Project Bailee: ZJ build - Page 2 - JeepForum.com
post #16 of 66 Old 02-24-2013, 03:11 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I just priced a 3.5" lift out for my ZJ, $1800
D3<!L!>3D
S8NNG8 is online now
post #17 of 66 Old 02-24-2013, 03:32 PM Thread Starter
bailee93zj
Really? You only need front coils and trackbar adjustment swaybar links and shocks the factory front coils move to the rear
93 grand cherokee limited 5.2l 2.5"lift with baja lights on roof
bailee93zj: 93 grand cherokee, 4" lift f>r, 5.2l V8, NP242 select track, homemade tube front bumper, 4 off road lights, sony radio, and 264K miles!
my build: http://www.jeepforum.com/forum/f197/project-bailee-zj-build-1483583/#post15023554
bailee93zj is offline
post #18 of 66 Old 02-24-2013, 04:01 PM
1stblack97ZJ
indulge me on the breakdown on this. My 4" lift that I pieced together cost me around 400. We aren't building hardcore rock crawlers here.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #19 of 66 Old 02-24-2013, 04:10 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Front: coils, shocks, adj. uca's, adj. lca's, disco's, brake lines, track bar
Rear: coils, shocks, uca's, adj. lca's, brake lines, t-case drop bracket.
And the front control arms will have the forged flex ends.
D3<!L!>3D
post #20 of 66 Old 02-24-2013, 04:12 PM
1stblack97ZJ
See, all that is not NECESSARY for a safe, reliable lift.
And you don't need a t-case drop on a ZJ at 3.5"
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #21 of 66 Old 02-24-2013, 04:17 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
The replacement of the control arms isn't necessary but if you felt the difference it can make... I have a first hand example, I did uca's and lca's on my 3.5" XJ. It repositioned the axle to its proper location, and gave me better use of the longer springs without binding
D3<!L!>3D
post #22 of 66 Old 02-24-2013, 04:19 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
As far as the t-case drop, that's precautionary due to the possibilities when the sway bars are diconnected.
D3<!L!>3D
post #23 of 66 Old 02-24-2013, 04:41 PM
1stblack97ZJ
I did front LCAs on mine.
IRO double sheer adjustable front trackbar: $200
IRO front extended swaybar links: $60
Front coils to rear: free
Ford thunderbird coils in the front: $20 (slightly rougher ride than stock, but not bad at all. Rides like my grandparents 02 highlander)
Front tube LCAs that are a little longer: $20 (I got lucky on that one)
Rebuilt steering with new TREs and moog TRE boots: ~$80
New SS: $30
But when you add all brand new springs, and all adjustable control arms, I can easily see how the cost would go up a lot.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #24 of 66 Old 02-24-2013, 05:25 PM Thread Starter
bailee93zj
2.5 inches will do for now till we sway some coils then ill have the t-bird coils so then ill have to get sway bar links and track bars and shocks otherwise thats all ill have to get i think. First i think i should get my muffler on... so its not so loud.
post #25 of 66 Old 02-24-2013, 05:29 PM
1stblack97ZJ
Yeah when do you wanna do the muffler?? I still got 1 clamp layin here on my toolbox.
Sent from my Samsung Galaxy Proclaim using JeepForum
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #26 of 66 Old 02-24-2013, 05:31 PM Thread Starter
bailee93zj
the rough ride might be not so bad with my jeep because you have the I6 and i have the 5.2
post #27 of 66 Old 02-24-2013, 05:33 PM Thread Starter
bailee93zj
when its not snowing haha some time on a sunny decently warm day would be good.
post #28 of 66 Old 02-24-2013, 06:24 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
New SS: $30
I find my satisfaction in knowing that all the parts were designed to work properly with each other. I also want the full capabilities of a 3.5" lift without worries. I also plan to put a pair of Currie 9"s and maybe 33's some day.
D3<!L!>3D
post #29 of 66 Old 02-24-2013, 06:36 PM Thread Starter
bailee93zj
well before i had the two inch blocks i had 2x6boards as spacers so i made the blocks to replace them and made them 2 inches
post #30 of 66 Old 02-24-2013, 06:57 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I'm the guy accused of being the "crazy perfectionist". Guilty! But I'm also the guy who is looked up to and envied by his friends. My friends are jealous but they also respect me cuz of the quality of my rigs knowing that I put them together. Secretly, my rigs are not perfect, I'm just proud of my project and I take care of it cuz of that pride.
My point: build it your way, so that you're proud of it
D3<!L!>3D
