Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build - Page 28 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line50" LED CREE Light Bar Pair With Wiring KitTeraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMA
Unread 10-23-2012, 02:09 PM   #406
redhatman
*picture in reference is from kevinsoffroad.com . I used this picture for the sole purpose of showing how the cage fits. All rights belong to them*
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote Quick reply to this message
Unread 11-26-2012, 05:20 PM   #407
redhatman
Finally got around to fixing the exhaust!
I also noticed that my gas tank in the rear has a burn mark on the plastic tank. I hope it holds up and that the pipe doesn't expand that far back. The ZJ exhausts are known to move backward about an inch when they are at full operating temperature.
-Pat
Unread 01-17-2013, 10:54 AM   #408
redhatman
Not relevant to my build, please take a minute to sign this whitehouse petition to stop the expansion of 29 palms marine base and save the public land use for recreational activities as well as our only place to run King of the Hammers, KOH in Johnson Valley
If you are not familiar with king of the hammers, do a search on youtube. Crazy stuff, it only takes a minute and we have 16,000 signatures to go! I hope to be in this one day.
Don't forget to share this!
http://ultra4racing.com/the-inside-l...e-the-hammers/
-Pat
Unread 07-17-2013, 10:35 PM   #409
redhatman
The niner's been running a little warm lately, so I decided to pull out the fan and check out the radiator fins. You can see they were pretty dirty!
All cleaned out. I rinsed the fins out with a garden hose from the front and back, and then sprayed some degreaser/soap, let it sit, and washed it all off again.
-Pat
Unread 07-17-2013, 10:53 PM   #410
redhatman
I had been told by a few people that my passenger rear tire had a wobble to it. Having the 8.8 in the rear end, I knew from my previous experience at IRO that the passenger side shafts of these bend from time to time in this manner. They bend in such a way where the tire wobbles. You really can't feel it in the jeep, but it is noticeable if you tilt your mirrors down and watch it as you go down the road. I didn't want to spend the money on a brand new shaft if I wasn't sure it would fix it, especially since I would have to tear apart the locker which can be kinda finicky.
So, here's how I tested it using a dial indicator. This setup checks the run-out. I checked both sides, the drivers side shaft had about 5 thousandths, while the passenger side had about 25.... Check it out, pretty entertaining to watch the gauge!
-Pat
Unread 07-17-2013, 10:54 PM   #411
redhatman
Here's an 8 second video showing you the gauge
-Pat
Unread 07-17-2013, 11:03 PM   #412
redhatman
Time to replace the shaft!
Diff cover off
-Pat
Unread 07-17-2013, 11:05 PM   #413
redhatman
Now it's time to start taking apart the Aussie Locker!
-Pat
Unread 07-17-2013, 11:10 PM   #414
redhatman
Shaft is out
Time to press in some new studs into the new axle shaft!
-Pat
Unread 07-17-2013, 11:14 PM   #415
redhatman
Setting up the studs to pull through with the impact
All 5 studs installed!
-Pat
Unread 07-17-2013, 11:17 PM   #416
redhatman
Reassembling the differential/locker
All back together
The diff cover is cleaned, and a thin layer of silicon is applied to both the cover and the cleaned housing.
I've been driving on it for a few days now and there's no more wobbling. Time to get some tires soon now that that's fixed.
-Pat
Unread 07-18-2013, 09:46 PM   #417
NTexasZJ
I love your build man! Looks great. Awesome flex. Good wheelin photos. Keep up the great work. I have a 5.2 I'm getting started on.
NTexasZJ is offline   Reply With Quote Quick reply to this message
