Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build - Page 22 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Project "Dirty Princess" ... Redhatman's 5.9 ZJ Build
JK Bumper System - Free Shipping + Cash RebateSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 06-23-2012, 02:05 AM   #316
redhatman
redhatman's Avatar
Originally Posted by Timo_90xj View Post
Ok, sounds good enough.. I've partially rebuilt two engines, set up multiple R%P sets, done a whole lot of fabbing, but this thing creeps me out
I have a nice big magnet and a steel tray, I'll be doing the tear-down and rebuild on that Thanks for the info and pics!
No problem! Like I said, let me know if you have any questions. Just make sure you have plenty of time to do it, and take your time.
Old steering box out
I noticed the one that was in my Jeep, (reman one) had this rubber boot inside of the pitman hole. I dont know it it was meant to be a diaper type of seal from the reman company, or basically a dust shield. I reinstalled it on the new one, factory ones dont have it.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote
Unread 06-23-2012, 02:14 AM   #317
redhatman
redhatman's Avatar
After these pictures, i put the steering box brace back on too and made sure it was free of oil residue. So far after 40 minutes of total driving since installation, its all good. Drives nice, and leak free! I have the ends capped until I get the ram mounted, which I hope will be saturday.
I then took the ram apart so I could see what I am dealing with, and so I can weld to it without worrying about overheating the o-rings
-Pat
Unread 06-23-2012, 03:05 PM   #318
redhatman
redhatman's Avatar
Time to start mounting the ram!
I remeasured everything again before deciding to cut up the ram and making it un-returnable. It looks like this ram will end up being slightly too short. Ideally, I think you would want about 6.5" of travel, obviously it depends on how you mount it too. I am still going with my 6" ram because the way I see it, is even if you bumpstop the inside of a longer ram, if that thing extends even a little too far, you are either bending your tie rod, or pulling on the gearbox. I would rather loose that little bit of steering at the end of the cycle and have the ram be the stop, versus having the steering box and components being pushed to their limits and causing excessive wear.
Rough sketch of what I plan on doing to mount it on the tie-rod
Drawn neater
Traced onto 1/4" steel plate
-Pat
Unread 06-23-2012, 03:07 PM   #319
redhatman
redhatman's Avatar
I started by drilling both of the holes first, then I cut out the two tabs and bolted them side by side.
I went over it with a flapwheel and made them identical all around.
You can see here, the heim would not have maximum rotational travel being its limited by the flat on the tab. So I drew a new cut line.
Fixed
-Pat
Unread 06-23-2012, 03:11 PM   #320
redhatman
redhatman's Avatar
Time to start modifying the ram. I started with the rod end of it. I took the ram all apart, and first ground the tube flat with an angle grinder as I could, then took an even surface off with the lathe. I am putting the flat on there so I can drill it straight through.
Time to drill!
More updates later!
-Pat
Unread 06-24-2012, 10:39 AM   #321
redhatman
redhatman's Avatar
-Pat
Unread 06-24-2012, 10:41 AM   #322
redhatman
redhatman's Avatar
Making the mount...
-Pat
Unread 06-24-2012, 10:43 AM   #323
redhatman
redhatman's Avatar
Ram bolted on... I am planning on strengthening up the drivers side of the mount too, dont worry
What do you guys think?
-Pat
Unread 06-24-2012, 02:52 PM   #324
redhatman
redhatman's Avatar
That's awesome man!
-Pat
Unread 06-24-2012, 02:55 PM   #325
redhatman
redhatman's Avatar
Thanks, I think so too.....
Tab welded onto the tie rod, I sense a new coat of paint on all of the steering soon!
Bracket all tacked up, I have washers installed that is equal to the width of the heim so that when I weld it all together nothing warps like crazy.
-Pat
Unread 06-24-2012, 03:55 PM   #326
Freestyle713
1994 ZJ
That's awesome man!
Lol
[B]94 Grand Cherokee 5.2[/B] [SIZE="1"]33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's[/SIZE]
[CENTER][COLOR="Yellow"][URL="http://www.jeepforum.com/forum/groups/zombie-outbreak-response-vehicles/"][COLOR="Yellow"]Zombie Outbreak Response Team[/COLOR][/URL][/COLOR][/CENTER]
[QUOTE=elcorvino;14544406]Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.[/QUOTE]
[QUOTE=ScottD16;14460352]I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.[/QUOTE]
Freestyle713 is offline   Reply With Quote
Unread 06-24-2012, 05:05 PM   #327
redhatman
redhatman's Avatar
Welded the tabs onto my tie-rod
I then took some 3/4" round stock and cut off thin slices and used these as caps. I welded them in, and ground them smooth to make the ram look a little better.
Welding the axle mount bracket on, I decided to remove the tie rod so I could get the steering stabilizer bracket off, and also so I could get a better angle for prepping the surface, welding, and painting.
-Pat
Unread 06-24-2012, 05:07 PM   #328
redhatman
redhatman's Avatar
Painting the ram, I did 2 coats of primer, then silver
-Pat
Unread 06-24-2012, 05:09 PM   #329
redhatman
redhatman's Avatar
Now....I.....Just....get.....to....wait.....for... ........paint.............to...............dry.... ........
-Pat
Unread 06-24-2012, 07:50 PM   #330
redhatman
redhatman's Avatar
Well..... any updates? How's it work?!
-Pat
