Project: War Wagon - Page 5 - JeepForum.com
post #61 of 292 Old 06-20-2010, 12:10 AM Thread Starter
xgerstandtx
We had a pretty impressive Trail Maintenance day today out at Walker Valley ORV near Burlington WA. This particular location had been pointed out by the "greenies" as a sensitive area. So naturally we grouped together and worked closely with the DNR to remedy the situation. Getting the excavator up the trail was quite impressive but a few pictures from today.
Loading up a Grand full of trail rock...
My Grand Loaded to the gills....
Teamwork
Finished product
xgerstandtx is offline
post #62 of 292 Old 06-20-2010, 11:51 PM
zjzach
right on guys, ive never been up to walker valley but it looks like you guys did some good work.
my build/wheelin/picture thread
zjzach is offline
post #63 of 292 Old 06-21-2010, 05:30 PM
Spike300
Good job, but u missed a spot, jk
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #64 of 292 Old 06-27-2010, 10:31 PM Thread Starter
xgerstandtx
Hey guys, Little late on the update
8.8............. check
detroit........ check
4.56 gears... check
To do:
Mount arb compressor
throw front d30 w/ ARB w/ 4.56 gears under
Everything was pretty smooth on the gear install and setup of the 8.8. The IRO brackets are amazing and line up every time. A nice bonus to the IRO kit is that the rear Track bar has two mounting holes. I used the highest one and was able to get rid of the rinky dink RC drop bracket and use the factory track bar. Good stuff.
Brake lines, I used a Trailer line w/ 3/16 male and female end. Attached this to the Stock Ford line. Found at my local napa dealer. A little expensive but worked well and now brake line will be plenty long for long arms.
Will get pictures up sometime.....
post #65 of 292 Old 06-28-2010, 05:28 AM
blackjack12982
1994 ZJ
Hmm, I didn't know that about IRO's 8.8 bracket kit. Good to know. I've been following this build for awhile now, and it's still very, very nice...
blackjack12982 is offline
post #66 of 292 Old 06-29-2010, 01:10 AM Thread Starter
xgerstandtx
8.8 Gear pattern pictures. The gear pattern is awesome looking. I have done tons of gears and the 8.8 has been one of the easier.
Upon first test drive, the backlash set in and was way too loose. Went back through the entire thing again and tightened it up to .007 backlash. Seems really smooth and quiet.
The locker on the other hand is mighty loud. seems to pop and make quite a bit of noise. Granted it has been a long time since i have driven a vehicle with a locker in the rear. (used to spools) Hopefully it '' breaks in'' a little more.
Here you can see the upper track bar mount:
Bad picture of rear end under the truck:
Another thing that caught me off gaurd was the way the springs sag. I have the RC 4'' lift springs. I thought they were saggy last fall so i put an extra isolator in it, It sat fine. So than i thought adding the 8.8 would net me the .75 of lift most claim. Well it still sat low in the ***. So i went ahead of added the isolator again. Sits about where i had it before. Point of the paragraph is the RC springs suck and I would recommend a higher quality spring for future purchases.
post #67 of 292 Old 06-30-2010, 11:19 PM Thread Starter
xgerstandtx
Today put a good amount of work into wiring and setting up the ARB.
I ended up going with CKMA12 compressor. This will be sufficent for airing up tires at the end of the wheeling days which should be nice.
Mounted the Compressor under the passenger seat. This was the best possible spot after racking my brain for almost a week on where to mount it. Under the hood would have been ideal but i couldn't find a good place, I removed the cruise control and thought about building a bracket for that area. But that still wasnt gonna work that well.
Pics:
I Tried to run the wiring cleanly. It will be much easier to find any problems if they arise.
Ended up Getting this amp/sub for free from a guy who just had more money than he knew what to do with or he was just dumb.
Basic system, The wiring was already in the truck from the previous owner. Real basic but it sounds solid.
I bought the Box at a garage sale for 3$ which was awesome. So it wont help me get down the trail but it is fun.
post #68 of 292 Old 07-01-2010, 08:22 AM
cheapjeeps85
lol i had the same amp i trade it to a kid that was geting his jeep repoed for some warn bumpers
cheapjeeps85 is offline
post #69 of 292 Old 07-01-2010, 10:09 AM
cirame1
i have 2 of those amps in my zj with 2 kicker comp vr 12's. Its loud but it should be wayyyy louder i think i wired sumthin wrong.
98' 5.9 slate on slate...
3.5" F>R swap, front and rear adj. track bars
17" rubicons w/ 285 70 17 inch hankook mtr's
full 3 inch exhaust w/flowmaster 40 series
242j tcase swap completed by jeeps unlimited providence,R.I.
cirame1 is offline
post #70 of 292 Old 07-01-2010, 10:37 AM
cheapjeeps85
lol i payed $75 and got a jbl 12 in a truck box with 500w alpine amp and it hits just as hard as my brothers 2 new kicker 12s and 1200w sony amp it makes him mad
post #71 of 292 Old 07-01-2010, 10:40 AM
cheapjeeps85
its kinda funny when ya pull up next to some one in a mud coverd jeep and ur country is hiting harder then the guy in the car next to you blasting his rap
post #72 of 292 Old 07-01-2010, 10:53 AM
PurpleZJ
lol so true on the country thing. i have 2 12" pioneers and a JL audio amp, they hit amazing. just make sure you tune your amp properly and your system will hit perfect
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #73 of 292 Old 07-01-2010, 05:02 PM
Spike300
haha sweet on the amp and arb, ANy pics of the air line ran for the locker?
To be rebuilt: HP30
To be received:
To be paid for:
lines
Spike300 is offline
post #74 of 292 Old 07-01-2010, 05:16 PM
PaLftr
In this thread : Jeepers discussing how hard their country music hits thru their subs...Now I've seen it all. LOL
ZJ DD, WW. 4.go litre modded. 3", 31's. Needs armor.
PaLftr is offline
post #75 of 292 Old 07-01-2010, 05:30 PM
PurpleZJ
country has bass in it. just not the same type bass as rap. lol
December 2010 GCOTM
04/28/58-2/13/11
PurpleZJ is offline
My new Project!! BHand89 ZJ Grand Cherokee Forum 3 06-26-2009 11:59 PM
Paint my wagon! What color? FortCollinsZJ ZJ Grand Cherokee Forum 19 12-15-2008 12:16 PM
next project? Derek33 ZJ Grand Cherokee Forum 4 10-24-2007 03:21 PM
My project anticrombie ZJ Grand Cherokee Forum 294 07-05-2007 04:48 PM
next big project grandman17 ZJ Grand Cherokee Forum 5 01-06-2006 08:11 PM
