcom02Wj
Looks like you guys had a blast. I may have to make the trip down for Thanksgiving
-COLE-
02 WJ Limited, 4.7L H.O. v8, 6.5" IRO CP Long arm kit, 35x12.50x15 Goodyear Wrangler MTR Kevlar's on Cragar soft 8's
Volcom02Wj is offline
post #593 of 796 Old 10-26-2012, 06:48 PM Thread Starter
85IrocZ-28
For sure, you need to join us!
post #594 of 796 Old 11-05-2012, 12:42 PM
wjjeep19
Hey man I love your wj. I have a 2002 Laredo. Since yours is a '99 do you have any electrical problems? Since the '99 is the first year the WJs went to electrical components I was just wondering because that's what I heard. Ive also heard that the WJs have had problems with the V8s and was wondering if you have had any problem with yours? I was looking into getting an overland but I want to have the i6 just because of the reliability.
wjjeep19 is offline
post #595 of 796 Old 11-05-2012, 12:56 PM Thread Starter
85IrocZ-28
Thanks!
The only electrical problem I have had was a heater blower motor wire that melted and needed to be replaced. $15 and 15 minutes, easy fix.
Everyone says the 4.7 isn't as reliable as the 4.0, but I don't know why. The I6 has problems too. Most of the have an anoying tick, and the power of the v8 is great. I know of a few WJ's that have over 200k on the clock with a 4.7 and are just fine. I also know a few 4.0 owners that didn't make it to 150K. I have also seen the opposite of both of those statements.
For me, I will stick with the 4.7 for the additional power, great sound, and perfomance. The 4.0 doesn't get much better gas mileage anyways. When my 4.7 goes out, I will just rebuild it or find a reman.
post #596 of 796 Old 11-13-2012, 11:06 PM Thread Starter
85IrocZ-28
I installed the second new battery this month. I think the one I picked up was bad, It wouldn't hold a charge very well.
I also installed by CB cable and antenna. I will continue to use my handheld unit for now, I have an adapter that is connected to the CB wire inside the cab. As some point I may install a full time CB unit in the Jeep, but I like the handheld for now. And with the 3 foot antenna, I will actually be able to communicate with others that are more than 20 feet from me
I ordered everything on Amazon, I picked up the Dodge Ram hood mount that I have seen others use on the WJ. It works great and looks good.
This pic shows where I ran the cable into the cab behind the tail light. I just stabbed through the rubber grommet with a screwdriver, then forced the cable through. It should remain a water tight fit.
I then removed the drivers side rear interior panel. The cable came in through the interior rubber grommet, then I ran it along the underside of the interior panel all the way to the drivers seat...just tucking it under the floor trim as I went.
I have seen others that notched the tail light to run the cable. I didn't do that, I just tilted the tail light down a bit. I may change that in the future, but it fits for now and it looks really clean IMO:
Once the cable was to the drivers seat, I ran it under the seat (the seat is adjusted all the way forward in this pic so that I had more working room. It isn't visable when the seat is in driving position. I then ran it under the center console, removed the center tray, drilled a hole in it, and left the excess cable in the console. Now I can just open the console, pull the cable out, and plug in my handheld CB!
post #597 of 796 Old 11-14-2012, 04:29 AM
platinum5.9
2003 WJ
I ran my cable the exact same way. Simple and worked great.
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #598 of 796 Old 11-14-2012, 11:18 AM
compcrasher86
That's exactly how I did mine! With that setup I was having trouble getting a good SWR (kept getting 1.7) but looking back on it I think there may have been a bad ground or I messed up the pl-259 soldering. When I put it on my ARB I got AMAZING SWR (1.1) and range but I sold that so I'm back to the taillight mount. It looks right at home back there though and I was still able to fit in my garage.
Matt
compcrasher86 is offline
post #599 of 796 Old 11-15-2012, 04:54 PM
801DubJay
You lucky sonuvagun. I could not get mine to work like that! Nice job though
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline
post #600 of 796 Old 11-15-2012, 05:01 PM Thread Starter
85IrocZ-28
Maybe the aftermarket tail lights have clearances that are not so tight.
Project rdtj Wrangler General Discussion 23 11-04-2009 08:40 PM
My new Project!! BHand89 ZJ Grand Cherokee Forum 3 06-26-2009 11:59 PM
zj project mudder_317 ZJ Grand Cherokee Forum 30 03-25-2008 06:23 PM
New project nashmd454 ZJ Grand Cherokee Forum 13 01-12-2008 12:42 PM
next big project grandman17 ZJ Grand Cherokee Forum 5 01-06-2006 08:11 PM
