Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 02-01-2011, 02:06 PM   #31
rugermack
I like the idea of putting the holes for the pinch seem directly in the rectangular tube, instead of adding another strip of metal for the pinch seem. less welding and drilling, plus it tucks it up a little better(and a little stronger). I'm glad I didn't weld that piece on yet.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
rugermack is offline   Reply With Quote Quick reply to this message
Unread 02-01-2011, 11:15 PM   #32
redhatman
I totally agree.
Got the sliders mounted tonight, smashed my thumb in the process.... ugh. Pictures later.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote Quick reply to this message
Unread 02-01-2011, 11:40 PM   #33
aircruiser
Originally Posted by redhatman View Post
Do you want one to reference the height? Or are you saying next to your new zj?
dude hurry before i lift mine and you can get pics next to mine stock
i still have yet to ride in this *****..we need to chill soon bro so i can finally decide whether or not to swap a 5.9 in mine
and you should totally paint the fake beadlock ring that silver color too
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 12:53 AM   #34
redhatman
...... hmmm ...... You got me thinking now. The Jeep's color scheme seems to be black/dark metallic grey.
-Pat
Unread 02-02-2011, 05:54 AM   #35
Irish_Assassin
It looks good. I really enjoy reading this thread!
April '11 GCOTM
COLORADO JEEP CLUB #133
www.militaryjeepers.com
Irish_Assassin is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 06:46 AM   #36
rugermack
I totally agree.
Your not working on a jeep if you don't atleast smash one finger.
Unread 02-06-2011, 11:16 PM   #37
redhatman
-Pat
Unread 02-06-2011, 11:20 PM   #38
redhatman
Compressor Mounted, not wired in quite yet.
The door hinge decided to go out, and with that the door hits really hard due to the misalignment, actually sheared the sheet metal. I am going to order that new hinge and weld it on soon, then repair the cracking.
Drop bumper, custom plates.
C Gussets from IRO, ALmost alloy tabs welded over Spicer 760's.
CB Mount
-Pat
Unread 02-06-2011, 11:24 PM   #39
redhatman
Got the rock sliders all painted and mounted up!
Swapping a few more parts over, getting the Project Grow-A-Set (brown one) ready to sell
-Pat
Unread 02-06-2011, 11:26 PM   #40
biggoofy
Looks sweet man
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
[URL="http://www.mallcrawlin.com/forum/showthread.php?22776-Biggoofy-s-96-ZJ-build!-**Building-axles**"]My Build[/URL]
Need quality parts call Andy at Ironman4x4fab!!!!!
[url]http://ironman4x4fab.com/index.html[/url]
[/CENTER]
biggoofy is offline   Reply With Quote Quick reply to this message
Unread 02-06-2011, 11:31 PM   #41
redhatman
A few more goodies I fixed this weekend aswell, as mentioned earlier I had a faulty coolant temp sensor in the upper radiator hose. Funny enough, this sensor is not available through any parts stores, or any dealer in the country. The parts guy at the dealer suggested "go to a junkyard, find a 5.9 grand, and take one off of that".... reallly? How many do you find in the junkyard?
So with doing some research I found a common GM Coolant temp sensor works, same threads, same plugs, but instead of commanding the fan on at 210 deg. it comes on at 200. So with replacing BOTH sensors (they are the same sensor, upper and lower rad hoses), I also put in a failsafe 180* T-Stat. 180* is the temp it opens up at, and the failsafe is a design so that if it fails, it fails open vs. closed. This prevents overheating if it fails. The feature costs a little bit extra, but it is worth it.
By putting in the cooler T-stat, the engine runs cooler all the time. For those of you not familiar with computer systems on cars, the computer is commanded to lengthen the time of injector pulses (dump more fuel) for cooler operating conditions. Inputs for this are the ECT and IAT aka engine coolant temp and intake air temp.
OEM vs new, OEM does not have the nipple.
-Pat
Unread 02-06-2011, 11:34 PM   #42
redhatman
And of course with all of this added horsepower I decided to take out the stock airbox and put in a new air filter setup. Its simply a reuseable cone filter from the parts store, and pvc piping to connect it to the stock hose. I will make a support for it, and possibly a "heat shield" for it in the future.
Notice with the addition of the cone filter, you eliminate the breather tube. To solve that problem I picked up an aftermarket breather from the parts store (1" neck) to pop into the factory breather grommet.
-Pat
Unread 02-06-2011, 11:36 PM   #43
redhatman
Originally Posted by biggoofy View Post
Looks sweet man
Thanks!
-Pat
Unread 02-06-2011, 11:47 PM   #44
aircruiser
hey man ive never actually seen how that cb mount is held in..what extra holes did you drill? ive been wanting to add a cb to mine but dont want to really drill any extra holes..i was thinking about try to make a mount that uses all 3 tail light holes but i dunno. i just wanna do it for going up to gilbert since they all use cbs and i get no cell reception up there.
Unread 02-06-2011, 11:48 PM   #45
JFox21
Looks awesome man. Nice job on the sliders. See you in three days!
Jamie
Sophomore at Santa Clara University
JFox21 is offline   Reply With Quote Quick reply to this message
