Project "Grow A Set" Redhatman's long lost build thread - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Grow A Set" Redhatman's long lost build thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 04-02-2010, 12:08 AM   #91
-cAcHe-
What is the purpose for the almost alloy?
www.desert-hooligans.webs.com
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 12:37 AM   #92
JFox21
I believe it is so that the ears on the axle shaft are stronger. Especially since he is running 37's.
Jamie
Sophomore at Santa Clara University
JFox21 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 12:41 AM   #93
redhatman
Originally Posted by bigbluezj94 View Post
pat you look 14 not 18 lol
sweet jeep nonetheless. keep it up brother
Thanks, I guess maybe that will help me look better in the field. The 14 year old that has the know-how to do lots of things!
The purpose is to prevent a problem that we see a lot. The u-joint cap will either work itself out (if the clip comes off), or the yoke itself will bust before the ujoint. We found the AA's help keep the cap in place in case the clip comes out, and also it holds the yoke together from splitting with the bridge it does.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 12:41 AM   #94
redhatman
Tomorrow I will get pictures of all the IRO LA Setup, and how that all goes into place.
-Pat
Unread 04-02-2010, 12:42 AM   #95
redhatman
Here is a picture of what happens..
http://webejeepinmoab.com/wp-content...8/photo121.jpg
-Pat
Unread 04-02-2010, 08:19 AM   #96
g-off70
this is looking killer, nice work
g-off70 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 08:59 AM   #97
bigbluezj94
1994 ZJ
all of those pictures are with 35s right? where are the 37s?
[CENTER]94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
[COLOR="RoyalBlue"][B]BigBlue build 33s, 6in lift and short arms[/COLOR][/B]
[B][U][URL="http://www.jeepforum.com/forum/showthread.php?t=679496"]http://www.jeepforum.com/forum/showthread.php?t=679496[/URL][/U][/B]
[COLOR="RoyalBlue"][B]BigBlue build 3/4 ton axles, LAs, 37s [/COLOR][/B]
[B][U][url]http://www.jeepforum.com/forum/showthread.php?t=818891[/url] [/U][/B]
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
[color=Black][center][size=4][font=Showcard Gothic][color=Black][url="http://groups.jeepforum.com/Built_Not_Bought"][color=Black]Built Not Bought #033[/color][/url][/color][/font][/size][/center]
[/color]
[/CENTER]
bigbluezj94 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 10:07 AM   #98
squashman702
1994 ZJ
Do you reccomend using a greasable U joint? My buddy has a set of the AA's and he's worried he burned up the grease in the process of welding them on.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 10:43 AM   #99
redhatman
Correct. 37's did not come until recently, I am trying to keep the build in order. According to this thread I do not have LA's yet, I will take pictures tonight of everything.
Nope, greasable Ujoints have a hollow core in the Main body of the trunion. The non greasable ones are non greasable, but solid forged. Because its hollow, its weaker.
-Pat
Unread 04-02-2010, 10:51 AM   #100
redhatman
So I just got back from the junkyard, I needed to find a 3.73 and up Dana 30 carrier. There inventory only listed on ZJ on the lot, so I went straight to that. The axle tag was not present on the front or rear differentials, so I could not tell the gear ratio. So me being as smart as I was, I called the local Park Jeep dealer and had them run the vin. Sure enough, it was 3.73 ratio.
After I dealt with the SOB wheel bearing bolts, and got the bearing caps out, I had to pull the whole carrier out. As seen in the picture before, I used the housing spreader to pull it out. Once again, me being as smart as I am I remembered to pack a ratchet strap in hopes I could use it to my advantage.
One hook in the spiders, and the other on the front sway-bar. Worked like a charm!
-Pat
Unread 04-02-2010, 11:20 AM   #101
reconvet88
can i go cash picking from your money tree?
reconvet88 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 12:31 PM   #102
redhatman
Unfortunately its not growing too well in the MN weather right now.
-Pat
Unread 04-02-2010, 12:43 PM   #103
reconvet88
miracle grow also known as crack. sell it. haha jk
but killer zj man.
Unread 04-02-2010, 09:32 PM   #104
redhatman
but killer zj man.
Oh is that why my dog always goes crazy after digging in our tomato plants?
Thanks.
I did not do any more work on the axle tonight, but I did snap some pictures of the Jeep....Front swaybar still connected, I did not feel like disco'ing it so I just pulled up it quick for some pictures.
37's tucked son
Coolant and washer fluid draining out from sitting at the extreme angle of the harsh MN rock mountains.
-Pat
Unread 04-03-2010, 12:30 AM   #105
country_boy454
Looking good!
1996 XJ 6.5" Rusty's, 34" LTB's, 220 amp alt, #1 wire upgrade, 4.0, AW4, NP231 NON SYE, CB 1996 ZJ Plum Broke Limited 5.2, SCT Tuned, Dual exhaust, CAI, Audivox Prestige APS997a alarm, Performance Distributors Ignition Upgrade, KOR BB + Up Country Springs, 52mm TB, 24lb/hr Ford Racing Injectors Plum Broke Build thread
country_boy454 is offline   Reply With Quote Quick reply to this message
