Project "Grow A Set" Redhatman's long lost build thread - Page 48 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Grow A Set" Redhatman's long lost build thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-26-2010, 11:52 PM   #706
redhatman
Originally Posted by JFox21 View Post
Yeah at least buy 2 of them.
thats what I was thinking...then I have a fullsize real spare.
lmao looks like someone forgot to put the steroids in the other tire haha. jeep is looking and sounding good as always
EDIT: also pat which muffler would you recommend to run with that exhaust setup for the 4.0
hahahah I would recommend either the velocity series muffler we include, or the flopro option. Both sound great, dont do a flowmaster 40 though. Too loud for a I6.
Drove the Jeep through the carwash today, its looking decently clean now. Still need to get the pressure washer out. I also need to start going through and retorquing everything, seems as though I have some clunking to fix
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote Quick reply to this message
Unread 07-30-2010, 04:40 AM   #707
drmud
Build
You've done a nice job!
I haven't seen you guys in a while. I need to get down there and pick up some more goodies!
slowly pimpn' my ride.
http://www.jeepforum.com/forum/f197/...mpers-1042265/
DRMUD.
drmud is offline   Reply With Quote Quick reply to this message
Unread 07-30-2010, 12:09 PM   #708
redhatman
DRMUD.
Thanks! Sounds good, stop by some time. I need a rear bumper!
-Pat
Unread 07-30-2010, 09:33 PM   #709
redhatman
Well, I just did some recent work to the Jeep between last night and just now... Just got back in from the garage.
Last night I decided to convert my IRO HD Track bar, to a true double shear. What I had before was the HD track bar orig with tie rod end on it, and converted it to a double shear track bar with the M22 threaded end. I ran that for about a year, and now decided I would replace the track bar and all bushings. I dont like the way the Jeep rides on the highway, squirely.
Another problem I noticed, was slop was in the bottom bolt hole aswell. It was starting to oval out. So I wire wheeled it, welded a washer on it, ground it flush, and proceeded!
-Pat
Unread 07-30-2010, 09:52 PM   #710
redhatman
So I noticed my rotor had some scoring, and brakes seemed funny the last day or two. So I decided I would tare it apart tonight... check it out.
-Pat
Unread 07-30-2010, 10:04 PM   #711
Spike300
check what out? i see part or your bumper and headlight
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2010, 10:05 PM   #712
redhatman
It is a video... click it.
-Pat
Unread 07-30-2010, 10:08 PM   #713
Spike300
oh haha opps
lines
Unread 07-30-2010, 10:11 PM   #714
redhatman
For now I just retorqued the nut, and I will see if it still drives alright, might need a new wheel bearing.
-Pat
Unread 08-01-2010, 10:35 PM   #715
squashman702
1994 ZJ
You were probably not too many miles away from losing that wheel.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2010, 10:44 PM   #716
JFox21
Yeah I think you may need a new wheel bearing. That one is definitely a goner.
Jamie
Sophomore at Santa Clara University
JFox21 is offline   Reply With Quote Quick reply to this message
Unread 08-02-2010, 12:12 AM   #717
SILASPRIT
Re-torquing the axle nut isn't going to help you at all. You really really really need to put in a new unit bearing. I can't believe that thing would even drive down the road remotely straight! LOL When you put in a new one you will be blown away at how much better it drives.
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline   Reply With Quote Quick reply to this message
Unread 08-02-2010, 07:27 AM   #718
redhatman
retorqued it, and it looked and drove like absolutely nothing happened. No extra noise or anything, perfect. A day later I checked it again for safe measure, sure enough it came a little loose again.
Yesterday I was pulling into the parking lot and it started making HORRID noises. Hahah, then it stopped for a couple hours. Now, its horrible again. Jeep is parked until I get a new one! I think its still under warranty.
-Pat
Unread 08-05-2010, 12:25 AM   #719
redhatman
Well, you guessed it. Its under warranty. Decided to resurface the rotor too since it got grooves in it from the wheel bearing.
-Pat
Unread 08-05-2010, 12:26 AM   #720
redhatman
As far as the tire, I picked up a 36 x 13.50 r 15 super swamper for $50 from a buddy. So I mounted that on my blown tire rim, and will run that to buy time. Hopefully I figure out what to do before the next wheeling event!
-Pat
