Project "Grow A Set" Redhatman's long lost build thread - Page 50 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Grow A Set" Redhatman's long lost build thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 08-06-2010, 07:38 PM   #736
Spike300
yeah prob, im on here trying to learn stuff so i dont break things haha
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 08-11-2010, 04:03 PM   #737
aircruiser
Originally Posted by redhatman View Post
too many web wheelers on all of these forums that think they know everything. Every forum has them.
might want to look at the title under your user name then
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 08-17-2010, 03:05 AM   #738
redhatman
One of the heims in my steering finally started getting sloppy, so I replaced all 4 Heims with Brand new ones, and upgraded to 5/8" while I was at it. No pictures now, but its true. I also replaced the drag link with the New and improved IRO drag link, with the IRO 7/8" Double adjuster at the top. Much stronger than the seemingly bulletproof previous one.
Also noticed a power steering leak today... coming right out of the pitman seal on the steering box. Gushing out. Time for a new box.... or a hydro assist setup?!....
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote Quick reply to this message
Unread 08-17-2010, 03:19 AM   #739
CLNinja
How new is that drag link Pat? is it the one i have? or is there a newer one than what i have that i should be upgrading to?
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote Quick reply to this message
Unread 08-17-2010, 07:27 AM   #740
spife7980
i agree, pics would be nice.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2010, 04:29 PM   #741
94ZJ-318
Is that 3/16" steel?
94ZJ-318 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2010, 06:58 PM   #742
redhatman
I am almost 100% sure it came out after you got yours installed Matt. We did not have problems with the other double adjusters breaking, It was time to replace the QA1 part with an IRO Part, bigger and better. You probably have a silver double adjuster that is basically a giant 3d hexagon with threads?
I will post pics later tonight.
What? The bumper? Yes.
Picked up a reman steering gearbox today for it, lifetime warranty. Also picked up a NAPA brand idler pulley, the autozone one I bought a month ago I have warrantied 3 times because they keep starting to squeek. We will see if this fixes it.
-Pat
Unread 08-17-2010, 09:01 PM   #743
-Shoey-
2003 KJ Liberty
If 94-00 Ram steering boxes work, PSC makes heavy duty ones.
2003 KJ Limited
USN Jeep Club #115
-Shoey- is offline   Reply With Quote Quick reply to this message
Unread 08-18-2010, 01:22 AM   #744
CLNinja
how much did that steering box run ya Pat? I plan on replacing mine soon too... i have a bit of a leak that i noticed coming out of mine ... thinking it might be contributing to my huge dead spot in my steering
Unread 08-18-2010, 11:17 AM   #745
redhatman
$154 out the door, but that was with a $15 core and tax. I think it was like $129.99, plus its lifetime warrantied
Got the box in last night, as well as the idler pulley. Yet, it still squeeks. I have no clue whats wrong. 4 brand new pulleys, obviously something is wrong.
-Pat
Unread 08-18-2010, 11:20 AM   #746
PurpleZJ
your engine is spiting you for making it move 37s lol
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
PurpleZJ is offline   Reply With Quote Quick reply to this message
Unread 08-18-2010, 12:27 PM   #747
squashman702
1994 ZJ
Do you have a mechanic's stethescope? Are you sure it's the idler pulley each time? I would listen to each of the pulleys and make sure the noise isn't being thrown from another pulley.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2010, 01:12 PM   #748
YMEOFCR
I used to have a Ram with a 5.2 and a belt squeek. Changed everything i could think of and the squeek never went away. Had a friend rev it up one day while i was looking at the pulleys and the crank would actually move in and out. If you shut it off and took a pry bar you could move the crank back and fourth in the block. I sold the truck like that but i assume it was a thrust washer for the crank that went bad.
YMEOFCR is offline   Reply With Quote Quick reply to this message
Unread 08-18-2010, 01:29 PM   #749
jeep0312
Very sexy jeep! I love it! Keep up the good work!
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline   Reply With Quote Quick reply to this message
Unread 08-20-2010, 12:55 PM   #750
redhatman
I do, its all coming from that pulley. I can spray it with lube, and it goes away temporarily.
-Pat
