Project "Grow A Set" Redhatman's long lost build thread - Page 10 - JeepForum.com
post #136 of 1008 Old 04-04-2010, 08:39 PM Thread Starter
redhatman
redhatman's Avatar
Redneck jungle gym!
More trail riding
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #137 of 1008 Old 04-04-2010, 08:43 PM Thread Starter
redhatman
redhatman's Avatar
The 35" mickeys and 4.0 did not like eachother. The 4.0 was a good strong reliable engine but it simply did not have the power I was looking for. I looked for a 5.9 grand for a while, and was thinking of swapping over my suspension but did not have 4 grand to buy one... So I bought a donor Jeep. Fully running, 1997 Jeep Grand Cherokee Laredo, 5.2. Over 220k on it, but it drove and shifted fine. Plus, I did not like the sound of a 4.0 on a huge Jeep, it needed a nice V8 roar.
Pulled the engine, trans, transfercase, all electrical harnesses, PCM, a/c, radiator, everything....
-Pat
post #138 of 1008 Old 04-04-2010, 08:46 PM
indredsnake99
your zj looks amazing. want to trade jeeps
Wayne
1997 formerly GREEN now rustoleum bed lined zj 4.0 np242 bought 9/25/2008
gone
1998 5.9l platnium zj np249 k&n sct bought 4/6/2010
2007 sahara 2 door wrangler stock bought 02/08/2011
Originally Posted by ZJones View Post
You'll learn a lot. I didn't know anything when I first joined this site either. (not sure if that's changed at all :laugh:)
indredsnake99 is offline
post #139 of 1008 Old 04-04-2010, 08:51 PM Thread Starter
redhatman
redhatman's Avatar
With the high miles, I wanted to make sure the engine was in good shape. So i regasketed and inspected everything, both heads for straightness and any internals from being damaged.
-Pat
post #140 of 1008 Old 04-04-2010, 08:55 PM
-Shoey-
2010 KK Liberty
Friggin sweet Jeep dude.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #141 of 1008 Old 04-04-2010, 08:57 PM Thread Starter
redhatman
redhatman's Avatar
There is Sir Flex A lot!
Compression tested out well, so I did not replace any rings.
Heads were tested for cracks and warpage, all systems go.
The following parts have been replaced so far.
-Rear Main Seal
-Waterpump
-Intake Manifold Bolts (One broke inside one of the heads)
-Oil Pan gasket
-Lower intake
-Upper intake
-Head Gaskets
-Thermostat
-Thermostat gasket
-Waterpump hoses
-Spark Plugs
-Distributor Cap
-Distributor Rotor
-Fuel injector O-Rings
-Exhaust manifold gaskets
All rusty parts, like valve covers and oil pan were wire wheeled down, and repainted with high temp paint.
-Pat
post #142 of 1008 Old 04-04-2010, 09:00 PM Thread Starter
redhatman
redhatman's Avatar
Notice the stock tires, that allowed us to get the cherry picker high enough lol.
4.slow is out!!
-Pat
post #143 of 1008 Old 04-04-2010, 09:04 PM Thread Starter
redhatman
redhatman's Avatar
And if you want more info on the engine swap....
http://www.jeepforum.com/forum/f13/m...-5-2-a-898022/
-Pat
post #144 of 1008 Old 04-04-2010, 09:09 PM Thread Starter
redhatman
redhatman's Avatar
I have yet to wheel with the V8, being the last trip was last summer/fall at the customer appreciation.
At IRO we just came out with a new ZJ skid plate, and it works very well (bolts up) to your existing IRO Front LA XMember.
-Pat
post #145 of 1008 Old 04-04-2010, 09:16 PM Thread Starter
redhatman
redhatman's Avatar
After putting the V8 in, my brand new front driveshaft was 3 inches too long!!!! So after spending $250 on the shaft, I had to get it shortened....
I saw and read all about ZJ V8 Exhaust upgrades, and although I wanted headers I did not want to pay for them. So I did take the step and have an exhaust shop (Reed @ Midas in Shakopee, Thank you) Put in this little section of pipe to get rid of the factory kink.
I needed new tires about two months ago, so while looking I came across the 37's. So why not? I wanted a little more clearance, so I put new springs in. IRO 7" ZJ fronts, no isolator, with BB stacked. And the rear, I took my old 7" fronts and did the good ol ZJ Front to rear! haha I was sitting at 10.5" in the rear, until I cut the coils. It now sits at 8.5" in the rear, 8" in front.
I drove it like that, and finally the vibes started. I guess 7" was the cutoff. I did the IRO Hack N Tap kit, its famous for XJ users, because its cheap and works wonders. For ZJ's, you need a custom driveshaft.
-Pat
post #146 of 1008 Old 04-04-2010, 09:21 PM Thread Starter
redhatman
redhatman's Avatar
That took care of all the vibes, it was amazing.
Since I am going to school for Automotive, I used it to my advantage. Although the 44re with 220k on it shifted fine, I decided to rebuild it for class credit. I had to buy parts, but it was worth it for the experience too.
So I bought a master rebuild (all new clutches, bands, new intermediate servo, seals) and also a Transgo shift kit.
I feel like I just had the trans out....
-Pat
post #147 of 1008 Old 04-04-2010, 09:22 PM Thread Starter
redhatman
redhatman's Avatar
Valve body
-Pat
post #148 of 1008 Old 04-04-2010, 09:25 PM Thread Starter
redhatman
redhatman's Avatar
O.D Unit, where you need a press. There is an 830 pound spring compressed in there!
While I had the t-case out, why not reseal it and inspect it? It was leaking between the case halves ever so slightly. So I tore it apart, and replaced all of the seals.
-Pat
post #149 of 1008 Old 04-04-2010, 09:27 PM Thread Starter
redhatman
redhatman's Avatar
Shift Improver kit. Basically corrects all problems the trans is known for, does not make a hard shift.
It was my first time ever rebuilding a transmission, and thankfully it worked!
-Pat
post #150 of 1008 Old 04-04-2010, 09:29 PM
lateralus3
1994 ZJ
your jeep makes me
lateralus3 is offline
Bentley Project (WJ) Build Thread lvum4x4 Grand Cherokee General Discussion 312 08-18-2016 04:18 PM
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-15-2016 12:39 AM
Build Thread - Project Lowis Jones Grand Cherokee General Discussion 2650 08-08-2012 11:39 PM
Rmtomasin build thread- Project Jeep Grand Heep rmtomasin Grand Cherokee General Discussion 224 08-11-2011 09:19 PM
My WJ Project Build Thread 22remud Grand Cherokee General Discussion 24 05-24-2011 08:30 AM
