Project Yeti, Abominable WJ - Page 35 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project Yeti, Abominable WJ
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-21-2012, 07:45 AM   #511
mrowaan
Just saw it on Facebook also, now I have to go read more of the build.
Flexing my WJ http://www.youtube.com/watch?v=KWFDAaQyMlM
mrowaan is offline   Reply With Quote
Unread 07-21-2012, 10:26 AM   #512
PhantomWJ
2003 WJ
That bumper looks clean.
PhantomWJ is offline   Reply With Quote
Unread 07-24-2012, 01:56 PM   #513
85IrocZ-28
Yeti - The Abominable WJ
85IrocZ-28's Avatar
Thanks guys. I need to find some time this week to track down a front end rattle.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, K&N, Flowmaster, Smittybilt 8k Synthetic Line Winch.
Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- Project Yeti Build Thread
85IrocZ-28 is offline   Reply With Quote
Unread 08-13-2012, 07:04 PM   #514
85IrocZ-28
85IrocZ-28's Avatar
Well,
I repainted a section of the bumper this last Friday. If I had scratched it in Moab, it would have been cool. But because I scratched it on a property stake up at my inlaws cabin, it wasn't a "cool" scratch and my wife wanted it painted. So I sanded the damaged area, and fixed the problem.
Sanded:
Acid Etch primer:
I had some paint leftover from the original paint job, so a coat of white primer then the paint and the bumper is fixed.
I also needed to do some concrete work over the weekend, and needed to pull about 11000 lbs. That is beyond the jeeps capability by far, so I borrowed my bro's truck. It is fun to drive, but it dwarfs the Jeep when parked next to it:
Unread 08-13-2012, 07:20 PM   #515
00JGC00
Nice!
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline   Reply With Quote
Unread 08-13-2012, 08:00 PM   #516
clgielin
2003 WJ
Is Brad towing DV down to Moab in October? I'd like to see that tow rig in person!
(and Brad abusing his trail rig)
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is online now   Reply With Quote
Unread 08-13-2012, 08:35 PM   #517
85IrocZ-28
85IrocZ-28's Avatar
I wish...I don't think he will be joining us this time. I think he is considering a 5.0 swap, he just put new Toyo's on it though.
Jeep Forum via Android
Unread 08-13-2012, 10:14 PM   #518
alwaysHI
2003 WJ
Shesh what is that, 550 series?
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/
alwaysHI is offline   Reply With Quote
Unread 08-14-2012, 05:49 AM   #519
85IrocZ-28
85IrocZ-28's Avatar
F350 with semi wheel adapters. It is fun to drive...It makes me want a row rig.
Unread 09-12-2012, 11:13 PM   #520
JerzeyBoyWJ
2003 WJ
got any pictures of your driveshaft angle with the IRO a-arm ...i cant get my to adj right to get rid of my vibrations ..any tips?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 bfg all terrains
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote
Unread 09-12-2012, 11:18 PM   #521
compcrasher86
compcrasher86's Avatar
If anyone knows the proper method for aligning those things I'd love to know I have one being delivered tomorrow and I don't wanna mess it up
01 WJ Ltd | i6 | QT2 | OME HD Lift | Bilstein 5100s | IRO Links | IRO A-Arm | Dueler AT RHS 255-70-18 (32") | JK Sahara rims | Moog HD steering | Upcountry Skids | Tow Package | KC Dayliters | Cobra 19 | Boston Acoustics Audio | Mopar subwoofer | RB1 | Lou's Catback | Stone White | Agate Interior
Build Thread
RIT Offroaders
Matt
compcrasher86 is offline   Reply With Quote
Unread 09-12-2012, 11:57 PM   #522
85IrocZ-28
85IrocZ-28's Avatar
I usually just eyeball it. The driveline is a hair under parallel to the pinion. It is pretty easy to adjust, no need to lift it off of the ground or unload the suspension. Just get it close, tighten the body side bolts, then slide the joint down into the diff mount, and keep adjusting until it looks right. With the upper body bolts in place, and the upper joint just floating, I would place a jack under the pinion and bring it up to the right level. Just adjust the joint in or out until you an slide it down into the mount and the bolt hole lines up. Slide the bolt in and remove the jack, and see how it looks. You may need to place the jack back in place and adjust in or out a bit more until you have it dialed in. Once the angle looks right, make sure to tighten the jam nut really tight.
My biggest tip: the instructions I received said to tighten the bolts holding the nylon, joint, and side plates to a ridiculously low number of inch lbs. Don't listen to this. 801DubJay and I both had a severe knock and slop in the rear suspension on our WJ's on Elephant Hill in Moab this June. When we got back into town, we crawled under and found that the joints were very loose. So loose, that I am surprised that I didn't loose the bolts/nuts that hold the joint together. I tightened it up very tight by hand, and re-greased it. The joint has been fine since, and operated perfectly.
It is kind of late, so the pics aren't great. Cell phone pics, but you get the idea.
My driveline has a single U-joint at the pinion, and a CV (2 U-joints) at the t-case.
Unread 09-13-2012, 01:24 PM   #523
JerzeyBoyWJ
2003 WJ
Thanks for the advice !!! I'm gonna try to dial it in on my next day off
Unread 09-13-2012, 02:18 PM   #524
85IrocZ-28
85IrocZ-28's Avatar
No problem. Do you have a CV at your transfer case, or a single u-joint at both ends?
Unread 09-13-2012, 03:59 PM   #525
JerzeyBoyWJ
2003 WJ
I have the 242 t case and it has single u-joints at both ends ..I've rear that I'm supposed to have my axle yoke and t-case yoke pararell to eachother ..but I can't adj. My a-arm enought to get my axle to be pararell..as of right now the joint is all the way it to the jam nut..if I remove the jam nut I can adj the axle more but then it won't be installed corrently and I would have a sloppy rear end from what I assume
