Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 04-17-2011, 09:41 PM   #91
squashman702
1994 ZJ
Originally Posted by redhatman View Post
I pulled some plugs today and did some tests, diagnosed the headgaskets are bad. I cant say the timing was too bad, being I was going to tear half the motor apart this week anyway, I am going to have to do heads and gaskets now too... as well as fix the fan.
I think I will go with remanufactured heads, or just remanufacture mine. This would involve remilling the surface, and a valve job. Along with a visual inspection on the heads all around.
Make sure the heads aren't cracked while you've got them off. Magnum heads are known for this.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2011, 10:23 PM   #92
redhatman
Originally Posted by blackjack12982 View Post
Pat
I looked into having that Y-pipe media blasted while I was still deployed, but once I got back everything went to crap. Didn't know if that was option for you or not...
Yeah I have been using this one guy that did my intake mani, front axle, knuckles, and some other stuff. Charges like 60/hr. I decided not to on this one due to his window, usually takes about a week to get stuff back.
Heads should arrive monday, and go on tuesday.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote Quick reply to this message
Unread 04-17-2011, 10:43 PM   #93
redhatman
They were haha I already counted on seeing a crack between the valves.
-Pat
Unread 04-18-2011, 03:52 PM   #94
redhatman
The heads have arrived
-Pat
Unread 04-20-2011, 08:04 AM   #95
redhatman
The heads, complete intake, water pump and valve covers are all on and tight. I was working on getting the headers on yesterday, along with the Y-Pipe but I am having trouble getting the headers on. I picked up some short studs to try and ease with installation. Also, I have yet to get the passenger side header even mounted in place, first I kept hitting the oil filter, now the stock UCA mount, I dont see how these would fit a stock ZJ unless you installed them with the heads off?
-Pat
Unread 04-20-2011, 08:08 AM   #96
blackjack12982
1994 ZJ
Are those the Iron Ram heads?
blackjack12982 is offline   Reply With Quote Quick reply to this message
Unread 04-20-2011, 09:25 AM   #97
redhatman
I wish.
Just reman stockers.. resurface, 3 angle valve grind, valve check, pressure tested, blah blah
-Pat
Unread 04-20-2011, 10:57 AM   #98
squashman702
1994 ZJ
I wish.
Where'd you get them and how much? Might need to do the same on my 5.9 swap.
As for the headers, I've heard of the unibody rails needing to be "massaged" to get them to fit. Post up what you get to work, I have Mopar headers to go on mine, which were either made by ML or he bought the design.
Think Twice Garage
Unread 04-20-2011, 11:06 PM   #99
redhatman
http://headsonly.com/ $350 shipped, they provide shipping labels to return your core heads. If you dont return cores, they charge you another $100.
I got the headers on today.... what a *****. I ended up taking out the spark plug shields from the head, the oil filter, coolant reservoir bracket, and CUT OFF THE STOCK UCA mount. Now surely there has to be a better way to get it in, like say for a Jeep that actually needs those mounts? IDK but either way both headers are mounted and tight.
I am going to look into locking fasteners, I hear that header bolts always come loose. These headers look nice and all, but jiminy crickets there is hardly any room to work, and I dont know how you are supposed to actually torque the nuts. Half are tightened with what I felt was right, with a standard wrench.
I ended up using 3 1.25" long, 5/16" studs. Dorman #735-202 per side. Jeep should hopefully be running tomorrow! Just gotta put the rest of the accessories on, and also fab up the rest of the exhaust.
Note. I thought 5.9's had a factory 3" pipe? I guess not, mine is 2.5".
-Pat
Unread 04-21-2011, 01:54 AM   #100
ZJ5point2GCL
Looking good.
The 5.9s did come stock with a 3'' tailpipe, but just after the muffler, the rest is only 2.5" i think.
and i bought stage 8 locking header bolts, and gave up putting them together since its so tight in there, but i haven't had any issues with them backing off on either jeeps, i think it might just be an issue with the cheap headers and the thin flanges, because i know my friend with a chev and headers are always loose and leaking.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline   Reply With Quote Quick reply to this message
Unread 04-22-2011, 01:44 PM   #101
redhatman
ahh, 3" tailpipe.... Yeah I was thinking about the headerbolts and was like how the hell am I going to get that contraption on here if I can hardly even get a damn wrench to the impossible nut on the 1/2 inches of stud sticking out....
in other news. JEEP.IS.ALIVE.
UCA Mount
-Pat
Unread 04-22-2011, 01:45 PM   #102
redhatman
-Pat
Unread 04-22-2011, 01:47 PM   #103
redhatman
The clearance on everything is basically non existant.. the headers were very tricky to put in, and thanks to the Y pipe I now have a new oil pan heater, as well as my 02 hitting my tranny case. I am trying to seal up all of the flanges that are leaking still.
-Pat
Unread 04-24-2011, 12:35 PM   #104
vwmaniacx
Looking good. (I know it's a pain) but what if you were to drop it again, and wrap it, also maybe just move the 02 bung alittle? Whenever i do exhaust I use "muffler weld" in all the flanges just to give it alil better seal. I also use band clamps instead of those c-clamps.
you can go a long way with a smile . You can go a lot farther with a smile and a gun . -Al Capone
If you own a VDUB this is where you should be
Western Mass 4x4
vwmaniacx is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 03:18 PM   #105
jeep0312
Love this build too. How does it feel to be smaller then "grow a set?"
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline   Reply With Quote Quick reply to this message
