Portable air tank ? - JeepForum.com
post #1 of 13 Old 04-12-2013, 09:15 AM Thread Starter
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Portable air tank ?
I carry a little Viair compressor right now and I'm thinking of a portable tank to speed airing back up. What size tank do I need to air up 4 32" tires quickly? I can fill the tank to 125 psi and I usually air down to 12-15 psi. thanks
HighLonesome is offline
post #2 of 13 Old 04-12-2013, 09:25 AM
kensnelling
For 4 tires you'll need a BIG tank. My 7 gallon tank puts about 10 psi in 1 LT265/75R16, then it's time for a refill.
Ken
kensnelling is offline
post #3 of 13 Old 04-12-2013, 09:34 AM Thread Starter
HighLonesome
jeez not what I wanted to hear
maybe its a bad idea
post #4 of 13 Old 04-12-2013, 11:44 AM
Uniblurb
Uniblurb's Avatar
Yeah, my 7 gal air tank filled to 125psi will only raise the air pressure by 10psi in about 3 1/2 stock tires (M&S 235/75/R15), 4 if I'm lucky, before it's empty. So probably wouldn't be feasible for your big tires unless you had a bigger tank.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #5 of 13 Old 04-12-2013, 01:10 PM
Technohead
You need something like a scuba tank.
-Eric
Technohead is offline
post #6 of 13 Old 04-12-2013, 02:01 PM Thread Starter
HighLonesome
I don't want anything I have to pay to get filled.
post #7 of 13 Old 04-12-2013, 04:11 PM
joshsmithers
1994 ZJ
If you have a shop compressor and an HPA booster, the only thing you'll have to pay is the electricity bill. An air booster can to fill any size tank up to 4500 psi or more depending on the booster. I'm not sure how much air boosters go for, though.
joshsmithers is offline
post #8 of 13 Old 04-12-2013, 04:22 PM
joshsmithers
1994 ZJ
Here's a compressor that fills up to 4500 psi and requires only 85 psi input air! Starts at $650. http://www.shoeboxcompressor.com/
post #9 of 13 Old 04-12-2013, 05:01 PM Thread Starter
HighLonesome
That is cool. That, a scuba tank, and some fittings and hoses should work.
In all reality, I'm thinking of only airing down to 18-20 lbs and going with a 10-11 lb tank. The tank is well under $100.
post #10 of 13 Old 04-12-2013, 05:53 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
co2, maybe a 20lb tank would get you done for a few trips.
125psi air? at least a 20gal
ratmonkey is offline
post #11 of 13 Old 04-12-2013, 05:59 PM
WhiteOut
WhiteOut's Avatar
If you only plan on going to 20psi, I wouldn't bother airing down at all.
WhiteOut is offline
post #12 of 13 Old 04-12-2013, 06:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
there is that though. 20psi isn't enough of a drop to matter.
post #13 of 13 Old 04-12-2013, 06:31 PM Thread Starter
HighLonesome
Been going to 18 lately. I just cruise forest roads with my wife and it really smoothes it out for us old folks.
