Project "Grow A Set" Redhatman's long lost build thread - Page 51 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Grow A Set" Redhatman's long lost build thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Labor Day Sale at UCF!Gibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-21-2010, 11:21 AM   #751
redhatman
For ****s and giggles today I replaced the tensioner pulley too.... Nope.
UGH! Also pulled apart the idler pulley setup, wire wheeled, checked that special washer for perfect roundness with a micrometer, everything seems to be in spec. Its such an annoying sqeek. Every other pulley looks and feels fine.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote Quick reply to this message
Unread 08-21-2010, 11:23 AM   #752
redhatman
New steering box installed!
5/8" Steering, all new heims, and bigger threads in the drag link for the IRO Double adjuster.
-Pat
Unread 09-02-2010, 06:46 PM   #753
redhatman
Well I evacuated the a/c system today in preparation for the intake gasket replacement. I will be doing that tonight when I get off work at 9, and hopefully finishing it before bed. Picked up some coolant, oil and filter, gasket set, and some RTV. Then, its off the Oklahoma at 6:30 AM for my cousins wedding. So... I want to get this finished tonight.
Next wheeling event is a week from tomorrow, probably the last of the year. Gilbert, MN. The Iron Range in Northern MN. Before then I hope I can lower it down to 7 inches, and get the front tire replaced. I work every day and have no time to go get the tires I found 3 hours away... Ugh.
-Pat
Unread 09-05-2010, 10:08 AM   #754
wfcxleatherneck
1993 XJ Cherokee
where are they? If they are closer to me, or some one I know I'll pick them up for you. I'm planning on heading to IRO soon so I could bring them there for you
wfcxleatherneck is offline   Reply With Quote Quick reply to this message
Unread 09-05-2010, 11:24 PM   #755
redhatman
Jeep intake gasket is pretty much done, I took a few pictures. I lost one of the fuel injector orings so it got put on hold while I was in oklahoma for the weekend.
I will hopefully pick up a 37" on monday, to replace the Irok I have been running.
-Pat
Unread 09-07-2010, 12:31 AM   #756
redhatman
Jeep is running again.... My buddy was helping me the other night and overtightened the wire harness on the voltage regulator of the alternator, snapped the stud. Long story short I bought a new alternator, at least I upgraded to the 136 amp vs. 90 amp.
Then I got it running and found out it was leaking coolant, to my surprise it was not the intake gasket, but rather the hose that runs from the waterpump to the intake manifold (almost impossible to see). So I tore it down again, and tightened that up (same buddy did not tighten enough).....
Then I went on a test drive and wound up with 5 tickets.
-HID's illegal
-Tires stick out too much (about an inch)
-No front drop bumper
-License (physical, photo id one in my wallet) too dirty. weird that stuff gets dirty when you are a mechanic. huh.
-No mud flaps.
Regardless, I told the officer very kindly I would see him in court.
But on the bright side,
picked up 1/4 MTR's that I bought (I bought a set)
-Pat
Unread 09-07-2010, 12:37 AM   #757
PurpleZJ
-HID's illegal
-No mud flaps.
damn son you go hard
http://www.youtube.com/watch?v=CtwJvgPJ9xw
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
PurpleZJ is offline   Reply With Quote Quick reply to this message
Unread 09-07-2010, 12:39 AM   #758
aircruiser
damn man that sucks this weekend is gonna be just what you need bro. wheel your worries away haha. atleast the tire situation is figured out..and your **** runs
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 09-07-2010, 08:35 PM   #759
redhatman
Well, The 37" mtr is mounted. So I am rolling on all 4 of the same tire again! Found out that my passenger rear 8.8 shaft is bent, and also my passenger front wheel bearing went bad again. Possibly from running the irok.
Either way, warrantying the bearing tomorrow.
-Pat
Unread 09-07-2010, 08:40 PM   #760
aircruiser
damn man and i thought i was having issues with my siezed up tracbar bolt. so what time are we leaving friday?
Unread 09-07-2010, 09:32 PM   #761
Spike300
tell the officer u dont know how to fix it
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2010, 10:37 PM   #762
redhatman
~2pm
-Pat
Unread 09-07-2010, 11:16 PM   #763
aircruiser
cool man cool let me know cause my buddys group is going up friday and i dunno what time they are leaving and i dont know if i can get work off early..we will figure it out tho.
Unread 09-10-2010, 01:50 PM   #764
redhatman
Intake gasket pictures, then leaving for The Iron Range!
-Pat
Unread 09-12-2010, 12:22 AM   #765
aircruiser
figured i would post this just to get some conversation going
