problem's with my jeep gcl - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > problem's with my jeep gcl
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJeep Gear & Install Packages!Rough Country Lift Kits and Parts!
Unread 11-09-2014, 07:07 AM   #1
MikeMcCoy81
I had these's three code come up on my scanner yesturday.
P1687 no mechanical instrument cluster bus message
P1686 No Skim (smart key immobilizer module) bus message recived
P0443 Evaporative Emission system Purge control valve circuit
And last week i had camshaft senser come up change the cam shaft senser and it fires up all the time now. But i keep losing my dust cluster iv'e took apart the connection and cleaned them in the dash seems ok but again I lost my gauges again.
MikeMcCoy81 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 07:09 AM   #2
MikeMcCoy81
Also had a new key programed and cleared the key with a line threw it used to run for two seconds and shut down but now it stays running.
Unread 11-21-2014, 08:41 AM   #3
MikeMcCoy81
Ok change the low speed sensor and camshaft position sensor and Vapour sensor all installed and crankshaft position sensor at home didn't install the crankshaft position sensor because it started no problem for about 2 weeks now the gagues are always screwing up and zeroing out. No whats wrong with this money pit
